Other Parts Discussed in Thread: CONTROLSUITE
I tried to build the Using the Control Law Accelerator (CLA) example based on ert.tlc. The diagnostic viewer ends with the following error message:
"cla_task.cla", line 2: fatal error: cannot open source file "F2806x_Cla_typedefs.h" 1 catastrophic error detected in the compilation of "cla_task.cla". Compilation terminated.
Im using MATLAB 2014a, checkEnvSetup results in:
1. CCSv5 (Code Composer Studio) Your version : 5.5.0 Required version: 5.0 or later Required for : Code Generation TI_DIR="C:\ti\ccsv5"
2. CGT (Texas Instruments C2000 Code Generation Tools) Your version : 6.0.2 Required version: 5.2.1 to 6.0.2 Required for : Code generation C2000_CGT_INSTALLDIR="C:\ti\ccsv5\tools\compiler\c2000_6.0.2"
3. DSP/BIOS (Real Time Operating System) Your version : 5.41.11.38 Required version: 5.33.05 to 5.41.11.38 Required for : Code generation CCSV5_DSPBIOS_INSTALLDIR="C:\ti\bios_5_41_11_38"
4. XDC Tools (eXpress DSP Components) Your version : 3.25.04.88 Required version: 3.16.02.32 or later Required for : Code generation
5. 2806x C/C++ Header Files Your version : 1.20 Required version: 1.20 Required for : Code generation DSP2806x_INSTALLDIR="C:\ti\controlSUITE\device_support\f2806x\v120"
6. Flash Tools (TMS320F2806x Piccolo™ Flash API) Your version : 1.00 Required version: 1.00 Required for : Flash Programming FLASH_2806X_API_INSTALLDIR="C:\ti\controlSUITE\libs\utilities\flash_api\2806x\v100"
The installed version of controlSUITE is v3.2.7.
I inspected the folder C:\ti\controlSUITE\device_support\f2806x\v120\F2806x_common\include and discovered, that there is no file named F2806x_Cla_typedefs.h. Can i copy one of the newer versions to this folder or is there another solution?
Thanks and best regards
Daniel Probst
