How to disable SPI loopback?
Hello forum
I am using a Piccolo F28035 controlcard along with a XDS100 dev board. i am trying to configure a SPI connection.
using the SPI loopback example i have code up running, but now i want to recieve as well.
in the documentation the register SPICCR should contain a bit that controls the loopback (SPILBK), but it says that its a read only? do i need to change it somewhere else or what should i do?
William
  • William,
    It seems you have found a mistake in the documentation! This bit is in fact R/W so you can enable/disable the Loopback in your code.
    I will feed this back to the Documentation team to get it fixed.
    Thanks!
    Mark
