Part Number: LAUNCHXL-F28069M
Hi everyone,
I'm trying to make a home function based on proj_lab13f,so i wrote the code for that in proj_lab13f.c file, there are no problems with the compilation but the program does nothing.
This is part of the code, i also add the file.
#include <math.h>
#include "main_position_2mtr.h"
/*--------- INICIO Headers y variables globales ----*/
interrupt void QEP_Index_ISR(void);
short gIndexOcurre = 0;
#include "spa_c.h"
double azi = 0, zen = 0;
spa_data spa; //declare the SPA structure
int result;
float min, sec;
int f_err = 0;
char *azi_zeni;
double angAz, angZen;
double ang_azi_Actual = 0;
double ang_zen_Actual = 0;
double ang_azi_establecer = 0;
double ang_zen_establecer = 0;
double ang_azi_mrev = 0.0; //_iq24
double ang_zen_mrev = 0.0;
double late = 20.6242738798, lon = -100.3663814068, ele = 1829;
/*--------- FIN Headers y variables globales ----*/
#ifdef FLASH
#pragma CODE_SECTION(motor1_ISR,"ramfuncs");
#pragma CODE_SECTION(motor2_ISR,"ramfuncs");
#endif
// Include header files used in the main function
// the defines
// the globals
CLARKE_Handle clarkeHandle_I[2]; //!< the handle for the current Clarke
//!< transform
CLARKE_Obj clarke_I[2]; //!< the current Clarke transform object
PARK_Handle parkHandle[2]; //!< the handle for the current Parke
//!< transform
PARK_Obj park[2]; //!< the current Parke transform object
CLARKE_Handle clarkeHandle_V[2]; //!< the handle for the voltage Clarke
//!< transform
CLARKE_Obj clarke_V[2]; //!< the voltage Clarke transform object
EST_Handle estHandle[2]; //!< the handle for the estimator
PID_Obj pid[2][3]; //!< three objects for PID controllers
//!< 0 - Speed, 1 - Id, 2 - Iq
PID_Handle pidHandle[2][3]; //!< three handles for PID controllers
uint16_t stCntPosition[2]; //!< count variable to decimate the execution
//!< of SpinTAC Position Control
IPARK_Handle iparkHandle[2]; //!< the handle for the inverse Park
//!< transform
IPARK_Obj ipark[2]; //!< the inverse Park transform object
SVGEN_Handle svgenHandle[2]; //!< the handle for the space vector generator
SVGEN_Obj svgen[2]; //!< the space vector generator object
ENC_Handle encHandle[2]; //!< the handle for the encoder
ENC_Obj enc[2]; //!< the encoder object
SLIP_Handle slipHandle[2]; //!< the handle for the slip compensator
SLIP_Obj slip[2]; //!< the slip compensator object
HAL_Handle halHandle; //!< the handle for the hardware abstraction
//!< layer for common CPU setup
HAL_Obj hal; //!< the hardware abstraction layer object
ANGLE_COMP_Handle angleCompHandle[2]; //!< the handle for the angle compensation
ANGLE_COMP_Obj angleComp[2]; //!< the angle compensation object
HAL_Handle_mtr halHandleMtr[2]; //!< the handle for the hardware abstraction
//!< layer specific to the motor board.
HAL_Obj_mtr halMtr[2]; //!< the hardware abstraction layer object
//!< specific to the motor board.
HAL_PwmData_t gPwmData[2] = {{_IQ(0.0),_IQ(0.0),_IQ(0.0)}, //!< contains the
{_IQ(0.0),_IQ(0.0),_IQ(0.0)}}; //!< pwm values for each phase.
//!< -1.0 is 0%, 1.0 is 100%
HAL_AdcData_t gAdcData[2]; //!< contains three current values, three
//!< voltage values and one DC buss value
MATH_vec3 gOffsets_I_pu[2] = {{_IQ(0.0),_IQ(0.0),_IQ(0.0)}, //!< contains
{_IQ(0.0),_IQ(0.0),_IQ(0.0)}}; //!< the offsets for the current feedback
MATH_vec3 gOffsets_V_pu[2] = {{_IQ(0.0),_IQ(0.0),_IQ(0.0)}, //!< contains
{_IQ(0.0),_IQ(0.0),_IQ(0.0)}}; //!< the offsets for the voltage feedback
MATH_vec2 gIdq_ref_pu[2] = {{_IQ(0.0),_IQ(0.0)}, //!< contains the Id and
{_IQ(0.0),_IQ(0.0)}}; //!< Iq references
MATH_vec2 gVdq_out_pu[2] = {{_IQ(0.0),_IQ(0.0)}, //!< contains the output
{_IQ(0.0),_IQ(0.0)}}; //!< Vd and Vq from the current controllers
MATH_vec2 gIdq_pu[2] = {{_IQ(0.0),_IQ(0.0)}, //!< contains the Id and Iq
{_IQ(0.0),_IQ(0.0)}}; //!< measured values
FILTER_FO_Handle filterHandle[2][6]; //!< the handles for the 3-current and 3-voltage filters for offset calculation
FILTER_FO_Obj filter[2][6]; //!< the 3-current and 3-voltage filters for offset calculation
uint32_t gOffsetCalcCount[2] = {0,0};
USER_Params gUserParams[2];
uint32_t gAlignCount[2] = {0,0};
ST_Obj st_obj[2]; //!< the SpinTAC objects
ST_Handle stHandle[2]; //!< the handles for the SpinTAC objects
volatile MOTOR_Vars_t gMotorVars[2] = {MOTOR_Vars_INIT_Mtr1,MOTOR_Vars_INIT_Mtr2}; //!< the global motor
//!< variables that are defined in main.h and
//!< used for display in the debugger's watch
//!< window
#ifdef FLASH
// Used for running BackGround in flash, and ISR in RAM
extern uint16_t *RamfuncsLoadStart, *RamfuncsLoadEnd, *RamfuncsRunStart;
#endif
#ifdef DRV8301_SPI
// Watch window interface to the 8301 SPI
DRV_SPI_8301_Vars_t gDrvSpi8301Vars[2];
#endif
#ifdef DRV8305_SPI
// Watch window interface to the 8305 SPI
DRV_SPI_8305_Vars_t gDrvSpi8305Vars[2];
#endif
_iq gFlux_pu_to_Wb_sf[2];
_iq gFlux_pu_to_VpHz_sf[2];
_iq gTorque_Ls_Id_Iq_pu_to_Nm_sf[2];
_iq gTorque_Flux_Iq_pu_to_Nm_sf[2];
_iq gSpeed_krpm_to_pu_sf[2];
_iq gSpeed_pu_to_krpm_sf[2];
_iq gSpeed_hz_to_krpm_sf[2];
_iq gCurrent_A_to_pu_sf[2];
// the functions
void main(void)
// Only used if running from FLASH
// Note that the variable FLASH is defined by the project
#ifdef FLASH
// Copy time critical code and Flash setup code to RAM
// The RamfuncsLoadStart, RamfuncsLoadEnd, and RamfuncsRunStart
// symbols are created by the linker. Refer to the linker files.
memCopy((uint16_t *)&RamfuncsLoadStart,(uint16_t *)&RamfuncsLoadEnd,
(uint16_t *)&RamfuncsRunStart);
#endif
// initialize the Hardware Abstraction Layer (HAL)
// halHandle will be used throughout the code to interface with the HAL
// (set parameters, get and set functions, etc) halHandle is required since
// this is how all objects are interfaced, and it allows interface with
// multiple objects by simply passing a different handle. The use of
// handles is explained in this document:
// C:/ti/motorware/motorware_1_01_00_1x/docs/motorware_coding_standards.pdf
halHandle = HAL_init(&hal,sizeof(hal));
// initialize the user parameters
// This function initializes all values of structure gUserParams with
// values defined in user.h. The values in gUserParams will be then used by
// the hardware abstraction layer (HAL) to configure peripherals such as
// PWM, ADC, interrupts, etc.
