Other Parts Discussed in Thread: CONTROLSUITE
I am in phase set using different module of EPWM, “EPwm4” set “up_down” EPwm4Regs.TBPHS.half.TBPHS = (AlgorithmReg.PwmReg.LLC_PwmPeriod_Pre > 1); / / Phase is 90 degrees, the theory can be phase shifted 90 degrees, in the actual waveform test phase shift 107 degrees left and right, need -20 to get a 90 degree phase shift, can help find why? Thank you
Configuration code is as follows:
#define BUCK_PWM_PERIOD (562) //Set PWM period =(90Mhz/80KHz)/2
#define LLC_PWM_PERIOD_80KHZ (562) //Set PWM period =(90Mhz/80KHz)/2
#define LLC_PWM_PERIOD_200KHZ (225) //Set PWM period =(90Mhz/200KHz)/2
void InitEPwm1(void)
* 1.0 Setup Time-Base(TB)
// Setup TBCLK
EPwm1Regs.TBPRD = BUCK_PWM_PERIOD; // Set timer period period
EPwm1Regs.TBPHS.half.TBPHS = 0x0000; // Phase is 0
EPwm1Regs.TBCTR = 0x0000; // Clear counter
// Set Compare values
EPwm1Regs.CMPA.half.CMPA = BUCK_PWM_PERIOD;// Set compare A value
EPwm1Regs.CMPB = 0; // Set compare B value
// Setup counter mode
EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up and down
EPwm1Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading
EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_DISABLE; // SYNC_DISABLE
EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1; // TBCLK = SYSCLKOUT / (HSPCLKDIV × CLKDIV) = SYSCLKOUT
* 2.0 Setup Counter Compare(CC)
// Setup shadowing (CC)
EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Shadow mode.
EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // Load on Zero
EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
* 3.0 Setup Action Qualifier(AQ)
// Set actions (AQ)
EPwm1Regs.AQCTLA.bit.CAU = AQ_SET; // Set PWM1A on event A, up count
EPwm1Regs.AQCTLA.bit.CAD = AQ_CLEAR; // Clear PWM1A on event A, down count
EPwm1Regs.AQCTLB.bit.CBU = AQ_CLEAR ; // Clear PWM1B on event B, up count
EPwm1Regs.AQCTLB.bit.CBD = AQ_SET; // Set PWM1B on event B, down count
* 4.0 Setup Dead Band(DB)
EPwm1Regs.DBCTL.bit.IN_MODE = DBA_RED_DBB_FED; // EPWMxA In (from the action-qualifier) is the source for rising-edge delayed signal.
// EPWMxB In (from the action-qualifier) is the source for falling-edge delayed signal.
EPwm1Regs.DBCTL.bit.POLSEL = DB_ACTV_HI; // Active high (AH) mode. Neither EPWMxA nor EPWMxB is inverted (default).
EPwm1Regs.DBCTL.bit.OUT_MODE = DB_DISABLE; // Dead-band generation is bypassed for both output signals.
EPwm1Regs.DBRED = 45; // 500ns,not active
EPwm1Regs.DBFED = 45; // 500ns,not active
* 5.0 Setup PWM-Chopper (PC)
EPwm1Regs.PCCTL.bit.CHPEN = 0; // Disable (bypass) PWM chopping function
* 6.0 Digital Compare (DC)
/* 比较器过流保护关驱动操作 */
/* TZDCSEL\DCTRIPSEL\DCACTL\DCBCTL\DCFCTL\DCCAPCTL寄存器受保护 */
/* 必须开启. */
EALLOW;
// Define an event (DCAEVT1) as OSHT to lock PWM
EPwm1Regs.DCTRIPSEL.bit.DCAHCOMPSEL = DC_COMP1OUT; /* DCAH = Comparator 1 output */
EPwm1Regs.TZDCSEL.bit.DCAEVT1 = TZ_DCAH_HI; /* DCAEVT1 = DCAH low(will become active as Comparator output goes high)*/
EPwm1Regs.DCACTL.bit.EVT1SRCSEL = DC_EVT1; /* DCAEVT1 = DCAEVT1 (not filtered) */
EPwm1Regs.DCACTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC; /* Take async path */
EPwm1Regs.DCTRIPSEL.bit.DCBHCOMPSEL = DC_COMP1OUT;
EPwm1Regs.TZDCSEL.bit.DCBEVT1 = TZ_DCBH_HI;
EPwm1Regs.DCBCTL.bit.EVT1SRCSEL = DC_EVT1;
EPwm1Regs.DCBCTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC;
EDIS;
* 7.0 Trip Zone(TZ)
/* TZSEL/TZCTL/TZEINT/TZCLR/TZFRC/HRCNFG are EALLOW-protected registers */
// Enable DCAEVT1 and DCBEVT1 are one shot trip sources
// Note: DCxEVT1 events can be defined as one-shot.
