Dear all,
I'm using an absolute encoder to measure the electric angle of my rotor with InstaSPIN motion. From my understanding, during RsRecalc estimation the rotor should be locked in the zero position of the electric angle, so that the measured encoder angle should always be consistent (assuming that I'm measuring the electric angle, and not the physical rotor position). However, I'm not seeing a consistent angle every time that I run RsRecalc. Actually I'm getting quite different results, varying from 140 degrees to 280 degrees. I measured the current during the RsRecalc across my three phases, and I'm seeing current in all of my coils.
Shouldn't I only be observing current from one (reference) phase to the other during RsRecalc? Do you have any suggestions as to why I'm seeing so much variability when locking the rotor position with RsRecalc?
Thank you in advance for your support.
Chris