USER_setParamsMtr1(&gUserParams[HAL_MTR1]);
USER_setParamsMtr2(&gUserParams[HAL_MTR2]);
// set the hardware abstraction layer parameters
// This function initializes all peripherals through a Hardware Abstraction
// Layer (HAL). It uses all values stored in gUserParams.
HAL_setParams(halHandle,&gUserParams[HAL_MTR1]);
// initialize the estimator
estHandle[HAL_MTR1] = EST_init((void *)USER_EST_HANDLE_ADDRESS,0x200);
estHandle[HAL_MTR2] = EST_init((void *)USER_EST_HANDLE_ADDRESS_1,0x200);
uint_least8_t mtrNum;
for(mtrNum=HAL_MTR1;mtrNum<=HAL_MTR2;mtrNum++)
// initialize the individual motor hal files
halHandleMtr[mtrNum] = HAL_init_mtr(&halMtr[mtrNum],sizeof(halMtr[mtrNum]),(HAL_MtrSelect_e)mtrNum);
// Setup each motor board to its specific setting
HAL_setParamsMtr(halHandleMtr[mtrNum],halHandle,&gUserParams[mtrNum]);
// These function calls are used to initialize the estimator with ROM
// function calls. It needs the specific address where the controller
// object is declared by the ROM code.
CTRL_Handle ctrlHandle = CTRL_init((void *)USER_CTRL_HANDLE_ADDRESS,0x200);
CTRL_Obj *obj = (CTRL_Obj *)ctrlHandle;
// this sets the estimator handle (part of the controller object) to
// the same value initialized above by the EST_init() function call.
// This is done so the next function implemented in ROM, can
// successfully initialize the estimator as part of the controller
// object.
obj->estHandle = estHandle[mtrNum];
// initialize the estimator through the controller. These three
// function calls are needed for the F2806xF/M implementation of
// InstaSPIN.
CTRL_setParams(ctrlHandle,&gUserParams[mtrNum]);
CTRL_setUserMotorParams(ctrlHandle);
CTRL_setupEstIdleState(ctrlHandle);
//Compensates for the delay introduced
//from the time when the system inputs are sampled to when the PWM
//voltages are applied to the motor windings.
angleCompHandle[mtrNum] = ANGLE_COMP_init(&angleComp[mtrNum],sizeof(angleComp[mtrNum]));
ANGLE_COMP_setParams(angleCompHandle[mtrNum],
gUserParams[mtrNum].iqFullScaleFreq_Hz,
gUserParams[mtrNum].pwmPeriod_usec,
gUserParams[mtrNum].numPwmTicksPerIsrTick);
// initialize the Clarke modules
// Clarke handle initialization for current signals
clarkeHandle_I[mtrNum] = CLARKE_init(&clarke_I[mtrNum],sizeof(clarke_I[mtrNum]));
// Clarke handle initialization for voltage signals
clarkeHandle_V[mtrNum] = CLARKE_init(&clarke_V[mtrNum],sizeof(clarke_V[mtrNum]));
// Park handle initialization for current signals
parkHandle[mtrNum] = PARK_init(&park[mtrNum],sizeof(park[mtrNum]));
// compute scaling factors for flux and torque calculations
gFlux_pu_to_Wb_sf[mtrNum] = USER_computeFlux_pu_to_Wb_sf(&gUserParams[mtrNum]);
gFlux_pu_to_VpHz_sf[mtrNum] = USER_computeFlux_pu_to_VpHz_sf(&gUserParams[mtrNum]);
gTorque_Ls_Id_Iq_pu_to_Nm_sf[mtrNum] = USER_computeTorque_Ls_Id_Iq_pu_to_Nm_sf(&gUserParams[mtrNum]);
gTorque_Flux_Iq_pu_to_Nm_sf[mtrNum] = USER_computeTorque_Flux_Iq_pu_to_Nm_sf(&gUserParams[mtrNum]);
gSpeed_krpm_to_pu_sf[mtrNum] = _IQ((float_t)gUserParams[mtrNum].motor_numPolePairs * 1000.0
/ (gUserParams[mtrNum].iqFullScaleFreq_Hz * 60.0)); //// 0.26666666666666666666666666666667
gSpeed_pu_to_krpm_sf[mtrNum] = _IQ((gUserParams[mtrNum].iqFullScaleFreq_Hz * 60.0)
/ ((float_t)gUserParams[mtrNum].motor_numPolePairs * 1000.0));
gSpeed_hz_to_krpm_sf[mtrNum] = _IQ(60.0 / (float_t)gUserParams[mtrNum].motor_numPolePairs / 1000.0);
gCurrent_A_to_pu_sf[mtrNum] = _IQ(1.0 / gUserParams[mtrNum].iqFullScaleCurrent_A);
// disable Rs recalculation
EST_setFlag_enableRsRecalc(estHandle[mtrNum],false);
// set the number of current sensors
setupClarke_I(clarkeHandle_I[mtrNum],gUserParams[mtrNum].numCurrentSensors);
// set the number of voltage sensors
setupClarke_V(clarkeHandle_V[mtrNum],gUserParams[mtrNum].numVoltageSensors);
// initialize the PID controllers
pidSetup((HAL_MtrSelect_e)mtrNum);
// initialize the inverse Park module
iparkHandle[mtrNum] = IPARK_init(&ipark[mtrNum],sizeof(ipark[mtrNum]));
// initialize the space vector generator module
svgenHandle[mtrNum] = SVGEN_init(&svgen[mtrNum],sizeof(svgen[mtrNum]));
// initialize and configure offsets using filters
uint16_t cnt = 0;
_iq b0 = _IQ(gUserParams[mtrNum].offsetPole_rps/(float_t)gUserParams[mtrNum].ctrlFreq_Hz);
_iq a1 = (b0 - _IQ(1.0));
_iq b1 = _IQ(0.0);
for(cnt=0;cnt<6;cnt++)
filterHandle[mtrNum][cnt] = FILTER_FO_init(&filter[mtrNum][cnt],sizeof(filter[mtrNum][0]));
FILTER_FO_setDenCoeffs(filterHandle[mtrNum][cnt],a1);
FILTER_FO_setNumCoeffs(filterHandle[mtrNum][cnt],b0,b1);
FILTER_FO_setInitialConditions(filterHandle[mtrNum][cnt],_IQ(0.0),_IQ(0.0));
gMotorVars[mtrNum].Flag_enableOffsetcalc = false;
// initialize the encoder module
encHandle[mtrNum] = ENC_init(&enc[mtrNum],sizeof(enc[mtrNum]));
// initialize the slip compensation module
slipHandle[mtrNum] = SLIP_init(&slip[mtrNum],sizeof(slip[mtrNum]));
// setup the SLIP module
SLIP_setup(slipHandle[mtrNum], _IQ(gUserParams[mtrNum].ctrlPeriod_sec));
