TMS320F28035: Negative Slope Compensation
Part Number: TMS320F28035
Dear All,
For my application, I have to use slope compensation but the slope should not be downwards. Is there any way to make the slope upwards? Or just assigning a negative value to slope is enough for it?
I would be appreciated if someone help me about this.
Thank you in advanced.
Merih
  • Merih,
    The ramp generator only decrements. There is no way to program a negative number to make it increment.
    If you are not using the CLA, you might be able to program it to increment the DAC value for you in the background.
    -Tommy
  • Tommy,
    Thank your for the reply.
    My questions are below:
    - Is the decrementing operation compiler dependent?
    - If this operation is a compiler dependent, is there any chance to change compiler options?
    - If there is a chance to do this, how can I change the compiler options?
    Merih
  • Merih,
    The ramp generator is implemented with a hardware state-machine. There is no way to change its behavior beyond the configuration registers.
    -Tommy
