Other Parts Discussed in Thread: CONTROLSUITE
Hi!!!!
I am trying ti run a program from flash memory but nothing work. I have followed all the documentation (spra958l) about the sujet and the result remain the same. When using the F28xx on-chip programmer I get a Halted:S/W Breakpoint. I went to TI wiki to find the solution and follow all the instructions(disable all breaking, uncheck CIO,..), all going always wrong. I am using a experiment's kit delfino F28335. when I close the on chip programmer, I get this:
And if I try to run the program it's also go to breakpoint in the defaut_isr, here is the figure
I have read some forum about this error, and the main is due to a problem from the the flash command file. Here is my flash command file code3124.F28335_nonBIOS_flash.zip
Thanks for your help
Fabrice Jovian
