multichanel RTDX reading in Matlab
Can anybody help to us with rebuilding this MATLAB script for twou channel rtdx monitoring.? Please because we can t move with that.
function varargout = Sensing_analog(varargin)
% SENSING_ANALOG MATLAB code for Sensing_analog.fig
%      SENSING_ANALOG, by itself, creates a new SENSING_ANALOG or raises the existing
%      singleton*.
%      H = SENSING_ANALOG returns the handle to a new SENSING_ANALOG or the handle to
%      the existing singleton*.
%      SENSING_ANALOG('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in SENSING_ANALOG.M with the given input arguments.
%      SENSING_ANALOG('Property','Value',...) creates a new SENSING_ANALOG or raises the
%      existing singleton*.  Starting from the left, property value pairs are
%      applied to the GUI before Sensing_analog_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to Sensing_analog_OpeningFcn via varargin.
%      *See GUI Options on GUIDE's Tools menu.  Choose "GUI allows only one
%      instance to run (singleton)".
% See also: GUIDE, GUIDATA, GUIHANDLES
% Edit the above text to modify the response to help Sensing_analog
% Last Modified by GUIDE v2.5 06-Feb-2014 15:26:15
% Begin initialization code - DO NOT EDIT
gui_Singleton = 1;
gui_State = struct('gui_Name',       mfilename, ...
                   'gui_Singleton',  gui_Singleton, ...
                   'gui_OpeningFcn', @Sensing_analog_OpeningFcn, ...
                   'gui_OutputFcn',  @Sensing_analog_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
if nargin && ischar(varargin{1})
    gui_State.gui_Callback = str2func(varargin{1});
end
if nargout
    [varargout{1:nargout}] = gui_mainfcn(gui_State, varargin{:});
else
end
% End initialization code - DO NOT EDIT
% --- Executes just before Sensing_analog is made visible.
function Sensing_analog_OpeningFcn(hObject, eventdata, handles, varargin)
% This function has no output args, see OutputFcn.
% hObject    handle to figure
% eventdata  reserved - to be defined in a future version of MATLAB
% handles    structure with handles and user data (see GUIDATA)
% varargin   command line arguments to Sensing_analog (see VARARGIN)
% Choose default command line output for Sensing_analog
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes Sensing_analog wait for user response (see UIRESUME)
% uiwait(handles.figure1);
% Initializing output plot settings %
set(handles.figure1,'visible','off')
axes(handles.axes1);
set(handles.axes1,'xlim',[0 100]);
set(handles.axes1,'ylim',[9206670 13812986]);
set(handles.axes1,'xlimmode','manual');
set(handles.axes1,'ylimmode','manual');
set(handles.axes1,'layer','bottom');
set(handles.axes1,'nextplot','add');
xlabel('X');
ylabel('Y');
% Plot some dummny data first to get axis handles %
allNaN = NaN*ones(1,100);
plot(allNaN);
handles.h1 = line('parent',handles.axes1);
% Initializing CCS settings %
global cc;
cc=ticcs;
configure(cc.rtdx,1024,4);
open(cc.rtdx,'ochan1','r');
open(cc.rtdx,'ochan2','r');
enable(cc.rtdx,'ochan1');
enable(cc.rtdx,'ochan2');
enable(cc.rtdx);
cc.rtdx
% Read data from Target Board, and plot them on the axes1 %
frameSize = 1;
xlimit = 100;
NumOfFrames = xlimit/frameSize;
yLines = handles.h1;
set(handles.figure1,'visible','on');
r = cc.rtdx;
while(isenabled(cc.rtdx))
    set(yLines,'ydata', allNaN,'xdata', [1:xlimit]);
    pause(1e-2); % must be the same as sample time
    for k = 1:NumOfFrames
        if ~ishandle(yLines)
            return;
        end
        yAll = get(yLines,'ydata');
        x = (k-1)*frameSize+1;
        y = (k-1)*frameSize+frameSize;
        % Read Data from the Target through RTDX %
        numMsgs = r.msgcount('ochan1');
        if(numMsgs > 0),
            if(numMsgs > 1),
                r.flush('ochan1',numMsgs-1);
            end
            yAll(x:y) = readmsg(cc.rtdx,'ochan1','single');
            set(handles.edit1,'String',num2str(yAll(y)))
        end
        set(yLines,'ydata',yAll,'xdata',[1:xlimit]);
    end
end
% --- Outputs from this function are returned to the command line.
function varargout = Sensing_analog_OutputFcn(hObject, eventdata, handles)
% varargout  cell array for returning output args (see VARARGOUT);
% Get default command line output from handles structure
% --- Executes on button press in Run.
function Run_Callback(hObject, eventdata, handles)
% hObject    handle to Run (see GCBO)
global cc;
run(cc);
% --- Executes on button press in Halt.
function Halt_Callback(hObject, eventdata, handles)
% hObject    handle to Halt (see GCBO)
global cc;
halt(cc);
function edit1_Callback(hObject, eventdata, handles)
% hObject    handle to edit1 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit1 as text
%        str2double(get(hObject,'String')) returns contents of edit1 as a double
% --- Executes during object creation, after setting all properties.
function edit1_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
