Control suite not updated for c2000 launchpad development kit
Other Parts Discussed in Thread: CONTROLSUITE
Sorry if it is not the right place to post this, I stumbled upon some problems with SCI configuration with ti's api. I finally found out that there was some errors in the api. I was using the development kit's folder, and i saw that for the f2802x there was other versions, and the error is repaired there.
So it would be a good idea to either remove the development kit folder, or update its code to the last version!
and thanks for the great Mcus!
Mathieu Garon
  • Hi Mathieu,
    Which version of controlSuite are you currently using?
    Gautam
    Sorry for the delay, I am using v3.2.7. I use the f2802x_common files. I found some bugs with SCI's driver. If i link with device_support/f2802x/v220 everything seems fine for now. But in development_kits/c2000_LaunchPad there is no version history. And the current file are not the same as v220.
    Unless I misunderstood something.
    Thank You,
    Mathieu
  • Yes, Mathieu I would suggest you to refer peripheral examples from this folder:
    C:\ti\controlSUITE\device_support\f2802x\v220\f2802x_examples_drivers
    That's true! I guess they belong to a different (previous) version.
    Gautam
