SFRA tool general question
Other Parts Discussed in Thread: SFRA, CONTROLSUITE
Hello all,
I am quite new with CCS and I have a DSP 28377D;  I wanted to test the SFRA tool.
Do I need to create a new project to run the SFRA and copy and paste into my new project the lines of code given in "spruhz5a"? Or can I just copy and paste the code given in "spruhz5a" into my main.c?? Does someone have any example on SFRA on 28377D?
Thanks for your help,
Leo
  • Recommend the following projects for more easy understanding,
    the SFRA lib shoudl work if you use the instructions from the manual as well.
    C:\ti\controlSUITE\development_kits\BOOSTXL_BUCKCONV\v1_01_00_00\Buck_VMC_F2837xS
    C:\ti\controlSUITE\development_kits\HV_1PH_DCAC\v1_02_00_00\f2837x\voltagesourceinvlcfltr
  • Thanks Manish and e2e,
    I am quite new with CCS and I still need some help, in order to measure tho open loop gain of my power stage. If I understand correctly the spruhz5a, pag.19,  the function
    SFRA_F_INJECT(Duty_pu_DC)
    needs to go inside my pwm interrupt.. it that correct? But what is Duty_pu_DC? Is it the amplitude of the small signal injected? So then, can I use SFRA_F_INJECT(0.1)? for instance?
    Also, I don't understand how these two commands work:
    //Update PWM value
    EPwm1Regs.CMPA.half.CMPA=((long)(BUCK_PWM_PERIOD))* Duty_pu;
    SFRA_F_COLLECT(&Duty_pu,&Vout1_Read);
    what are the variables BUCK_PWM_PERIOD, Duty_pu? and what does EPwm1Regs.CMPA.half mean?
    Thank you very much again,
    Leo
