Can I simulate my program with .hex file in CCS4.0?
Other Parts Discussed in Thread: TMS320F28027
The .out file    can run success, while the hex file coming from the same source code  faile.
should I   configure  the CCS4.0   to BOOT MODE   ?
there are the steps  as follow during simulation
step1, I  loaded the dcdc.hex file dowm to  MCU TMS320F28027 using sofware C2Prog.exe .
step 2,    open CCS4.0  --> press  launch TI debugger button---> Connect Target
step 3,   after connecting the Target ,I can see the assembly code in the  disassembly window
step 4,  Set  BOOT_MODE_FLASH
step5,   Reset CPU
step6   press F6
then  I  falled  in a trap  0x3FF7E7:   6F00        SB         0,UNC
could  anybody tell me the reason?