// DCxEVT2 events can be defined as cycle-by-cycle.
EALLOW;
EPwm1Regs.TZSEL.bit.DCAEVT1 = 1; /* Enable DCAEVT1 as one-shot-trip source for this ePWM module.*/
EPwm1Regs.TZSEL.bit.DCBEVT1 = 1; /* Enable DCBEVT1 as one-shot-trip source for this ePWM module.*/
// DCAEVTx events can force EPWMxA
// DCBEVTx events can force EPWMxB
EPwm1Regs.TZCTL.bit.TZA = TZ_FORCE_LO; // 本项目使用软件出发TZ,EPWM1A will go low
EPwm1Regs.TZCTL.bit.TZB = TZ_FORCE_LO; // 本项目使用软件出发TZ,EPWM1B will go low
EPwm1Regs.TZCTL.bit.DCAEVT1 = TZ_FORCE_LO;
EPwm1Regs.TZCTL.bit.DCBEVT1 = TZ_FORCE_LO;
EDIS;
* 8.0 Event Trigger and Interrupt(ET)
// SOC
EPwm1Regs.ETSEL.bit.SOCAEN = 1; // 使能EPWMxSOCA;
EPwm1Regs.ETSEL.bit.SOCASEL = ET_CTR_PRD; // TBCTR=TBTRD,时触发SOCA;
EPwm1Regs.ETPS.bit.SOCAPRD = ET_1ST; // Generate the EPWMxSOCA pulse on the first event
EPwm1Regs.ETSEL.bit.SOCBEN = 1; // 使能EPWMxSOCB;
EPwm1Regs.ETSEL.bit.SOCBSEL = ET_CTR_PRD; // TBCTR=TBTRD,时触发SOCB;
EPwm1Regs.ETPS.bit.SOCBPRD = ET_1ST; // Generate the EPWMxSOCB pulse on the first event
// Interrupt
EPwm1Regs.ETSEL.bit.INTSEL = ET_CTR_ZERO; // Select INT on Zero event
EPwm1Regs.ETSEL.bit.INTEN = 1; // 使能Enable INT,外设级中断允许
EPwm1Regs.ETPS.bit.INTPRD = ET_1ST; // Generate an interrupt on the first event
* Function: InitEPwm2()
* Description: Initializes the EPwm2 module on the F2806x.
* 将PWM2A与PWM2B配置成互补驱动,以PWM1A为信号源
* 上升沿死区:500ns
* 下降沿死区:500ns
void InitEPwm2(void)
// Setup TBCLK
EPwm2Regs.TBPRD = LLC_PWM_PERIOD_200KHZ; // Set timer period period
EPwm2Regs.TBPHS.half.TBPHS = 0x0000; // Phase is 0
EPwm2Regs.TBCTR = 0x0000; // Clear counter
EPwm2Regs.CMPA.half.CMPA = LLC_PWM_PERIOD_200KHZ;// Set compare A value
EPwm2Regs.CMPB = 0; // Set compare B value
EPwm2Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up and down
EPwm2Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading
EPwm2Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO; // CTR = zero时输出同步信号,EPWM2同步用
EPwm2Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm2Regs.TBCTL.bit.CLKDIV = TB_DIV1; // TBCLK = SYSCLKOUT / (HSPCLKDIV × CLKDIV) = SYSCLKOUT
EPwm2Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Shadow mode.
