Other Parts Discussed in Thread: CONTROLSUITE
when i am running the code for DAC,it is showing one error such as ''could not open the source file "f2833xbmsk.h".why it this error is coming .i am attaching the code for DAC.
File name: F2833XPWMDAC.H
Originator: Digital Control Systems Group
Texas Instruments
Description:Header file containing data type, object, macro definitions and initializers
Configures PWM 5A & 6A as PWMDACs for HVDMC Kit
Target: TMS320F2833x family
History:
04-15-2010 Version 1.0:
#ifndef __F2833X_PWMDAC_H__
#define __F2833X_PWMDAC_H__
#include "f2833xbmsk.h"
Initialization constant for the F2833X Time-Base Control Registers for PWM Generation.
Sets up the timer to run free upon emulation suspend, count up-down mode
prescaler 1.
#define PWMDAC_INIT_STATE ( FREE_RUN_FLAG + \
PRDLD_IMMEDIATE + \
TIMER_CNT_UPDN + \
HSPCLKDIV_PRESCALE_X_1 + \
PHSDIR_CNT_UP + \
CNTLD_DISABLE )
Initialization constant for the F2833X Compare Control Register.
#define PWMDAC_CMPCTL_INIT_STATE ( LOADAMODE_ZRO + \
LOADBMODE_ZRO + \
SHDWAMODE_SHADOW + \
SHDWBMODE_SHADOW )
Initialization constant for the F2833X Action Qualifier Output A Register.
#define PWMDAC_AQCTLA_INIT_STATE ( CAD_SET + CAU_CLEAR )
#define PWMDAC_AQCTLB_INIT_STATE ( CBD_SET + CBU_CLEAR )
Initialization constant for the F2833X Dead-Band Generator registers for PWM Generation.
Sets up the dead band for PWMDAC and sets up dead band values.
#define PWMDAC_DBCTL_INIT_STATE BP_DISABLE
Initialization constant for the F2833X PWM Chopper Control register for PWM Generation.
#define PWMDAC_PCCTL_INIT_STATE CHPEN_DISABLE
Initialization constant for the F2833X Trip Zone Select Register
#define PWMDAC_TZSEL_INIT_STATE DISABLE_TZSEL
Initialization constant for the F2833X Trip Zone Control Register
#define PWMDAC_TZCTL_INIT_STATE ( TZA_HI_Z + TZB_HI_Z + \
DCAEVT1_HI_Z + DCAEVT2_HI_Z + \
DCBEVT1_HI_Z + DCBEVT2_HI_Z )
Define the structure of the PWMDAC Driver Object
typedef struct {
int16 *PwmDacInPointer0; // Input: Pointer to source data output on PWMDAC channel 0
int16 *PwmDacInPointer1; // Input: Pointer to source data output on PWMDAC channel 1
int16 *PwmDacInPointer2; // Input: Pointer to source data output on PWMDAC channel 2
int16 *PwmDacInPointer3; // Input: Pointer to source data output on PWMDAC channel 3
Uint16 PeriodMax; // Parameter: PWMDAC half period in number of clocks (Q0)
} PWMDAC ;
Define a PWMDAC_handle
typedef PWMDAC *PWMDAC_handle;
Default Initializers for the F2833X PWMGEN Object
#define F2833X_PWMDAC_DEFAULTS { (int16 *)0x300, \
