I'm using a SM320F2808PZMEP processor and usually they work fine. But occasionally I get some that come back as failed and the processors no longer seem to be running the firmware that they were originally programmed with. An obvious sign of this is that it's supposed to blink one of the LEDs and it longer does.
After reprogramming the processor over JTAG, everything seems fine. I'm trying to figure out what could be causing this. Any ideas? Although I'm not running in to this issue that frequently I've probably seen it on about 2-4% of the boards that have been deployed.
I've check the power supplies and everything seems fine, so I'm at a bit of a loss as to what could be causing this. I'm using a power-on reset circuit, although there is nothing to guarantee that it did not see some very frequent power resets due to intermittent connections at some point in its life.
Let me know if I left out any important details.
