Part Number: LAUNCHXL-F28377S
I need to program the F28377S to PWM from 10kHz to 1MHz. Is that possible? Any help would be greatly appreciated. Thank you!
Hi Mike,
Michael Philips said:I need to program the F28377S to PWM from 10kHz to 1MHz. Is that possible? Any help would be greatly appreciated. Thank you
Yes you can very well achieve the above range using F28377S. Do go through the TRM of this device to verify the same.
Gautam
