Converting the HVPSFB EVM to F28069 MCU
Other Parts Discussed in Thread: CONTROLSUITE
I'm converting the HVPSFB EVM software package to the F28069 MCU on a new PCB, and get two linker error that I find difficult to solve:
1. unresolved symbol _Comp, first referenced in ./DAC_Cnf.obj HVPSFB_PCMC
2. unresolved symbol _ePWM, first referenced in ./PWM_PSFB_PCMC_Cnf.obj HVPSFB_PCMC
I'm not able to determine in which file these structs are defined:
// Used to indirectly access all Comparator modules
volatile struct COMP_REGS *Comp[] = ..........
// Used to indirectly access all EPWM modules
volatile struct EPWM_REGS *ePWM[] = ........
Best regards
Consul
  • Hello Consul!
    I'm not sure but perhaps you need to define within your main file:
    Variant 1
    volatile struct EPWM_REGS *ePWM[8] = {&EPwm1Regs, &EPwm2Regs, &EPwm3Regs, &EPwm4Regs,
    &EPwm5Regs, &EPwm6Regs, &EPwm7Regs, &EPwm8Regs};
    volatile struct COMP_REGS *Comp[3] = {&Comp1Regs, &Comp2Regs, &Comp3Regs};
    Variant 2
    extern volatile struct EPWM_REGS *ePWM[];
    extern volatile struct COMP_REGS *Comp[];
    Also perhaps you need to include to project this library:
    ti\controlSUITE\device_support\f2806x\v136\MWare\rts2800_bl\Release\rts2800_bl.lib
    Igor