EPwm2Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm2Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // Load on Zero
EPwm2Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
// Set actions (AQ)
EPwm2Regs.AQCTLA.bit.CAU = AQ_SET; // Set PWM1A on event A, up count
EPwm2Regs.AQCTLA.bit.CAD = AQ_CLEAR; // Clear PWM1A on event A, down count
EPwm2Regs.AQCTLB.bit.CBU = AQ_CLEAR ; // Clear PWM1B on event B, up count
EPwm2Regs.AQCTLB.bit.CBD = AQ_SET; // Set PWM1B on event B, down count
EPwm2Regs.DBCTL.bit.IN_MODE = DBA_ALL; // EPWMxA In (from the action-qualifier) is the source for both falling-edge and rising-edge delay.
EPwm2Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC; // Active high (AH) mode. Neither EPWMxA nor EPWMxB is inverted (default).
EPwm2Regs.DBCTL.bit.OUT_MODE = DB_DISABLE;//DB_FULL_ENABLE; // Dead-band generation is bypassed for both output signals.
EPwm2Regs.DBRED = 45; // Rising-edge delay 500ns is active.
EPwm2Regs.DBFED = 45; // Fising-edge delay 500ns is active.
EPwm2Regs.PCCTL.bit.CHPEN = 0; // Disable (bypass) PWM chopping function
/* 比较器过流保护关驱动操作 */
/* 必须开启. */
EALLOW;
EPwm2Regs.DCTRIPSEL.bit.DCAHCOMPSEL = DC_COMP1OUT; /* DCAH = Comparator 1 output */
EPwm2Regs.TZDCSEL.bit.DCAEVT1 = TZ_DCAH_HI; /* DCAEVT1 = DCAH low(will become active as Comparator output goes high)*/
EPwm2Regs.DCACTL.bit.EVT1SRCSEL = DC_EVT1; /* DCAEVT1 = DCAEVT1 (not filtered) */
EPwm2Regs.DCACTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC; /* Take async path */
EPwm2Regs.DCTRIPSEL.bit.DCBHCOMPSEL = DC_COMP1OUT;
EPwm2Regs.TZDCSEL.bit.DCBEVT1 = TZ_DCBH_HI;
EPwm2Regs.DCBCTL.bit.EVT1SRCSEL = DC_EVT1;
EPwm2Regs.DCBCTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC;
EDIS;
* 7.0 Trip Zone(TZ)
EALLOW;
EPwm2Regs.TZSEL.bit.DCAEVT1 = 1; /* Enable DCAEVT1 as one-shot-trip source for this ePWM module.*/
EPwm2Regs.TZSEL.bit.DCBEVT1 = 1; /* Enable DCBEVT1 as one-shot-trip source for this ePWM module.*/
EPwm2Regs.TZCTL.bit.TZA = TZ_FORCE_LO; // 本项目使用软件出发TZ,EPWM1A will go low
EPwm2Regs.TZCTL.bit.TZB = TZ_FORCE_LO; // 本项目使用软件出发TZ,EPWM1B will go low
EPwm2Regs.TZCTL.bit.DCAEVT1 = TZ_FORCE_LO;
EPwm2Regs.TZCTL.bit.DCBEVT1 = TZ_FORCE_LO;
EDIS;
// SOC
//None
// Interrupt
EPwm2Regs.ETSEL.bit.INTSEL = ET_DCAEVT1SOC; // Select INT on Zero event
EPwm2Regs.ETSEL.bit.INTEN = 0; // Disable INT, 外设级中断允许
EPwm2Regs.ETPS.bit.INTPRD = ET_DISABLE; // Generate an interrupt on the first event
* Function: InitEPwm3()
* Description: Initializes the EPwm3 module on the F2806x.
