I believe I bricked my F28069 Launchpad. Are there any program files available that can unbrick my device?
I'm not exactly sure but I was trying to power the board with a Lithium Ion battery and the battery is not actually 3.3V. It's more like 4V. I also was trying to communicate over the USB to UART line.
So did you check what all components have been damaged by doing so?
Check the mcu's health first! So did you give Li-ion battery directly to 3.3V pin & GND?
Andrew,
I took a look at the electricals for that device and it looks like it should be able to handle up to 4.6V, so I'm not sure why the board isn't working with your battery.
When you've tested it since, has it been powered by the battery or USB? You may want to try using USB power if you haven't yet.
BR,