// setup faults
HAL_setupFaults(halHandleMtr[mtrNum]);
// initialize the SpinTAC Components
stHandle[mtrNum] = ST_init(&st_obj[mtrNum], sizeof(st_obj[mtrNum]));
} // End of for loop
// setup the encoder module
ENC_setup(encHandle[HAL_MTR1], 1, USER_MOTOR_NUM_POLE_PAIRS, USER_MOTOR_ENCODER_LINES, 0, USER_IQ_FULL_SCALE_FREQ_Hz, USER_ISR_FREQ_Hz, 8000.0);
ENC_setup(encHandle[HAL_MTR2], 1, USER_MOTOR_NUM_POLE_PAIRS_2, USER_MOTOR_ENCODER_LINES_2, 0, USER_IQ_FULL_SCALE_FREQ_Hz_2, USER_ISR_FREQ_Hz_2, 8000.0);
/// M C >>>>>>>>>>>>>
HAL_Obj_mtr *obj_mtr = (HAL_Obj_mtr *)halHandle;
HAL_Obj *obj = (HAL_Obj *)halHandle;
// QEP_Obj *qep = (QEP_Obj *)obj_mtr->qepHandle;
QEP_clear_all_interrupt_flags(obj_mtr->qepHandle); // Limpiar todas las banderas de interrupci�n
QEP_disable_all_interrupts(obj_mtr->qepHandle); // Deshabilitar todas las interrupciones
PIE_enableInt( obj->pieHandle, PIE_GroupNumber_5, PIE_InterruptSource_EQEP1 ); //Grupo 5 donde se encuentra la interrupcion de EQEP1
QEP_enable_interrupt(obj_mtr->qepHandle, QEINT_Iel); //Habilitar el bit de interrupci�n correspondiente al pulso de Index
CPU_enableInt(obj->cpuHandle,CPU_IntNumber_5); //Habilitar el grupo 5 en las interrupciones de la CPU
// setup the SpinTAC Components
ST_setupPosConv_mtr1(stHandle[HAL_MTR1]);
ST_setupPosConv_mtr2(stHandle[HAL_MTR2]);
ST_setupPosCtl_mtr1(stHandle[HAL_MTR1]);
ST_setupPosMove_mtr1(stHandle[HAL_MTR1]);
ST_setupPosCtl_mtr2(stHandle[HAL_MTR2]);
ST_setupPosMove_mtr2(stHandle[HAL_MTR2]);
// set the pre-determined current and voltage feeback offset values
gOffsets_I_pu[HAL_MTR1].value[0] = _IQ(I_A_offset);
gOffsets_I_pu[HAL_MTR1].value[1] = _IQ(I_B_offset);
gOffsets_I_pu[HAL_MTR1].value[2] = _IQ(I_C_offset);
gOffsets_V_pu[HAL_MTR1].value[0] = _IQ(V_A_offset);
gOffsets_V_pu[HAL_MTR1].value[1] = _IQ(V_B_offset);
gOffsets_V_pu[HAL_MTR1].value[2] = _IQ(V_C_offset);
gOffsets_I_pu[HAL_MTR2].value[0] = _IQ(I_A_offset_2);
gOffsets_I_pu[HAL_MTR2].value[1] = _IQ(I_B_offset_2);
gOffsets_I_pu[HAL_MTR2].value[2] = _IQ(I_C_offset_2);
gOffsets_V_pu[HAL_MTR2].value[0] = _IQ(V_A_offset_2);
gOffsets_V_pu[HAL_MTR2].value[1] = _IQ(V_B_offset_2);
gOffsets_V_pu[HAL_MTR2].value[2] = _IQ(V_C_offset_2);
// initialize the interrupt vector table
HAL_initIntVectorTable(halHandle);
//>>>> Configuracion de la interrupcion del index <<<<<<<<<<<<//
PIE_Obj *pie = (PIE_Obj *)obj->pieHandle;
ENABLE_PROTECTED_REGISTER_WRITE_MODE;
pie->EQEP1_INT = &QEP_Index_ISR;
DISABLE_PROTECTED_REGISTER_WRITE_MODE;
// enable the ADC interrupts
HAL_enableAdcInts(halHandle);
// enable global interrupts
HAL_enableGlobalInts(halHandle);
// enable debug interrupts
HAL_enableDebugInt(halHandle);
// disable the PWM
HAL_disablePwm(halHandleMtr[HAL_MTR1]);
HAL_disablePwm(halHandleMtr[HAL_MTR2]);
// initialize SpinTAC Velocity Control watch window variables
gMotorVars[HAL_MTR1].SpinTAC.PosCtlBw_radps = STPOSCTL_getBandwidth_radps(st_obj[HAL_MTR1].posCtlHandle);
gMotorVars[HAL_MTR2].SpinTAC.PosCtlBw_radps = STPOSCTL_getBandwidth_radps(st_obj[HAL_MTR2].posCtlHandle);
// initialize the watch window with maximum and minimum Iq reference
gMotorVars[HAL_MTR1].SpinTAC.PosCtlOutputMax_A = _IQmpy(STPOSCTL_getOutputMaximum(st_obj[HAL_MTR1].posCtlHandle), _IQ(gUserParams[HAL_MTR1].iqFullScaleCurrent_A));
gMotorVars[HAL_MTR1].SpinTAC.PosCtlOutputMin_A = _IQmpy(STPOSCTL_getOutputMinimum(st_obj[HAL_MTR1].posCtlHandle), _IQ(gUserParams[HAL_MTR1].iqFullScaleCurrent_A));
gMotorVars[HAL_MTR2].SpinTAC.PosCtlOutputMax_A = _IQmpy(STPOSCTL_getOutputMaximum(st_obj[HAL_MTR2].posCtlHandle), _IQ(gUserParams[HAL_MTR2].iqFullScaleCurrent_A));
gMotorVars[HAL_MTR2].SpinTAC.PosCtlOutputMin_A = _IQmpy(STPOSCTL_getOutputMinimum(st_obj[HAL_MTR2].posCtlHandle), _IQ(gUserParams[HAL_MTR2].iqFullScaleCurrent_A));
// enable the system by default
gMotorVars[HAL_MTR1].Flag_enableSys = true;
#ifdef DRV8301_SPI
// turn on the DRV8301 if present
HAL_enableDrv(halHandleMtr[HAL_MTR1]);
HAL_enableDrv(halHandleMtr[HAL_MTR2]);
// initialize the DRV8301 interface
HAL_setupDrvSpi(halHandleMtr[HAL_MTR1],&gDrvSpi8301Vars[HAL_MTR1]);
HAL_setupDrvSpi(halHandleMtr[HAL_MTR2],&gDrvSpi8301Vars[HAL_MTR2]);
#endif
#ifdef DRV8305_SPI
// turn on the DRV8305 if present
// initialize the DRV8305 interface
HAL_setupDrvSpi(halHandleMtr[HAL_MTR1],&gDrvSpi8305Vars[HAL_MTR1]);
HAL_setupDrvSpi(halHandleMtr[HAL_MTR2],&gDrvSpi8305Vars[HAL_MTR2]);
#endif
spa.year = 2003;
spa.month = 10;
spa.day = 17;
spa.hour = 12;
spa.minute = 30;
spa.second = 30;
spa.timezone = -7.0;
spa.delta_ut1 = 0;
spa.delta_t = 67;
spa.longitude = -105.1786;
spa.latitude = 39.742476;
spa.elevation = 1830.14;
spa.pressure = 820;
spa.temperature = 11;
spa.slope = 30;
spa.azm_rotation = -10;
spa.atmos_refract = 0.5667;
spa.function = SPA_ALL;
// Begin the background loop
for(;;)
// Waiting for enable system flag to be set
// Motor 1 Flag_enableSys is the master control.
