Would you have a product that will perform the folowing functions ?
Richard Pearl – www.banjomobile.com
I am looking for a High Quality MP3 Music Player module that will fit the following Specs. There is no FM or record function necessary!!!
- Large numbered display to indicate song playing – user should be able to search for the selection by number.
- Play music recorded in MP3 WAV WMV formats from USB and SD cards
- Playback music in a high quality 24 bit Stereo format
- Player should be controllable with outboard (foot) switches
- Play switch to toggle from play to pause.
- Stop switch to stop player at any time.
- Select Up Switch - to advance to next selection one at a time or rapidly when held down.
- Select Down Switch - to display previous selection one at a time or rapidly when held down.
- Rotary Encoder (Speed Knob) to rapidly change selections to be played
- Volume up Switch.
- Volume down Switch
- EQ Switch
- Repeat Switch
- IMPORTANT – The unit should be user programmable so that when the selection playing finishes, the player automatically advances to the next song and is ready for playback. However, it does not play until the Play switch is pushed by the user.
