How to run the proj_lab11d on the LAUNCHXL-F28069M and two BOOSTXL-DRV8305EVMs?
Other Parts Discussed in Thread: MOTORWARE
Hello, everyone. I'm a beginner user of the Motorware.
I could run some examples, such as proj_lab02b, proj_lab03a.
I tried to use the proj_lab11d and GUI Composer, but every buttons of GUI Composer are disabled.
I could not found for lab11d or dual-motor examples for lab11d or dual-motor examples on any notes of TI Motorware and devices.
How can I use the proj_lab11d example?
  • proj_lab11# use a different structure of variables than the others, so the GUI doesn't work with them. You will need to import the proj_lab11#.js and use the expressions view.
    there is also not a write-up for all of the projects.
    the next version of MotorWare will have some new write-ups, and we are also releasing a proj_lab10d, which uses the previous structure for 2 motor. This lab will have a write-up, but the GUI still won't work (it's not set-up for the dual motor variables)
