Other Parts Discussed in Thread: CONTROLSUITE
hi
i am using the Eqep configuration as in the IDDK_PM_Servo_F2837x example.
when i use the encoder in very slow speeds every things seems to work fine , but as soon i little bit higher the rpm i see big errors in the QPOSCNT counter .
maybe i didnt configured the model properly?
what is effecting the QPOSCNT updating? , i have looked in the datasheet many times and i cant fully understand the eqep functionality , the QDU unit reads the A, B signals and generates QCLK signal to the position counter, does the position counter unit also responsible for updating QPOSCNT?
if i set the QDECCTL register properly , which else configuration can effect the QPOSCNT?
any suggestion please?
best regards
Mark
