Use oscilloscope to check PWM outputs
I am begginer with DSP and I'm working in the project at the university .I'm working on the  control of  BLDC motor,and i'm using Texas Instrument's High Voltage Digital Motor Control Kit v1.7 and Code compose studio V6...
I use literature that i found at the Texas Instruments site... and i found Incremental system build for Sensored BLDC Project ,which build up system step by step.
At this moment I´m using the first level which describes the steps for a minimum system check-out which confirms operation of system interrupts, some peripheral & target independent modules  and one peripheral dependent module.
One of the steps you need to do in the first level is check the PWM outputs controlled by the peripheral dependent  module-BLDC_3PWM_DRV.The point is that I wanna see the result calculated by the algorithms in one oscilloscope.
I don't know  how to connect oscilloscope to check the PWM outputs ?Which pins with inverter should I connect with oscilloscope?
Do you have any Idea, or documentation that could give me any direction?