while(!(gMotorVars[HAL_MTR1].Flag_enableSys));
// loop while the enable system flag is true
while(gMotorVars[HAL_MTR1].Flag_enableSys)
uint_least8_t mtrNum = HAL_MTR1;
// >>> INICIO Se le pasan los parametros al algoritmo y se obtienen los �ngulos <<<
// spa_algorithm(late,lon, ele);
result = spa_calculate(&spa);
if (result == 0) //check for SPA errors
//display the results inside the SPA structure
// printf("Julian Day: %.6f\n",spa.jd);
// printf("L: %.6e degrees\n",spa.l);
// printf("B: %.6e degrees\n",spa.b);
// printf("R: %.6f AU\n",spa.r);
// printf("H: %.6f degrees\n",spa.h);
// printf("Delta Psi: %.6e degrees\n",spa.del_psi);
// printf("Delta Epsilon: %.6e degrees\n",spa.del_epsilon);
// printf("Epsilon: %.6f degrees\n",spa.epsilon);
// printf("Zenith: %.6f degrees\n",spa.zenith);
// printf("Azimuth: %.6f degrees\n",spa.azimuth);
// printf("Incidence: %.6f degrees\n",spa.incidence);
azi = spa.azimuth;
zen = spa.zenith;
min = 60.0*(spa.sunrise - (int)(spa.sunrise));
sec = 60.0*(min - (int)min);
// printf("Sunrise: %02d:%02d:%02d Local Time\n", (int)(spa.sunrise), (int)min, (int)sec);
min = 60.0*(spa.sunset - (int)(spa.sunset));
// printf("Sunset: %02d:%02d:%02d Local Time\n", (int)(spa.sunset), (int)min, (int)sec);
} else f_err = 1; // printf("SPA Error Code: %d\n", result);
angAz = spa.azimuth;
angZen = spa.zenith;
ang_azi_establecer = (angAz - ang_azi_Actual);
ang_zen_establecer = (angZen - ang_zen_Actual);
ang_azi_mrev = ang_azi_establecer/360;
ang_zen_mrev = ang_zen_establecer/360;
ang_azi_Actual = angAz;
ang_zen_Actual = angZen;
// gMotorVars[HAL_MTR1].PosStepInt_MRev = 0;
// gMotorVars[HAL_MTR1].PosStepFrac_MRev = _IQ24(ang_azi_mrev);
gMotorVars[HAL_MTR1].RunPositionProfile = true;
// gMotorVars[HAL_MTR2].PosStepInt_MRev = 0;
// gMotorVars[HAL_MTR2].PosStepFrac_MRev = _IQ24(ang_zen_mrev);
gMotorVars[HAL_MTR2].RunPositionProfile = true;
// >>> FIN Se le pasan los parametros al algoritmo y se obtienen los �ngulos <<<
// If Flag_enableSys is set AND Flag_Run_Identify is set THEN
// enable PWMs and set the speed reference
if(gMotorVars[mtrNum].Flag_Run_Identify)
// update estimator state
EST_updateState(estHandle[mtrNum],0);
#ifdef FAST_ROM_V1p6
// call this function to fix 1p6. This is only used for
// F2806xF/M implementation of InstaSPIN (version 1.6 of
// ROM), since the inductance calculation is not done
// correctly in ROM, so this function fixes that ROM bug.
softwareUpdate1p6(estHandle[mtrNum],&gUserParams[mtrNum]);
#endif
// enable the PWM
HAL_enablePwm(halHandleMtr[mtrNum]);
// enable SpinTAC Velocity Control
STPOSCTL_setEnable(st_obj[mtrNum].posCtlHandle, true);
// provide bandwidth setting to SpinTAC Velocity Control
STPOSCTL_setBandwidth_radps(st_obj[mtrNum].posCtlHandle, gMotorVars[mtrNum].SpinTAC.PosCtlBw_radps);
// provide output maximum and minimum setting to SpinTAC Velocity Control
STPOSCTL_setOutputMaximums(st_obj[mtrNum].posCtlHandle, _IQmpy(gMotorVars[mtrNum].SpinTAC.PosCtlOutputMax_A, gCurrent_A_to_pu_sf[mtrNum]), _IQmpy(gMotorVars[mtrNum].SpinTAC.PosCtlOutputMin_A, gCurrent_A_to_pu_sf[mtrNum]));
else // Flag_enableSys is set AND Flag_Run_Identify is not set
// set estimator to Idle
EST_setIdle(estHandle[mtrNum]);
// disable the PWM
HAL_disablePwm(halHandleMtr[mtrNum]);
// clear integrator outputs
PID_setUi(pidHandle[mtrNum][0],_IQ(0.0));
PID_setUi(pidHandle[mtrNum][1],_IQ(0.0));
PID_setUi(pidHandle[mtrNum][2],_IQ(0.0));
// clear Id and Iq references
gIdq_ref_pu[mtrNum].value[0] = _IQ(0.0);
gIdq_ref_pu[mtrNum].value[1] = _IQ(0.0);
// place SpinTAC Velocity Control into reset
STPOSCTL_setEnable(st_obj[mtrNum].posCtlHandle, false);
// If motor is not running, feed the position feedback into SpinTAC Position Move
STPOSMOVE_setPositionStart_mrev(st_obj[mtrNum].posMoveHandle, STPOSCONV_getPosition_mrev(st_obj[mtrNum].posConvHandle));
// update the global variables
updateGlobalVariables(estHandle[mtrNum], mtrNum);
// enable/disable the forced angle
EST_setFlag_enableForceAngle(estHandle[mtrNum],
gMotorVars[mtrNum].Flag_enableForceAngle);
#ifdef DRV8301_SPI
HAL_writeDrvData(halHandleMtr[mtrNum],&gDrvSpi8301Vars[mtrNum]);
HAL_readDrvData(halHandleMtr[mtrNum],&gDrvSpi8301Vars[mtrNum]);
#endif
#ifdef DRV8305_SPI
HAL_writeDrvData(halHandleMtr[mtrNum],&gDrvSpi8305Vars[mtrNum]);
HAL_readDrvData(halHandleMtr[mtrNum],&gDrvSpi8305Vars[mtrNum]);
#endif
} // end of for loop
} // end of while(gFlag_enableSys) loop
// disable the PWM
gMotorVars[HAL_MTR1].Flag_Run_Identify = false;
gMotorVars[HAL_MTR2].Flag_Run_Identify = false;
} // end of for(;;) loop
} // end of main() function
//! \brief The main ISR that implements the motor control.
