data lost at SPI receiver side with "polling" mechanism
Hi All:
I am coding the communication between 2 DSPs through SPI. The start code is quite simple, DSP-1 is sending and DSP-2 is receiving (Of course, DSP-1 also receives but I don't care so far, vice versa for DSP-2)
That works fine. One thousand 16bit data were sent and received correctly.
However, when I add an random delay in DSP-1(master) side, I found DSP-2 begin to lost some data. It is confusing me that I didn't change anything at DSP-2 side for receiving and I am polling quite often.
So anyidea why the delay on sender's side might affect the receiver? (I double checked the DSP1 did send correct sequence.)
And I am thinking to convert to interrupt mechanism, will that solve this kind of issue for all?
my DSP2's polling code is:
for(;;)  //my main program for receving
  spi_xmit(data);  //For sending, not care so far
  while(SpiaRegs.SPIFFRX.bit.RXFFST == 0) {} //polling
  while(SpiaRegs.SPIFFRX.bit.RXFFST != 0)
    rdata[seq] = SpiaRegs.SPIRXBUF;
    seq++;
  if(seq>1000) break;
Other configuration for SPI is:
void spi_init()
	SpiaRegs.SPICCR.all =0x000F;	             // Reset on, rising edge, 16-bit char bits
	SpiaRegs.SPICTL.all =0x0002;    		     // Enable slave mode, normal phase,
                                                 // enable talk, and SPI int disabled.
	SpiaRegs.SPIBRR =0x0003;
    SpiaRegs.SPICCR.all =0x008F;		         // Relinquish SPI from Reset
    SpiaRegs.SPIPRI.bit.FREE = 1;                // Set so breakpoints don't disturb xmission
void spi_xmit(Uint16 a)
    SpiaRegs.SPITXBUF=a;
void spi_fifo_init()
// Initialize SPI FIFO registers
    SpiaRegs.SPIFFTX.all=0xE040;
    SpiaRegs.SPIFFRX.all=0x2044;
    SpiaRegs.SPIFFCT.all=0x0;
  • Lebing,
    I have run your code on the bench. I am unfortunately unable to replicate your results. Interrupts may be something to try. If anything it may just mask the issue, and we will never know what the root cause is.
    What do you mean when you say the data is not received correctly?
    Are you missing data (i.e. expected: 0x1234, 0xFEDC, 0x5678, 0xBA98, actual: 0x1234, 0x5678, 0xBA98)?
    Is the data jumbled and not received properly (i.e. expected: 0x1234, actual: 0x087B)?
    Can you tell me what frequencies of SYSCLK and LSPCLK on the slave side. What about the master's frequency? what is the device you are receiving data from?
    I hope we are able to find the cause,
    Mark
  • Hi Mark,
    Thank you for your reply. I'm sorry for a late reply. I solved this question by increasing the transmission speed.
