Hello, I am looking at the schematics for the F28035 control card. Can anyone explain the purpose of the parallel L/C on the VSSA / ADCGnd pin?
I'm not sure I follow that. Seems like the capacitor would provide a high frequency path between the analog and digital grounds. Is it maybe some kind of resonant trap to block noise from a particular clock or switching converter on that board?
Could it just be an error? Like maybe the capacitor was supposed to bypass VDDA to VSSA?
Hi Mark,
This is a situation that started off as an experiment, but stayed in the design.
The bead shouldn't do much in the VSSA path - as you've mentioned high-frequency noise can come in through the capacitor and any low-frequency parts will flow in through the bead.
I would recommend not placing this particular ferrite bead in your design (largely just because of the unnecessary extra BOM cost).
Thank you,
Brett