interrupt void motor1_ISR(void)
// Declaration of local variables
static _iq angle_pu = _IQ(0.0);
_iq speed_pu = _IQ(0.0);
_iq oneOverDcBus;
MATH_vec2 Iab_pu;
MATH_vec2 Vab_pu;
MATH_vec2 phasor;
HAL_setGpioHigh(halHandle,GPIO_Number_12);
// acknowledge the ADC interrupt
HAL_acqAdcInt(halHandle,ADC_IntNumber_1);
// convert the ADC data
HAL_readAdcDataWithOffsets(halHandle,halHandleMtr[HAL_MTR1],&gAdcData[HAL_MTR1]);
// remove offsets
gAdcData[HAL_MTR1].I.value[0] = gAdcData[HAL_MTR1].I.value[0] - gOffsets_I_pu[HAL_MTR1].value[0];
gAdcData[HAL_MTR1].I.value[1] = gAdcData[HAL_MTR1].I.value[1] - gOffsets_I_pu[HAL_MTR1].value[1];
gAdcData[HAL_MTR1].I.value[2] = gAdcData[HAL_MTR1].I.value[2] - gOffsets_I_pu[HAL_MTR1].value[2];
gAdcData[HAL_MTR1].V.value[0] = gAdcData[HAL_MTR1].V.value[0] - gOffsets_V_pu[HAL_MTR1].value[0];
gAdcData[HAL_MTR1].V.value[1] = gAdcData[HAL_MTR1].V.value[1] - gOffsets_V_pu[HAL_MTR1].value[1];
gAdcData[HAL_MTR1].V.value[2] = gAdcData[HAL_MTR1].V.value[2] - gOffsets_V_pu[HAL_MTR1].value[2];
// run Clarke transform on current. Three values are passed, two values
// are returned.
CLARKE_run(clarkeHandle_I[HAL_MTR1],&gAdcData[HAL_MTR1].I,&Iab_pu);
// compute the sine and cosine phasor values which are part of the
// Park transform calculations. Once these values are computed,
// they are copied into the PARK module, which then uses them to
// transform the voltages from Alpha/Beta to DQ reference frames.
phasor.value[0] = _IQcosPU(angle_pu);
phasor.value[1] = _IQsinPU(angle_pu);
// set the phasor in the Park transform
PARK_setPhasor(parkHandle[HAL_MTR1],&phasor);
// Run the Park module. This converts the current vector from
// stationary frame values to synchronous frame values.
PARK_run(parkHandle[HAL_MTR1],&Iab_pu,&gIdq_pu[HAL_MTR1]);
// compute the electrical angle
ENC_calcElecAngle(encHandle[HAL_MTR1], HAL_getQepPosnCounts(halHandleMtr[HAL_MTR1]));
if(stCntPosition[HAL_MTR1] >= gUserParams[HAL_MTR1].numCtrlTicksPerSpeedTick)
// Calculate the feedback position, this must always be ran in order to ensure there are no jumps
ST_runPosConv(stHandle[HAL_MTR1], encHandle[HAL_MTR1], slipHandle[HAL_MTR1], &gIdq_pu[HAL_MTR1], gUserParams[HAL_MTR1].motor_type);
// run the appropriate controller
if(gMotorVars[HAL_MTR1].Flag_Run_Identify)
// Declaration of local variables.
_iq refValue;
_iq fbackValue;
_iq outMax_pu;
// check if the motor should be forced into encoder slignment
if(gMotorVars[HAL_MTR1].Flag_enableAlignment == false)
gMotorVars[HAL_MTR1].MaxVel_krpm = _IQ(3);
gMotorVars[HAL_MTR1].MaxAccel_krpmps = _IQ(65);
gMotorVars[HAL_MTR1].MaxDecel_krpmps = _IQ(65);
gMotorVars[HAL_MTR1].MaxJrk_krpmps2 = _IQ20(350);
// when appropriate, run SpinTAC Position Control
// This mechanism provides the decimation for the speed loop.
// Reset the Position execution counter.
stCntPosition[HAL_MTR1] = 0;
if((STPOSMOVE_getStatus(st_obj[HAL_MTR1].posMoveHandle) == ST_MOVE_IDLE) && (gMotorVars[HAL_MTR1].RunPositionProfile == true))
// Get the configuration for SpinTAC Position Move
STPOSMOVE_setCurveType(st_obj[HAL_MTR1].posMoveHandle, gMotorVars[HAL_MTR1].SpinTAC.PosMoveCurveType);
STPOSMOVE_setPositionStep_mrev(st_obj[HAL_MTR1].posMoveHandle, gMotorVars[HAL_MTR1].PosStepInt_MRev,gMotorVars[HAL_MTR1].PosStepFrac_MRev);
STPOSMOVE_setVelocityLimit(st_obj[HAL_MTR1].posMoveHandle, _IQmpy(gMotorVars[HAL_MTR1].MaxVel_krpm, gSpeed_krpm_to_pu_sf[HAL_MTR1]));
STPOSMOVE_setAccelerationLimit(st_obj[HAL_MTR1].posMoveHandle, _IQmpy(gMotorVars[HAL_MTR1].MaxAccel_krpmps, gSpeed_krpm_to_pu_sf[HAL_MTR1]));
STPOSMOVE_setDecelerationLimit(st_obj[HAL_MTR1].posMoveHandle, _IQmpy(gMotorVars[HAL_MTR1].MaxDecel_krpmps, gSpeed_krpm_to_pu_sf[HAL_MTR1]));
STPOSMOVE_setJerkLimit(st_obj[HAL_MTR1].posMoveHandle, _IQ20mpy(gMotorVars[HAL_MTR1].MaxJrk_krpmps2, _IQtoIQ20(gSpeed_krpm_to_pu_sf[HAL_MTR1])));
// Enable the SpinTAC Position Profile Generator
STPOSMOVE_setEnable(st_obj[HAL_MTR1].posMoveHandle, true);
// clear the position step command
gMotorVars[HAL_MTR1].PosStepFrac_MRev = 0;
gMotorVars[HAL_MTR1].RunPositionProfile = false;
// The next instruction executes SpinTAC Velocity Move
// This is the speed profile generation
STPOSMOVE_run(st_obj[HAL_MTR1].posMoveHandle);
// The next instruction executes SpinTAC Position Control and places
// its output in Idq_ref_pu.value[1], which is the input reference
// value for the q-axis current controller.
