Other Parts Discussed in Thread: TMS320F28035
My kit was burned dowm ,the Customer service said i must first contact TI via E2E forum at
http://e2e.ti.com/ to verify the failure
TI’s C2000 Piccolo™ TMS320F28035 microcontroller (MCU).:Solar Micro Inverter Development Board
What build level were you on when this happened?
Did you connect both the power supplies to the board? one for the isolated flyback side and other for the inverter side?
Based on the description above you did not follow the instructions where it is clearly listed not to connect any input voltage before you load code into the controller.
hence I would suggest you make arrangements to repair the board yourself as it was not operated per the user guide.
However i will be interested to know what exactly you did wrong to ensure you don;t face the same issue after the repair.
I follow the instruction to connect all the power supplies in the kit.I hope you can help me to test the kit if there are ather elements damaged which i do not know,and fix it.thank you very much
