2407A ADC not working
Other Parts Discussed in Thread: TMS320LF2407A
I have been using a modified version of the FFT library c program for the 2407A and all has been working well up till today. Today when I sampled the signal with the 2407A I only get 0s. I did not change any code and my signal that I am transmitting looks normal.  I have tried transmitting a pure tone and sampling it, the 2407A still gives me 0 for all samples. The actual chip feels very hot to the touch even when the program has been halted, I do not remember if this is normal or not.
I have tried to change the channel that the ADC uses, but I do not get any different results. Does this sound like the ADC has malfunctioned? Are there any other debugging techniques that I should try? I am using the TMS320LF2407A Evaluation model.
Thanks!
  • Maybe you've touched the a/d ports with your fingers and the static electricity damaged the periferic. It happened to my dsp teacher.
    One question: ¿Where did you get the fft library and how did you use it? (Thanks)