* 上升沿死区:500ns
* 下降沿死区:500ns
void InitEPwm3(void)
// Setup TBCLK
EPwm3Regs.TBPRD = LLC_PWM_PERIOD_200KHZ; // Set timer period period
EPwm3Regs.TBPHS.half.TBPHS = 0x0000; // Phase is 0
EPwm3Regs.TBCTR = 0x0000; // Clear counter
EPwm3Regs.CMPA.half.CMPA = LLC_PWM_PERIOD_200KHZ; // Set compare A value
EPwm3Regs.CMPB = 0; // Set compare B value
EPwm3Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up and down
EPwm3Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Disable phase loading
EPwm3Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;//TB_CTR_ZERO; // CTR = zero时输出同步信号,EPWM2同步用
EPwm3Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm3Regs.TBCTL.bit.CLKDIV = TB_DIV1; // TBCLK = SYSCLKOUT / (HSPCLKDIV × CLKDIV) = SYSCLKOUT
EPwm3Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Shadow mode.
EPwm3Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm3Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // Load on Zero
EPwm3Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
// Set actions (AQ)
* 变压器需要取反,2015.12.01
EPwm3Regs.AQCTLA.bit.CAU = AQ_SET; // Set PWM1A on event A, up count
EPwm3Regs.AQCTLA.bit.CAD = AQ_CLEAR; // Clear PWM1A on event A, down count
EPwm3Regs.AQCTLB.bit.CBU = AQ_CLEAR; // Clear PWM1B on event B, up count
EPwm3Regs.AQCTLB.bit.CBD = AQ_SET; // Set PWM1B on event B, down count
EPwm3Regs.AQCTLA.bit.CBU = AQ_CLEAR; // Set PWM1A on event A, up count
EPwm3Regs.AQCTLA.bit.CBD = AQ_SET; // Clear PWM1A on event A, down count
EPwm3Regs.AQCTLB.bit.CAU = AQ_SET; // Clear PWM1B on event B, up count
EPwm3Regs.AQCTLB.bit.CAD = AQ_CLEAR; // Set PWM1B on event B, down count
EPwm3Regs.DBCTL.bit.IN_MODE = DBA_ALL; // EPWMxA In (from the action-qualifier) is the source for both falling-edge and rising-edge delay.
EPwm3Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC; // Active high (AH) mode. Neither EPWMxA nor EPWMxB is inverted (default).
EPwm3Regs.DBCTL.bit.OUT_MODE = DB_DISABLE; // Dead-band generation is bypassed for both output signals.
EPwm3Regs.DBRED = 45; // Rising-edge delay 500ns is active.
EPwm3Regs.DBFED = 45; // Fising-edge delay 500ns is active.
EPwm3Regs.PCCTL.bit.CHPEN = 0; // Disable (bypass) PWM chopping function
/* 比较器过流保护关驱动操作 */
/* 必须开启. */
EALLOW;
EPwm3Regs.DCTRIPSEL.bit.DCAHCOMPSEL = DC_COMP1OUT; /* DCAH = Comparator 1 output */
EPwm3Regs.TZDCSEL.bit.DCAEVT1 = TZ_DCAH_HI; /* DCAEVT1 = DCAH low(will become active as Comparator output goes high)*/
EPwm3Regs.DCACTL.bit.EVT1SRCSEL = DC_EVT1; /* DCAEVT1 = DCAEVT1 (not filtered) */
EPwm3Regs.DCACTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC; /* Take async path */
EPwm3Regs.DCTRIPSEL.bit.DCBHCOMPSEL = DC_COMP1OUT;
EPwm3Regs.TZDCSEL.bit.DCBEVT1 = TZ_DCBH_HI;
EPwm3Regs.DCBCTL.bit.EVT1SRCSEL = DC_EVT1;
EPwm3Regs.DCBCTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC;
EDIS;
* 7.0 Trip Zone(TZ)
EALLOW;
EPwm3Regs.TZSEL.bit.DCAEVT1 = 1; /* Enable DCAEVT1 as one-shot-trip source for this ePWM module.*/
EPwm3Regs.TZSEL.bit.DCBEVT1 = 1; /* Enable DCBEVT1 as one-shot-trip source for this ePWM module.*/
EPwm3Regs.TZCTL.bit.TZA = TZ_FORCE_LO; // 本项目使用软件出发TZ,EPWM1A will go low
EPwm3Regs.TZCTL.bit.TZB = TZ_FORCE_LO; // 本项目使用软件出发TZ,EPWM1B will go low
EPwm3Regs.TZCTL.bit.DCAEVT1 = TZ_FORCE_LO;
EPwm3Regs.TZCTL.bit.DCBEVT1 = TZ_FORCE_LO;
EDIS;
// SOC
//None
// Interrupt
EPwm3Regs.ETSEL.bit.INTSEL = ET_DCAEVT1SOC; // Select INT on Zero event
EPwm3Regs.ETSEL.bit.INTEN = 0; // Disable INT, 外设级中断允许
EPwm3Regs.ETPS.bit.INTPRD = ET_DISABLE; // Generate an interrupt on the first event
* Function: InitEPwm4()
* Description: Initializes the EPwm4 module on the F2806x.
