I am new to the FOC-algorithm and have some questions regarding use of it. I have read through the Spraa 588 Application report, and the motor used in the example is a Star-connected motor (and all other application reports I have found on the web).
The motor I am using is a delta connected motor (PMSM), I assume the FOC-algorithm uses the phase current in the calculations? Do I need to correct for this when using a Delta motor? Is it other correction needed when using a delta motor?
BR/ Jorgen
