Hi everybody
I am exploring the functions of the development kit, due to that I am new in this field of communication and the kit.
I have made all the installations that are required, made some minor tests to prove the communication between the modems is done correctly using the zero configuration gui, in other words I am able to exhange messages between them. The problem comes, when I am trying to change from mode, zero configuration to intermediate, it halts and appears a window in which displays an error, stating that the system can not find some specific files.
Details
************* Texto de la excepción **************
System.ComponentModel.Win32Exception: El sistema no puede encontrar el archivo especificado
en System.Diagnostics.Process.StartWithShellExecuteEx(ProcessStartInfo startInfo)
en System.Diagnostics.Process.Start(ProcessStartInfo startInfo)
en System_GUI.Basic.intermediateToolStripMenuItem_Click(Object sender, EventArgs e)
en System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
en System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
en System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
en System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
en System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
en System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
en System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
en System.Windows.Forms.Control.WndProc(Message& m)
en System.Windows.Forms.ToolStrip.WndProc(Message& m)
en System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
en System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
en System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Ensamblados cargados **************
mscorlib
Versión del ensamblado: 2.0.0.0
Versión Win32: 2.0.50727.5477 (Win7SP1GDR.050727-5400)
Código base: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
PLC_Application_Suite
Versión del ensamblado: 2.2.4149.23086
Versión Win32: 2.2.4149.23086
Código base: file:///C:/Program%20Files%20(x86)/Texas%20Instruments/PLC%20Application%20Suite/PLC_Application_Suite.exe
Versión Win32: 2.0.50727.5468 (Win7SP1GDR.050727-5400)
Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Versión Win32: 2.0.50727.5467 (Win7SP1GDR.050727-5400)
Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Application_Suite_Interface_Library
Versión del ensamblado: 1.0.4148.13786
Versión Win32: 1.0.4148.13786
Código base: file:///C:/Program%20Files%20(x86)/Texas%20Instruments/PLC%20Application%20Suite/Application_Suite_Interface_Library.DLL
Dynamic_Forms
Versión del ensamblado: 1.0.4149.23085
Versión Win32: 1.0.4149.23085
Código base: file:///C:/Program%20Files%20(x86)/Texas%20Instruments/PLC%20Application%20Suite/Dynamic_Forms.DLL
GUI_Test_Scripts
Versión del ensamblado: 1.0.4149.23087
Versión Win32: 1.0.4149.23087
Código base: file:///C:/Program%20Files%20(x86)/Texas%20Instruments/PLC%20Application%20Suite/GUI_Test_Scripts.DLL
Scripts
Versión del ensamblado: 1.0.4149.23086
Versión Win32: 1.0.4149.23086
Código base: file:///C:/Program%20Files%20(x86)/Texas%20Instruments/PLC%20Application%20Suite/Scripts.DLL
PLC_Message_Library
Código base: file:///C:/Program%20Files%20(x86)/Texas%20Instruments/PLC%20Application%20Suite/PLC_Message_Library.DLL
PLC_Host_Message_Library
Código base: file:///C:/Program%20Files%20(x86)/Texas%20Instruments/PLC%20Application%20Suite/PLC_Host_Message_Library.DLL
System.Core
Versión del ensamblado: 3.5.0.0
Versión Win32: 3.5.30729.5420 built by: Win7SP1
Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
System_GUI
Código base: file:///C:/Program%20Files%20(x86)/Texas%20Instruments/PLC%20Application%20Suite/System_GUI.DLL
User_Messages
Código base: file:///C:/Program%20Files%20(x86)/Texas%20Instruments/PLC%20Application%20Suite/User_Messages.DLL
User_Scripts
Código base: file:///C:/Program%20Files%20(x86)/Texas%20Instruments/PLC%20Application%20Suite/User_Scripts.DLL
System.Configuration
Versión Win32: 2.0.50727.5476 (Win7SP1GDR.050727-5400)
Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Accessibility
Versión Win32: 2.0.50727.4927 (NetFXspW7.050727-4900)
Código base: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Windows.Forms.resources
Versión Win32: 2.0.50727.5420 (Win7SP1.050727-5400)
Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_es_b77a5c561934e089/System.Windows.Forms.resources.dll
mscorlib.resources
************** Depuración JIT **************
Para habilitar la depuración Just In Time (JIT), el archivo de configuración de esta
aplicación o equipo (machine.config) debe tener el
valor jitDebugging establecido en la sección system.windows.forms.
La aplicación también se debe compilar con la depuración
habilitada
Por ejemplo:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Cuando esté habilitada la depuración JIT, cualquier excepción no controlada
se enviará al depurador JIT registrado en el equipo
en lugar de controlarlo mediante el cuadro de diálogo.
Hope that can help me,
Oscar
