Interrup Time @ tms320f28335
Other Parts Discussed in Thread: TMS320F28335
Hi Together,
does somebody know how long the tms320f28335 needs to jump into an interrupt and back to the program at a frequence of 150Mhz - and: are there any options to optimate this time ?
Regards Heiko
    Heiko,
    Please see the Interrupt Response and Latency information in section 4 of the 2833x multi-day workshp material:
    http://processors.wiki.ti.com/index.php/C2000_Archived_Workshops
    -Lori
  • Heiko,
    the interrupt latency (time between signal and 1st instruction of the corresponding ISR) is 14 to 16 cycles ( 6.667 ns). If you write your ISR in C, the compiler will place some additional register savings (approx. 6 cylcles) at the beginning of the ISR.  To return from an ISR, the assembly instruction" IRET" takes 7 cycles and in case of a C-code the ISR context restore will take some additional 6 cycles.
    Summary: To jump in and out of an ISR takes approx. 35 cycles. The only solution which I know of to minimize these cycles is to write the ISR purely in assembly (the hard way)