gIdq_ref_pu[HAL_MTR1].value[1] = ST_runPosCtl(stHandle[HAL_MTR1]);
else
// increment counter
stCntPosition[HAL_MTR1]++;
// generate the motor electrical angle
if(gUserParams[HAL_MTR1].motor_type == MOTOR_Type_Induction)
// update the electrical angle for the SLIP module
SLIP_setElectricalAngle(slipHandle[HAL_MTR1], ENC_getElecAngle(encHandle[HAL_MTR1]));
// compute the amount of slip
SLIP_run(slipHandle[HAL_MTR1]);
// set magnetic angle
angle_pu = SLIP_getMagneticAngle(slipHandle[HAL_MTR1]);
else
angle_pu = ENC_getElecAngle(encHandle[HAL_MTR1]);
speed_pu = STPOSCONV_getVelocity(st_obj[HAL_MTR1].posConvHandle);
else
{ // the alignment procedure is in effect
// force motor angle and speed to 0
// set D-axis current to Rs estimation current
gIdq_ref_pu[HAL_MTR1].value[0] = _IQ(USER_MOTOR_RES_EST_CURRENT/USER_IQ_FULL_SCALE_CURRENT_A);
// set Q-axis current to 0
gIdq_ref_pu[HAL_MTR1].value[1] = _IQ(0.0);
// save encoder reading when forcing motor into alignment
if(gUserParams[HAL_MTR1].motor_type == MOTOR_Type_Pm)
ENC_setZeroOffset(encHandle[HAL_MTR1], (uint32_t)(HAL_getQepPosnMaximum(halHandleMtr[HAL_MTR1]) - HAL_getQepPosnCounts(halHandleMtr[HAL_MTR1])));
// if alignment counter exceeds threshold, exit alignment
if(gAlignCount[HAL_MTR1]++ >= gUserParams[HAL_MTR1].ctrlWaitTime[CTRL_State_OffLine])
gMotorVars[HAL_MTR1].Flag_enableAlignment = false;
gAlignCount[HAL_MTR1] = 0;
gIdq_ref_pu[HAL_MTR1].value[0] = _IQ(0.0);
// Get the reference value for the d-axis current controller.
refValue = gIdq_ref_pu[HAL_MTR1].value[0];
// Get the actual value of Id
fbackValue = gIdq_pu[HAL_MTR1].value[0];
// The next instruction executes the PI current controller for the
// d axis and places its output in Vdq_pu.value[0], which is the
// control voltage along the d-axis (Vd)
PID_run(pidHandle[HAL_MTR1][1],refValue,fbackValue,&(gVdq_out_pu[HAL_MTR1].value[0]));
// get the Iq reference value
refValue = gIdq_ref_pu[HAL_MTR1].value[1];
// get the actual value of Iq
fbackValue = gIdq_pu[HAL_MTR1].value[1];
// The voltage limits on the output of the q-axis current controller
// are dynamic, and are dependent on the output voltage from the d-axis
// current controller. In other words, the d-axis current controller
// gets first dibs on the available voltage, and the q-axis current
// controller gets what's left over. That is why the d-axis current
// controller executes first. The next instruction calculates the
// maximum limits for this voltage as:
// Vq_min_max = +/- sqrt(Vbus^2 - Vd^2)
outMax_pu = _IQsqrt(_IQ(USER_MAX_VS_MAG_PU * USER_MAX_VS_MAG_PU)
- _IQmpy(gVdq_out_pu[HAL_MTR1].value[0],gVdq_out_pu[HAL_MTR1].value[0]));
// Set the limits to +/- outMax_pu
PID_setMinMax(pidHandle[HAL_MTR1][2],-outMax_pu,outMax_pu);
// q axis and places its output in Vdq_pu.value[1], which is the
// control voltage vector along the q-axis (Vq)
PID_run(pidHandle[HAL_MTR1][2],refValue,fbackValue,&(gVdq_out_pu[HAL_MTR1].value[1]));
// The voltage vector is now calculated and ready to be applied to the
// motor in the form of three PWM signals. However, even though the
// voltages may be supplied to the PWM module now, they won't be
// applied to the motor until the next PWM cycle. By this point, the
// motor will have moved away from the angle that the voltage vector
// was calculated for, by an amount which is proportional to the
// sampling frequency and the speed of the motor. For steady-state
// speeds, we can calculate this angle delay and compensate for it.
ANGLE_COMP_run(angleCompHandle[HAL_MTR1],speed_pu,angle_pu);
angle_pu = ANGLE_COMP_getAngleComp_pu(angleCompHandle[HAL_MTR1]);
// compute the sine and cosine phasor values which are part of the inverse
// they are copied into the IPARK module, which then uses them to
// transform the voltages from DQ to Alpha/Beta reference frames.
// set the phasor in the inverse Park transform
IPARK_setPhasor(iparkHandle[HAL_MTR1],&phasor);
// Run the inverse Park module. This converts the voltage vector from
// synchronous frame values to stationary frame values.
IPARK_run(iparkHandle[HAL_MTR1],&gVdq_out_pu[HAL_MTR1],&Vab_pu);
// These 3 statements compensate for variations in the DC bus by adjusting the
// PWM duty cycle. The goal is to achieve the same volt-second product
// regardless of the DC bus value. To do this, we must divide the desired voltage
// values by the DC bus value. Or...it is easier to multiply by 1/(DC bus value).
oneOverDcBus = _IQdiv(_IQ(1.0), gAdcData[HAL_MTR1].dcBus);//EST_getOneOverDcBus_pu(estHandle[HAL_MTR1]);
Vab_pu.value[0] = _IQmpy(Vab_pu.value[0],oneOverDcBus);
Vab_pu.value[1] = _IQmpy(Vab_pu.value[1],oneOverDcBus);
// Now run the space vector generator (SVGEN) module.
// There is no need to do an inverse CLARKE transform, as this is
// handled in the SVGEN_run function.
SVGEN_run(svgenHandle[HAL_MTR1],&Vab_pu,&(gPwmData[HAL_MTR1].Tabc));
else if(gMotorVars[HAL_MTR1].Flag_enableOffsetcalc == true)
runOffsetsCalculation(HAL_MTR1);
else // gMotorVars.Flag_Run_Identify = 0
// disable the PWM
// Set the PWMs to 50% duty cycle
gPwmData[HAL_MTR1].Tabc.value[0] = _IQ(0.0);
gPwmData[HAL_MTR1].Tabc.value[1] = _IQ(0.0);
gPwmData[HAL_MTR1].Tabc.value[2] = _IQ(0.0);
// write to the PWM compare registers, and then we are done!
