To interface sd card with the TMS320f28f377 d experimenter kit and copy file from usb to sd card and vice versa.
Other Parts Discussed in Thread: TMS320F28377D, CONTROLSUITE
hi guys.
I want to copy files from usb to sd card and vice versa using the tms320f28377d control card
    I'd recommend downloading controlSUITE and then taking a look at the following two examples.  They can likely be used as a good starting point for your project:
    \controlSUITE\device_support\F2837xD\v200\F2837xD_examples_Cpu1\usb_dev_serial\
    \controlSUITE\device_support\F2837xD\v200\F2837xD_examples_Cpu1\sd_card\
    Hopefully this helps.  Good luck in your project!
    Thank you,
    Brett
