THE GPIO input issue for TMS320F28027
Dear,
The GPIO 12 pin is connected to pushbotton switch with resistor in series and then conected to ground
I had configured GPIO12 as input pin with internal pull up.
Moreover, it is configured for external interrupt from high to low trnasistion.
However, when I the switch is closed  the waveform at GPIO pin is indicating negative 2.4 volt to 1.64 volt pulse of duration 200 msec each side. i.e 2.4 msec last for 200 msec and 1.64Volt drops down to 0.8volt within 200 msec
Question.
1. Why there is negative trnasition to -2.4 Volt
2. Wont it dmagae my mircontroller as each pin is configured to withstand upto -0.3 volt only.
3. Why positive voltage trnasition is 1.64 volt only.
Enclosed is the drawing
waeform and circuit drawing.pdf
  • Hi Ashutosh,
    There's something wrong in your hardware configuration. It should not go down to negative voltage at all.
    Check your hardware
    Offcourse this negative voltage will damge the GPIO!
    Again, check your hardware.
    Gautam
