DAC channel on the TMS320F2812
Other Parts Discussed in Thread: TMS320F2812, SPRC097
hi,
is there a way to display signals from the TMS320F2812 on a Oscilloscope? In the datasheet there is no indication about the DAC channels .
M.J
    you can download C281x C/C++ Header Files and Peripheral Examples (SPRC097) from here http://www.ti.com/tool/sprc097.  "ev_pwm" is event Manager PWM example. This program sets up the EV timers to generate PWM waveforms. The user can then observe the waveforms using an oscilloscope.
    Igor
    You can use the EV Timers, as suggested by Igor, to output a PWM waveform.  If desired, you could configure the PWM to be very fast and then filter these PWM waveforms with an RC-filter (or similar) to get an analog output.
    (the magnitude of the analog output would then by 3.3*D where D is the Duty cycle of the PWM.  Assuming that the speed of the PWM and the RC-filter is chosen correctly you shouldn't see too much ripple)
    Thank you,
    Brett
