Part Number: TMDSSOLARPEXPKIT
I used the PVGUI with the Quick Start Guide and it works perfectly.
I modified the PV_Table1.asm in order to change the emulator parameters for an application and I've been trying to compile the "SolarExplorer_PVEmulator_F2802x" project and it does it.
The problem is that i can make it work. There is not a value on the V-pv pins
Do you know which parameters have i to change to emulate the radiation in the code?
is that the way i should change the PV emulator parameters?
Thank You
