Errors with .obj
I am getting these errors though the required header files are included. Any other file required to include?
Description Resource Path Location Type
#10010 errors encountered during linking; "test20.out" not built test20 C/C++ Problem
#10056 symbol "_apf" redefined: first defined in "./deltF.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_closeIt" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_de" redefined: first defined in "./deltF.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_deltCoarse" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_deltFine" redefined: first defined in "./deltF.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_EdgeLogic" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_Floor" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_fpDiff" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_fpJk" redefined: first defined in "./deltF.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_fpJk360" redefined: first defined in "./deltF.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_fpKmax" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_fpSweep" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_fpUpDn" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_fpwin" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_fpWin" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_getD" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_getDetWin" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_locateEdges" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_main" redefined: first defined in "./main.obj"; redefined in "./win32Adam8in.obj" test20 C/C++ Problem
#10056 symbol "_myJK" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_myLog" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_normalize" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_ObjC" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_ObjNew" redefined: first defined in "./deltF.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_OnlyTwo" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_r2Deg" redefined: first defined in "./deltF.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_rdot2bk" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_shift" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_twoDtkt" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_Usage" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
#10056 symbol "_yk2bk" redefined: first defined in "./deltc8in.obj"; redefined in "./main.obj" test20 C/C++ Problem
<a href="file:/c:/ti/ccsv6/tools/compiler/dmed/HTML/10234.html">#10234-D</a> unresolved symbols remain test20 C/C++ Problem
unresolved symbol _energy, first referenced in ./deltc8in.obj test20 C/C++ Problem
unresolved symbol _fopen_s, first referenced in ./deltF.obj test20 C/C++ Problem
unresolved symbol _fscanf_s, first referenced in ./deltc8in.obj test20 C/C++ Problem
unresolved symbol _skanX, first referenced in ./deltc8in.obj test20 C/C++ Problem
unresolved symbol _sprintf_s, first referenced in ./main.obj test20 C/C++ Problem
unresolved symbol _strcat_s, first referenced in ./deltc8in.obj test20 C/C++ Problem
unresolved symbol _strcpy_s, first referenced in ./deltc8in.obj test20 C/C++ Problem
Pooja