* 与EPwm1,EPwm4移向90度,
* 将PWM4A与PWM4B配置成互补驱动,以PWM4A为信号源
* 上升沿死区:500ns
* 下降沿死区:500ns
void InitEPwm4(void)
// Setup TBCLK
EPwm4Regs.TBPRD = LLC_PWM_PERIOD_200KHZ; // Set timer period period
EPwm4Regs.TBPHS.half.TBPHS = (LLC_PWM_PERIOD_200KHZ >> 1);// Phase is 90°
EPwm4Regs.TBCTR = 0x0000; // Clear counter
EPwm4Regs.CMPA.half.CMPA = LLC_PWM_PERIOD_200KHZ; // Set compare A value
EPwm4Regs.CMPB = 0; // Set compare B value
EPwm4Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up and down
EPwm4Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Phase loading
EPwm4Regs.TBCTL.bit.PHSDIR = TB_DOWN; // Count DOWN on sync (=90 deg)
EPwm4Regs.TBCTL.bit.PRDLD = TB_SHADOW; // The period register (TBPRD) is loaded from its shadow register
// when the time-base counter,TBCTR, is equal to zero.
EPwm4Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN; // CTR = zero时输出同步信号,EPWM2同步用
EPwm4Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm4Regs.TBCTL.bit.CLKDIV = TB_DIV1; // TBCLK = SYSCLKOUT / (HSPCLKDIV × CLKDIV) = SYSCLKOUT
EPwm4Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Shadow mode.
EPwm4Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm4Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // Load on Zero
EPwm4Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
// Set actions (AQ)
EPwm4Regs.AQCTLA.bit.CAU = AQ_SET; // Set PWM1A on event A, up count
EPwm4Regs.AQCTLA.bit.CAD = AQ_CLEAR; // Clear PWM1A on event A, down count
EPwm4Regs.AQCTLB.bit.CBU = AQ_CLEAR ; // Clear PWM1B on event B, up count
EPwm4Regs.AQCTLB.bit.CBD = AQ_SET; // Set PWM1B on event B, down count
EPwm4Regs.DBCTL.bit.IN_MODE = DBA_ALL; // EPWMxA In (from the action-qualifier) is the source for both falling-edge and rising-edge delay.
EPwm4Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC; // Active high (AH) mode. Neither EPWMxA nor EPWMxB is inverted (default).
EPwm4Regs.DBCTL.bit.OUT_MODE = DB_DISABLE; // Dead-band generation is bypassed for both output signals.