HAL_writePwmData(halHandleMtr[HAL_MTR1],&gPwmData[HAL_MTR1]);
HAL_setGpioLow(halHandle,GPIO_Number_12);
return;
} // end of motor1_ISR() function
interrupt void motor2_ISR(void)
_iq oneOverDcBus;
MATH_vec2 Iab_pu;
MATH_vec2 Vab_pu;
MATH_vec2 phasor;
HAL_setGpioHigh(halHandle,GPIO_Number_20);
HAL_acqAdcInt(halHandle,ADC_IntNumber_2);
HAL_readAdcDataWithOffsets(halHandle,halHandleMtr[HAL_MTR2],&gAdcData[HAL_MTR2]);
// remove offsets
gAdcData[HAL_MTR2].I.value[0] = gAdcData[HAL_MTR2].I.value[0] - gOffsets_I_pu[HAL_MTR2].value[0];
gAdcData[HAL_MTR2].I.value[1] = gAdcData[HAL_MTR2].I.value[1] - gOffsets_I_pu[HAL_MTR2].value[1];
gAdcData[HAL_MTR2].I.value[2] = gAdcData[HAL_MTR2].I.value[2] - gOffsets_I_pu[HAL_MTR2].value[2];
gAdcData[HAL_MTR2].V.value[0] = gAdcData[HAL_MTR2].V.value[0] - gOffsets_V_pu[HAL_MTR2].value[0];
gAdcData[HAL_MTR2].V.value[1] = gAdcData[HAL_MTR2].V.value[1] - gOffsets_V_pu[HAL_MTR2].value[1];
gAdcData[HAL_MTR2].V.value[2] = gAdcData[HAL_MTR2].V.value[2] - gOffsets_V_pu[HAL_MTR2].value[2];
// are returned.
CLARKE_run(clarkeHandle_I[HAL_MTR2],&gAdcData[HAL_MTR2].I,&Iab_pu);
PARK_setPhasor(parkHandle[HAL_MTR2],&phasor);
PARK_run(parkHandle[HAL_MTR2],&Iab_pu,&gIdq_pu[HAL_MTR2]);
ENC_calcElecAngle(encHandle[HAL_MTR2], HAL_getQepPosnCounts(halHandleMtr[HAL_MTR2]));
if(stCntPosition[HAL_MTR2] >= gUserParams[HAL_MTR2].numCtrlTicksPerSpeedTick)
ST_runPosConv(stHandle[HAL_MTR2], encHandle[HAL_MTR2], slipHandle[HAL_MTR2], &gIdq_pu[HAL_MTR2], gUserParams[HAL_MTR2].motor_type);
if(gMotorVars[HAL_MTR2].Flag_Run_Identify)
_iq refValue;
_iq fbackValue;
_iq outMax_pu;
if(gMotorVars[HAL_MTR2].Flag_enableAlignment == false)
gMotorVars[HAL_MTR2].MaxVel_krpm = _IQ(3);
gMotorVars[HAL_MTR2].MaxAccel_krpmps = _IQ(65);
gMotorVars[HAL_MTR2].MaxDecel_krpmps = _IQ(65);
gMotorVars[HAL_MTR2].MaxJrk_krpmps2 = _IQ20(350);
stCntPosition[HAL_MTR2] = 0;
if((STPOSMOVE_getStatus(st_obj[HAL_MTR2].posMoveHandle) == ST_MOVE_IDLE) && (gMotorVars[HAL_MTR2].RunPositionProfile == true))
STPOSMOVE_setCurveType(st_obj[HAL_MTR2].posMoveHandle, gMotorVars[HAL_MTR2].SpinTAC.PosMoveCurveType);
STPOSMOVE_setPositionStep_mrev(st_obj[HAL_MTR2].posMoveHandle, gMotorVars[HAL_MTR2].PosStepInt_MRev, gMotorVars[HAL_MTR2].PosStepFrac_MRev);
STPOSMOVE_setVelocityLimit(st_obj[HAL_MTR2].posMoveHandle, _IQmpy(gMotorVars[HAL_MTR2].MaxVel_krpm, gSpeed_krpm_to_pu_sf[HAL_MTR2]));
STPOSMOVE_setAccelerationLimit(st_obj[HAL_MTR2].posMoveHandle, _IQmpy(gMotorVars[HAL_MTR2].MaxAccel_krpmps, gSpeed_krpm_to_pu_sf[HAL_MTR2]));
STPOSMOVE_setDecelerationLimit(st_obj[HAL_MTR2].posMoveHandle, _IQmpy(gMotorVars[HAL_MTR2].MaxDecel_krpmps, gSpeed_krpm_to_pu_sf[HAL_MTR2]));
STPOSMOVE_setJerkLimit(st_obj[HAL_MTR2].posMoveHandle, _IQ20mpy(gMotorVars[HAL_MTR2].MaxJrk_krpmps2, _IQtoIQ20(gSpeed_krpm_to_pu_sf[HAL_MTR2])));
STPOSMOVE_setEnable(st_obj[HAL_MTR2].posMoveHandle, true);
gMotorVars[HAL_MTR2].PosStepFrac_MRev = 0;
gMotorVars[HAL_MTR2].RunPositionProfile = false;
STPOSMOVE_run(st_obj[HAL_MTR2].posMoveHandle);
gIdq_ref_pu[HAL_MTR2].value[1] = ST_runPosCtl(stHandle[HAL_MTR2]);
else
stCntPosition[HAL_MTR2]++;
if(gUserParams[HAL_MTR2].motor_type == MOTOR_Type_Induction)
SLIP_setElectricalAngle(slipHandle[HAL_MTR2], ENC_getElecAngle(encHandle[HAL_MTR2]));
SLIP_run(slipHandle[HAL_MTR2]);
angle_pu = SLIP_getMagneticAngle(slipHandle[HAL_MTR2]);
else
angle_pu = ENC_getElecAngle(encHandle[HAL_MTR2]);
speed_pu = STPOSCONV_getVelocity(st_obj[HAL_MTR2].posConvHandle);
else
gIdq_ref_pu[HAL_MTR2].value[0] = _IQ(USER_MOTOR_RES_EST_CURRENT_2/USER_IQ_FULL_SCALE_CURRENT_A_2);
gIdq_ref_pu[HAL_MTR2].value[1] = _IQ(0.0);
if(gUserParams[HAL_MTR2].motor_type == MOTOR_Type_Pm)
ENC_setZeroOffset(encHandle[HAL_MTR2], (uint32_t)(HAL_getQepPosnMaximum(halHandleMtr[HAL_MTR2]) - HAL_getQepPosnCounts(halHandleMtr[HAL_MTR2])));
if(gAlignCount[HAL_MTR2]++ >= gUserParams[HAL_MTR2].ctrlWaitTime[CTRL_State_OffLine])
gMotorVars[HAL_MTR2].Flag_enableAlignment = false;
gAlignCount[HAL_MTR2] = 0;
gIdq_ref_pu[HAL_MTR2].value[0] = _IQ(0.0);
refValue = gIdq_ref_pu[HAL_MTR2].value[0];
fbackValue = gIdq_pu[HAL_MTR2].value[0];
PID_run(pidHandle[HAL_MTR2][1],refValue,fbackValue,&(gVdq_out_pu[HAL_MTR2].value[0]));
refValue = gIdq_ref_pu[HAL_MTR2].value[1];
fbackValue = gIdq_pu[HAL_MTR2].value[1];
outMax_pu = _IQsqrt(_IQ(USER_MAX_VS_MAG_PU_2 * USER_MAX_VS_MAG_PU_2)
- _IQmpy(gVdq_out_pu[HAL_MTR2].value[0],gVdq_out_pu[HAL_MTR2].value[0]));
PID_setMinMax(pidHandle[HAL_MTR2][2],-outMax_pu,outMax_pu);
PID_run(pidHandle[HAL_MTR2][2],refValue,fbackValue,&(gVdq_out_pu[HAL_MTR2].value[1]));
ANGLE_COMP_run(angleCompHandle[HAL_MTR2],speed_pu,angle_pu);
angle_pu = ANGLE_COMP_getAngleComp_pu(angleCompHandle[HAL_MTR2]);
IPARK_setPhasor(iparkHandle[HAL_MTR2],&phasor);
IPARK_run(iparkHandle[HAL_MTR2],&gVdq_out_pu[HAL_MTR2],&Vab_pu);
oneOverDcBus = _IQdiv(_IQ(1.0), gAdcData[HAL_MTR2].dcBus);
SVGEN_run(svgenHandle[HAL_MTR2],&Vab_pu,&(gPwmData[HAL_MTR2].Tabc));
