Hi I am using TILaunchpad F28069M for spinning PMSM. I want to use eQEP pulses for speed and position feedback. How to find position offset for index pulse for 4 pole machine
Hello Aishwarya,
I understand that you are looking for a phasing method, is that right? Are you familiar with things like electrical angle and mechanical angle?
Janos
Hi Janos
I am aware of concept of electrical zero and mechanical zero. I am having 4 pole machine means it is having 2 electrical zeros and one mechanical zero. My question was there is some time lapse between electrical zero of machine and index pulse arriving and when you are giving position feedback this difference is required to be offset. How to calculate this offset.
After reset, let's say that the position is zero, the mechanical angle is zero and the electrical angle is assumed zero. You need to manually rotate the motor by slowly rotating the electrical angle until you find the index pulse from the encoder. Detailed steps below.
BR,
Janos
