CCS/TMS320F28377S: Error related with 'InitPieCtrl();' and 'InitPieVectTable();'
Part Number: TMS320F28377S
I am using ccs v7.0.0.
If i used 'InitPieCtrl();' and 'InitPieVectTable();' function.
CCS happen error.
error:
C28xx_CPU1: GEL: Encountered a problem loading file: C:\Users\HJH\workspace_v7\F2837xS_1\Debug\F2837xS_1.out Could not open file
Help me.
    I'm guessing your project isn't compiling correctly, so there's no .out being generated. When you build the project, are you getting any error messages from the compiler or linker?
    Whitney
  • Description Resource Path Location Type
    #10010 errors encountered during linking; "F2837xS_1.out" not built F2837xS_1 C/C++ Problem
    <a href="processors.wiki.ti.com/.../10234">
    #10234-D</a> unresolved symbols remain F2837xS_1 C/C++ Problem
    gmake: *** [all] Error 2 F2837xS_1 C/C++ Problem
    gmake[1]: *** [F2837xS_1.out] Error 1 F2837xS_1 C/C++ Problem
    unresolved symbol _ADCA_EVT_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ADCA1_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ADCA2_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ADCA3_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ADCA4_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ADCB_EVT_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ADCB1_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ADCB2_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ADCB3_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ADCB4_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ADCC_EVT_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ADCC1_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ADCC2_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ADCC3_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ADCC4_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ADCD_EVT_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ADCD1_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ADCD2_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ADCD3_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ADCD4_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _AUX_PLL_SLIP_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _CANA0_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _CANA1_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _CANB0_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _CANB1_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _CLA_OVERFLOW_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _CLA_UNDERFLOW_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _CLA1_1_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _CLA1_2_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _CLA1_3_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _CLA1_4_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _CLA1_5_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _CLA1_6_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _CLA1_7_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _CLA1_8_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _DATALOG_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _DMA_CH1_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _DMA_CH2_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _DMA_CH3_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _DMA_CH4_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _DMA_CH5_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _DMA_CH6_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ECAP1_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ECAP2_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ECAP3_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ECAP4_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ECAP5_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ECAP6_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EMIF_ERROR_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EMU_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM1_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM1_TZ_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM10_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM10_TZ_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM11_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM11_TZ_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM12_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM12_TZ_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM2_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM2_TZ_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM3_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM3_TZ_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM4_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM4_TZ_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM5_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM5_TZ_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM6_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM6_TZ_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM7_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM7_TZ_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM8_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM8_TZ_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM9_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EPWM9_TZ_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EQEP1_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EQEP2_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _EQEP3_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _FLASH_CORRECTABLE_ERROR_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _FPU_OVERFLOW_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _FPU_UNDERFLOW_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _I2CA_FIFO_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _I2CA_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _I2CB_FIFO_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _I2CB_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _ILLEGAL_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _IPC0_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _IPC1_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _IPC2_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _IPC3_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _MCBSPA_RX_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _MCBSPA_TX_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _MCBSPB_RX_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _MCBSPB_TX_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _NMI_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _PIE_RESERVED_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _RAM_ACCESS_VIOLATION_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _RAM_CORRECTABLE_ERROR_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _RTOS_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _SCIA_RX_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _SCIA_TX_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _SCIB_RX_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _SCIB_TX_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _SCIC_RX_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _SCIC_TX_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _SCID_RX_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _SCID_TX_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _SD1_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _SD2_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _SPIA_RX_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _SPIA_TX_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _SPIB_RX_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _SPIB_TX_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _SPIC_RX_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _SPIC_TX_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _SYS_PLL_SLIP_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _TIMER0_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _TIMER1_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _TIMER2_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _UPPA_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _USBA_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _USER1_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _USER10_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _USER11_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _USER12_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _USER2_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _USER3_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _USER4_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _USER5_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _USER6_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _USER7_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _USER8_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _USER9_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _VCU_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _WAKE_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _XINT1_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _XINT2_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _XINT3_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _XINT4_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    unresolved symbol _XINT5_ISR, first referenced in ./F2837xS_PieVect.obj F2837xS_1 C/C++ Problem
    Above error message is given to me.
    After i added 'F2837xS_PieCtrl.c' and 'F2837xS_PieVect.c' File.
    Help me
    #10063-D entry-point symbol other than "_c_int00" specified: "code_start" F2837xS_1 C/C++ Problem
    #10210-D creating ".stack" section with default size of 0x400; use the -stack option to change the default size F2837xS_1 C/C++ Problem
    Above message is 'warning'.
  • I resolved.
    Thank you.
  • Hi H-san,
    I meet similar errors on my project.
    Could you please explain how to solve it?
    Takano
    If you're still having trouble solving the errors, go ahead and create a new thread on the forum with the details and we'll assign someone to help you.
    Whitney
  • Hi Whitney-san,
    Thanks for your kindness, currently I solved.
    Takano