EPwm4Regs.DBRED = 45; // 500ns,not active
EPwm4Regs.DBFED = 45; // 500ns,not active
EPwm4Regs.PCCTL.bit.CHPEN = 0; // Disable (bypass) PWM chopping function
/* 比较器过流保护关驱动操作 */
/* 必须开启. */
EALLOW;
EPwm4Regs.DCTRIPSEL.bit.DCAHCOMPSEL = DC_COMP1OUT; /* DCAH = Comparator 1 output */
EPwm4Regs.TZDCSEL.bit.DCAEVT1 = TZ_DCAH_HI; /* DCAEVT1 = DCAH low(will become active as Comparator output goes high)*/
EPwm4Regs.DCACTL.bit.EVT1SRCSEL = DC_EVT1; /* DCAEVT1 = DCAEVT1 (not filtered) */
EPwm4Regs.DCACTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC; /* Take async path */
EPwm4Regs.DCTRIPSEL.bit.DCBHCOMPSEL = DC_COMP1OUT;
EPwm4Regs.TZDCSEL.bit.DCBEVT1 = TZ_DCBH_HI;
EPwm4Regs.DCBCTL.bit.EVT1SRCSEL = DC_EVT1;
EPwm4Regs.DCBCTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC;
EDIS;
* 7.0 Trip Zone(TZ)
EALLOW;
EPwm4Regs.TZSEL.bit.DCAEVT1 = 1; /* Enable DCAEVT1 as one-shot-trip source for this ePWM module.*/
EPwm4Regs.TZSEL.bit.DCBEVT1 = 1; /* Enable DCBEVT1 as one-shot-trip source for this ePWM module.*/
EPwm4Regs.TZCTL.bit.TZA = TZ_FORCE_LO; // 本项目使用软件出发TZ,EPWM1A will go low
EPwm4Regs.TZCTL.bit.TZB = TZ_FORCE_LO; // 本项目使用软件出发TZ,EPWM1B will go low
EPwm4Regs.TZCTL.bit.DCAEVT1 = TZ_FORCE_LO;
EPwm4Regs.TZCTL.bit.DCBEVT1 = TZ_FORCE_LO;
EDIS;
// SOC
EPwm4Regs.ETSEL.bit.SOCBEN = 1; // 使能EPWMxSOCB;
EPwm4Regs.ETSEL.bit.SOCBSEL = ET_CTR_PRD; // TBCTR=TBTRD,时触发SOCB;
EPwm4Regs.ETPS.bit.SOCBPRD = ET_1ST; // Generate the EPWMxSOCA pulse on the first event
// Interrupt
EPwm4Regs.ETSEL.bit.INTSEL = ET_DCAEVT1SOC; // Select INT on Zero event
EPwm4Regs.ETSEL.bit.INTEN = 0; // Disable INT, 外设级中断允许
EPwm4Regs.ETPS.bit.INTPRD = ET_DISABLE; // Generate an interrupt on the first event
* Function: InitEPwm5()
* 与EPwm4,EPwm5同相,都与EPwm1移向90度,
* 将PWM5A与PWM5B配置成互补驱动,以PWM5A为信号源
* 上升沿死区:500ns
* 下降沿死区:500ns
void InitEPwm5(void)
// Setup TBCLK
EPwm5Regs.TBPRD = LLC_PWM_PERIOD_200KHZ; // Set timer period period
EPwm5Regs.TBPHS.half.TBPHS = (LLC_PWM_PERIOD_200KHZ >> 1);// Phase is 90
EPwm5Regs.TBCTR = 0x0000; // Clear counter
EPwm5Regs.CMPA.half.CMPA = LLC_PWM_PERIOD_200KHZ; // Set compare A value
EPwm5Regs.CMPB = 0; // Set compare B value
EPwm5Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Count up and down
EPwm5Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Enable phase loading
EPwm5Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN; // sync flow-through
EPwm5Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm5Regs.TBCTL.bit.CLKDIV = TB_DIV1; // TBCLK = SYSCLKOUT / (HSPCLKDIV × CLKDIV) = SYSCLKOUT
EPwm5Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Shadow mode.