(int16 *)0x300, \
(int16 *)0x300, \
(int16 *)0x300, \
500, \
#define PWMDAC_DEFAULTS F2833X_PWMDAC_DEFAULTS
PWMDAC Init & PWMDAC Update Macro Definitions
#define PWMDAC_INIT_MACRO(v) \
/* Setup Sync*/ \
EPwm5Regs.TBCTL.bit.SYNCOSEL = 0; /* Pass through*/ \
EPwm6Regs.TBCTL.bit.SYNCOSEL = 0; /* Pass through*/ \
/* Allow each timer to be sync'ed*/ \
EPwm5Regs.TBCTL.bit.PHSEN = 1; \
EPwm6Regs.TBCTL.bit.PHSEN = 1; \
/* Init Timer-Base Period Register for EPWM5-EPWM7*/ \
EPwm5Regs.TBPRD = v.PeriodMax; \
EPwm6Regs.TBPRD = v.PeriodMax; \
/* Init Timer-Base Phase Register for EPWM5-EPWM7*/ \
EPwm5Regs.TBPHS.half.TBPHS = 0; \
EPwm6Regs.TBPHS.half.TBPHS = 0; \
/* Init Timer-Base Control Register for EPWM5-EPWM7*/ \
EPwm5Regs.TBCTL.all = PWMDAC_INIT_STATE; \
EPwm6Regs.TBCTL.all = PWMDAC_INIT_STATE; \
/* Init Compare Control Register for EPWM5-EPWM7*/ \
EPwm5Regs.CMPCTL.all = PWMDAC_CMPCTL_INIT_STATE; \
EPwm6Regs.CMPCTL.all = PWMDAC_CMPCTL_INIT_STATE; \
/* Init Action Qualifier Output A Register for EPWM5-EPWM7*/ \
EPwm5Regs.AQCTLA.all = PWMDAC_AQCTLA_INIT_STATE; \
EPwm6Regs.AQCTLA.all = PWMDAC_AQCTLA_INIT_STATE; \
/* Init Dead-Band Generator Control Register for EPWM4-EPWM6*/ \
EPwm5Regs.DBCTL.all = PWMDAC_DBCTL_INIT_STATE; \
EPwm6Regs.DBCTL.all = PWMDAC_DBCTL_INIT_STATE; \
/* Init PWM Chopper Control Register for EPWM5-EPWM7*/ \
EPwm5Regs.PCCTL.all = PWMDAC_PCCTL_INIT_STATE; \
EPwm6Regs.PCCTL.all = PWMDAC_PCCTL_INIT_STATE; \
EALLOW; /* Enable EALLOW */ \
/* Init Trip Zone Select Register*/ \
EPwm5Regs.TZSEL.all = PWMDAC_TZSEL_INIT_STATE; \
EPwm6Regs.TZSEL.all = PWMDAC_TZSEL_INIT_STATE; \
/* Init Trip Zone Control Register*/ \
EPwm5Regs.TZCTL.all = PWMDAC_TZCTL_INIT_STATE; \
EPwm6Regs.TZCTL.all = PWMDAC_TZCTL_INIT_STATE; \
/* Setting 5A, 6A EPWMs as DAC output pins*/ \
GpioCtrlRegs.GPAMUX1.bit.GPIO8 = 1; /* EPWM5A pin*/ \
GpioCtrlRegs.GPAMUX1.bit.GPIO10 = 1; /* EPWM6A pin*/ \
EDIS; /* Disable EALLOW*/
int32 TmpD;
#define PWMDAC_MACRO(v) \
/* Update Timer-Base period Registers*/ \
/* Compute the compare A (Q0) from the EPWM5 A duty cycle ratio (Q15)*/ \
TmpD = (int32)v.PeriodMax*(int32)(*v.PwmDacInPointer0); /* Q15 = Q0*Q15*/ \
EPwm5Regs.CMPA.half.CMPA = (int16)(TmpD>>16) + (int16)(v.PeriodMax>>1); /* Q0 = (Q15->Q0)/2 + (Q0/2)*/ \
/* Compute the compare A (Q0) from the EPWM6 A duty cycle ratio (Q15)*/ \
TmpD = (int32)v.PeriodMax*(int32)(*v.PwmDacInPointer1); /* Q15 = Q0*Q15*/ \
EPwm6Regs.CMPA.half.CMPA = (int16)(TmpD>>16) + (int16)(v.PeriodMax>>1); /* Q0 = (Q15->Q0)/2 + (Q0/2)*/ \
#endif // __F2833X_PWMDAC_H__
