configuration needed to run "usb_host_msc" example on 28377D Experimenters Kit
Other Parts Discussed in Thread: TMS320F28377D
Hi All,
I am using TMS320F28377D DELFINO CONTROL CARD. I need to interface pen drive. So i refereed sample code from folder named "usb_host_msc". simply i have connected pen drive with OTG cable on USB micro-B connector. And i connected mini-B connector to PC through virtual serial port(By using emulator section and changing switch position on Experimenters kit).
Does i need any changes on firmware to get response on serial port?
Does i need any changes on experimental kit to get response on serial port excluding A:SW1 switch position?
I did not get any data on serial port. but if i put UARTprintf  function in while then i am getting continuously garbage value on serial port. I have also set recommended setting(Baud rate, parity, etc.) for virtual serial port on Hyper Terminal.
In debug mode, i am getting: Can't find a source file at "C:/repositories/cs30_f2837x/F28X7x_common/usblib/host/usbhostenum.c"
My code is running from CPU1 FLASH.
Thanks and Regards,
Maulik Timbadiya
