Has TI given any document to give scaling factors of the various ACTUAL motor/drive parameters like motor current, motor speed, motor inductance, resistance etc. with 32bit value represented inside dsp?
For serial transmission of data, I wanted to check if all parameters can be fitted in 16bit, so amount of data transfer will reduce, so I was trying to see - how these parameters are defined so that I can find a best way to fit them in 16bits. Unfortunately, they all do not seem to be in IQ24 format, (For example, terminal voltage & speed do not seem to be in IQ24 format). So I wanted to know if TI has any document defining the same...
