Other Parts Discussed in Thread: CONTROLSUITE
How can I configure the ePWM to implement a peak current mode controller into a phase shifted full-bridge DC-DC converter?
As far as I know ePWM module itself doesn't have any specific feature to implement peak current mode algorithm however the latest Piccolo devices may have analog modules to implement peak current mode typ eof algorithms. Have you checked out the latest Piccolo family devices?
Thank you,
Piccolo B has three analog comparator, and using the comparator output, it's possible to set PWM off by Trip-Zone, but it can not affect Compare-Logic and Action-Qualifier in ePWM module.
is it possible to change TBPHS using output of analog comparator?
any suggestion about this problem?
I am using a 28069 and I need to perform a phase-shift control in peak current mode.
I can use the CBC trip generated by the current comparator.
Once the interrupt is generated, how to manage TBPHS register?
Michi
Michi,
I would recommend taking a look at the software (and documentation) for the TMDSHVPSFBKIT. This should help you to get some idea of how TI has implemented phase-shifting via CBC trips in a peak-current mode design.
In controlSUITE it can be found at the following:
\controlSUITE\development_kits\HVPSFB_v1.1\
Thank you,
Brett
