Other Parts Discussed in Thread: CONTROLSUITE
HI,
I am using Concerto development board. I try to run my codes in Flash memory(permanent program like that). I programmed successfully in ARM core and it is working fine when i power down and again power it up.
Then i try to load my program my DSP code into flash memory. While loading it was showed like "Erasing Flash " then " Load programming". When i power down then again power it know, that time my ARM is running but my DSP is not running.
I try to load blinky project only. I set my boot pin as 0x07.
Thanks in advance
Thirumoorthy.R
