Other Parts Discussed in Thread: TMS320F28027
I am using TMS320F28027 DSC. I am using ADCINT1, ADCINT2, SCI RX INT & SCI TX INT.
The ADCINT1 trigger at EPWM1A PRD & ADCINT2 trigger at EPWM1B ZERO. In both ADCINT what I found is ADCINTOVF flag set for multiple times. The implementation is as follows
if(1 == AdcRegs.ADCINTOVF.bit.ADCINT1)
AdcRegs.ADCINTOVFCLR.bit.ADCINT1 = 1;
adc_isr1_overflow_cntr++;
if(TRUE == AdcRegs.ADCINTOVF.bit.ADCINT2)
AdcRegs.ADCINTOVFCLR.bit.ADCINT2 = 1;
adc_isr2_overflow_cntr++;
I check this implementation in main loop at the rate of 3mili second.
And I check adc_isr1_overflow_cntr & adc_isr2_overflow_cntr on MODBUS communication where I found these counters are incrementing.
So my doubt is:
- what will happen if i does't clear ADCINTOVF bit .
- In my implementation if these overflow_cntr continuously increased what could be impact on ADCINT
Well i've checked both cases but didn't found anything problematic at all. But I am curious to know about impact of this ADCINTOVF flag on ADCINT generation and the usage of this ADCINTOVF .
