Other Parts Discussed in Thread: TMS320F28335
Dear All,
I am developing an ECAN application using TMS320F28335. Development environment is CCSv3.3.
During project build process following build error is encountered:
"DSP2833x_GlobalVariableDefs.c", line 26: error: variable "AdcRegs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 34: error: variable "AdcMirror" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 42: error: variable "CpuTimer0Regs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 50: error: variable "CpuTimer1Regs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 59: error: variable "CpuTimer2Regs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 86: error: variable "DevEmuRegs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 94: error: variable "DmaRegs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 186: error: variable "EPwm1Regs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 195: error: variable "EPwm2Regs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 203: error: variable "EPwm3Regs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 211: error: variable "EPwm4Regs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 219: error: variable "EPwm5Regs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 227: error: variable "EPwm6Regs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 236: error: variable "ECap1Regs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 245: error: variable "ECap2Regs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 253: error: variable "ECap3Regs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 261: error: variable "ECap4Regs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 269: error: variable "ECap5Regs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 277: error: variable "ECap6Regs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 285: error: variable "EQep1Regs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 293: error: variable "EQep2Regs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 325: error: variable "I2caRegs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 333: error: variable "McbspaRegs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 341: error: variable "McbspbRegs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 349: error: variable "PartIdRegs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 373: error: variable "SciaRegs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 381: error: variable "ScibRegs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 389: error: variable "ScicRegs" was declared with a never-completed type
"DSP2833x_GlobalVariableDefs.c", line 398: error: variable "SpiaRegs" was declared with a never-completed type
29 errors detected in the compilation of "DSP2833x_GlobalVariableDefs.c".
>> Compilation failure
Could anybody suggest a solution to the problem ?
Thank you,
Sunil Sawant
