Other Parts Discussed in Thread: TMS320F28335
Hello, I have a very similar error.
About the first error line. I'm sure my controler is a TMS320F28335.
The programme was working fine but when i was measuring a signal on the electronic card, a tiny electric arc happen and now i cannot load the program anymore, and this error very similar have happen.
What can i do to solve this problem ?
C28xx: Error connecting to the target: (Error -183 @ 0x0) The controller has detected a cable break far-from itself. The user must connect the cable/pod to the target. (Emulation package 5.0.777.0)
C28xx: Flash Programmer: Warning: The configured device (TMS320F28335), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
C28xx: Failed CPU Reset: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.777.0)
C28xx: Trouble Reading Register PC: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.777.0)
C28xx: Trouble Reading Register ST1: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.777.0)
C28xx: GEL: Error while executing OnReset(1): Target failed to read register ST1 at (ST1&~(0x0100)) [f28335.gel:312] at C28x_Mode() [f28335.gel:38] at OnReset(1) .
C28xx: Trouble Writing Memory Block at 0x0 on Page 0 of Length 0x2: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 5.0.777.0)
C28xx: GEL: File: C:\Users\admin\Documents\1 - Heig-vd\Code Composer\Test\cleopatreII\Release\cleopatreII.out: Load failed.