EPwm5Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm5Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // Load on Zero
EPwm5Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
// Set actions (AQ)
EPwm5Regs.AQCTLA.bit.CAU = AQ_SET; // Set PWM1A on event A, up count
EPwm5Regs.AQCTLA.bit.CAD = AQ_CLEAR; // Clear PWM1A on event A, down count
EPwm5Regs.AQCTLB.bit.CBU = AQ_CLEAR ; // Clear PWM1B on event B, up count
EPwm5Regs.AQCTLB.bit.CBD = AQ_SET; // Set PWM1B on event B, down count
EPwm5Regs.AQCTLA.bit.CBU = AQ_CLEAR; // Set PWM1A on event A, up count
EPwm5Regs.AQCTLA.bit.CBD = AQ_SET; // Clear PWM1A on event A, down count
EPwm5Regs.AQCTLB.bit.CAU = AQ_SET ; // Clear PWM1B on event B, up count
EPwm5Regs.AQCTLB.bit.CAD = AQ_CLEAR; // Set PWM1B on event B, down count
EPwm5Regs.DBCTL.bit.IN_MODE = DBA_ALL; // EPWMxA In (from the action-qualifier) is the source for both falling-edge and rising-edge delay.
EPwm5Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC; // Active high (AH) mode. Neither EPWMxA nor EPWMxB is inverted (default).
EPwm5Regs.DBCTL.bit.OUT_MODE = DB_DISABLE; // Dead-band generation is bypassed for both output signals.
EPwm5Regs.DBRED = 45; // 500ns,not active
EPwm5Regs.DBFED = 45; // 500ns,not active
EPwm5Regs.PCCTL.bit.CHPEN = 0; // Disable (bypass) PWM chopping function
/* 比较器过流保护关驱动操作 */
/* 必须开启. */
EALLOW;
EPwm5Regs.DCTRIPSEL.bit.DCAHCOMPSEL = DC_COMP1OUT; /* DCAH = Comparator 1 output */
EPwm5Regs.TZDCSEL.bit.DCAEVT1 = TZ_DCAH_HI; /* DCAEVT1 = DCAH low(will become active as Comparator output goes high)*/
EPwm5Regs.DCACTL.bit.EVT1SRCSEL = DC_EVT1; /* DCAEVT1 = DCAEVT1 (not filtered) */
EPwm5Regs.DCACTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC; /* Take async path */
EPwm5Regs.DCTRIPSEL.bit.DCBHCOMPSEL = DC_COMP1OUT;
EPwm5Regs.TZDCSEL.bit.DCBEVT1 = TZ_DCBH_HI;
EPwm5Regs.DCBCTL.bit.EVT1SRCSEL = DC_EVT1;
EPwm5Regs.DCBCTL.bit.EVT1FRCSYNCSEL = DC_EVT_ASYNC;
EDIS;
* 7.0 Trip Zone(TZ)
EALLOW;
EPwm5Regs.TZSEL.bit.DCAEVT1 = 1; /* Enable DCAEVT1 as one-shot-trip source for this ePWM module.*/
EPwm5Regs.TZSEL.bit.DCBEVT1 = 1; /* Enable DCBEVT1 as one-shot-trip source for this ePWM module.*/
EPwm5Regs.TZCTL.bit.TZA = TZ_FORCE_LO; // 本项目使用软件出发TZ,EPWM1A will go low
EPwm5Regs.TZCTL.bit.TZB = TZ_FORCE_LO; // 本项目使用软件出发TZ,EPWM1B will go low
EPwm5Regs.TZCTL.bit.DCAEVT1 = TZ_FORCE_LO;
EPwm5Regs.TZCTL.bit.DCBEVT1 = TZ_FORCE_LO;
EDIS;
// SOC
// EPwm5Regs.ETSEL.bit.SOCBEN = 1; // 使能EPWMxSOCB;
// EPwm5Regs.ETSEL.bit.SOCBSEL = ET_CTR_PRD; // TBCTR=TBTRD,时触发SOCB;
// EPwm5Regs.ETPS.bit.SOCBPRD = ET_1ST; // Generate the EPWMxSOCA pulse on the first event
// Interrupt
EPwm5Regs.ETSEL.bit.INTSEL = ET_DCAEVT1SOC; // Select INT on Zero event
EPwm5Regs.ETSEL.bit.INTEN = 0; // Disable INT, 外设级中断允许
EPwm5Regs.ETPS.bit.INTPRD = ET_DISABLE; // Generate an interrupt on the first event
