Other Parts Discussed in Thread: TMS320F28335, CONTROLSUITE
how to resolve following error?
After i did some changes to "LED Blink example" of F28335 and tried to debug, it is giving following error.
and now it is not accepting original example code also.
aC28xx: Flash Programmer: Warning: The configured device (TMS320F28335), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
C28xx: Failed CPU Reset: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.507.0)
C28xx: Trouble Reading Register PC: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.507.0)
C28xx: Trouble Reading Register ST1: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.507.0)
C28xx: GEL: Error while executing OnReset(1): Target failed to read register ST1 at (ST1&~(0x0100)) [f28335.gel:312] at C28x_Mode() [f28335.gel:38] at OnReset(1) .
C28xx: Trouble Writing Memory Block at 0x9000 on Page 0 of Length 0xd80: (Error -1137 @ 0x9002) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.1.507.0)
C28xx: GEL: File: F:\Ashish\ccs\a1\Debug\a1.out: Load failed.C28xx: Flash Programmer: Warning: The configured device (TMS320F28335), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