else if(gMotorVars[HAL_MTR2].Flag_enableOffsetcalc == true)
runOffsetsCalculation(HAL_MTR2);
// disable the PWM
gPwmData[HAL_MTR2].Tabc.value[0] = _IQ(0.0);
gPwmData[HAL_MTR2].Tabc.value[1] = _IQ(0.0);
gPwmData[HAL_MTR2].Tabc.value[2] = _IQ(0.0);
HAL_writePwmData(halHandleMtr[HAL_MTR2],&gPwmData[HAL_MTR2]);
HAL_setGpioLow(halHandle,GPIO_Number_20);
return;
} // end of motor2_ISR() function
void pidSetup(HAL_MtrSelect_e mtrNum)
// This equation uses the scaled maximum voltage vector, which is
// already in per units, hence there is no need to include the #define
// for USER_IQ_FULL_SCALE_VOLTAGE_V
_iq maxVoltage_pu = _IQ(gUserParams[mtrNum].maxVsMag_pu *
gUserParams[mtrNum].voltage_sf);
float_t fullScaleCurrent = gUserParams[mtrNum].iqFullScaleCurrent_A;
float_t fullScaleVoltage = gUserParams[mtrNum].iqFullScaleVoltage_V;
float_t IsrPeriod_sec = 1.0e-6 * gUserParams[mtrNum].pwmPeriod_usec *
gUserParams[mtrNum].numPwmTicksPerIsrTick;
float_t Ls_d = gUserParams[mtrNum].motor_Ls_d;
float_t Ls_q = gUserParams[mtrNum].motor_Ls_q;
float_t Rs = gUserParams[mtrNum].motor_Rs;
// This lab assumes that motor parameters are known, and it does not
// perform motor ID, so the R/L parameters are known and defined in
// user.h
float_t RoverLs_d = Rs / Ls_d;
float_t RoverLs_q = Rs / Ls_q;
// For the current controller, Kp = Ls*bandwidth(rad/sec) But in order
// to be used, it must be converted to per unit values by multiplying
// by fullScaleCurrent and then dividing by fullScaleVoltage. From the
// statement below, we see that the bandwidth in rad/sec is equal to
// 0.25/IsrPeriod_sec, which is equal to USER_ISR_FREQ_HZ/4. This means
// that by setting Kp as described below, the bandwidth in Hz is
// USER_ISR_FREQ_HZ/(8*pi).
_iq Kp_Id = _IQ((0.25 * Ls_d * fullScaleCurrent) / (IsrPeriod_sec
* fullScaleVoltage));
// In order to achieve pole/zero cancellation (which reduces the
// closed-loop transfer function from a second-order system to a
// first-order system), Ki must equal Rs/Ls. Since the output of the
// Ki gain stage is integrated by a DIGITAL integrator, the integrator
// input must be scaled by 1/IsrPeriod_sec. That's just the way
// digital integrators work. But, since IsrPeriod_sec is a constant,
// we can save an additional multiplication operation by lumping this
// term with the Ki value.
_iq Ki_Id = _IQ(RoverLs_d * IsrPeriod_sec);
// Now do the same thing for Kp for the q-axis current controller.
// If the motor is not an IPM motor, Ld and Lq are the same, which
// means that Kp_Iq = Kp_Id
_iq Kp_Iq = _IQ((0.25 * Ls_q * fullScaleCurrent) / (IsrPeriod_sec
// Do the same thing for Ki for the q-axis current controller. If the
// motor is not an IPM motor, Ld and Lq are the same, which means that
// Ki_Iq = Ki_Id.
_iq Ki_Iq = _IQ(RoverLs_q * IsrPeriod_sec);
// There are two PI controllers; two current
// controllers. Each PI controller has two coefficients; Kp and Ki.
// So you have a total of four coefficients that must be defined.
// This is for the Id current controller
pidHandle[mtrNum][1] = PID_init(&pid[mtrNum][1],sizeof(pid[mtrNum][1]));
// This is for the Iq current controller
pidHandle[mtrNum][2] = PID_init(&pid[mtrNum][2],sizeof(pid[mtrNum][2]));
stCntPosition[mtrNum] = 0; // Set the counter for decimating the speed
// controller to 0
// The following instructions load the parameters for the d-axis
// P term = Kp_Id, I term = Ki_Id, D term = 0
PID_setGains(pidHandle[mtrNum][1],Kp_Id,Ki_Id,_IQ(0.0));
// Largest negative voltage = -maxVoltage_pu, largest positive
// voltage = maxVoltage_pu
PID_setMinMax(pidHandle[mtrNum][1],-maxVoltage_pu,maxVoltage_pu);
// Set the initial condition value for the integrator output to 0
// The following instructions load the parameters for the q-axis
// P term = Kp_Iq, I term = Ki_Iq, D term = 0
PID_setGains(pidHandle[mtrNum][2],Kp_Iq,Ki_Iq,_IQ(0.0));
// The largest negative voltage = 0 and the largest positive
// voltage = 0. But these limits are updated every single ISR before
// actually executing the Iq controller. The limits depend on how much
// voltage is left over after the Id controller executes. So having an
// initial value of 0 does not affect Iq current controller execution.
PID_setMinMax(pidHandle[mtrNum][2],_IQ(0.0),_IQ(0.0));
void runOffsetsCalculation(HAL_MtrSelect_e mtrNum)
uint16_t cnt;
// enable the PWM
for(cnt=0;cnt<3;cnt++)
gPwmData[mtrNum].Tabc.value[cnt] = _IQ(0.0);
// reset offsets used
gOffsets_I_pu[mtrNum].value[cnt] = _IQ(0.0);
gOffsets_V_pu[mtrNum].value[cnt] = _IQ(0.0);
// run offset estimation
FILTER_FO_run(filterHandle[mtrNum][cnt],gAdcData[mtrNum].I.value[cnt]);
FILTER_FO_run(filterHandle[mtrNum][cnt+3],gAdcData[mtrNum].V.value[cnt]);
if(gOffsetCalcCount[mtrNum]++ >= gUserParams[mtrNum].ctrlWaitTime[CTRL_State_OffLine])
gOffsetCalcCount[mtrNum] = 0;
// get calculated offsets from filter
gOffsets_I_pu[mtrNum].value[cnt] = FILTER_FO_get_y1(filterHandle[mtrNum][cnt]);
gOffsets_V_pu[mtrNum].value[cnt] = FILTER_FO_get_y1(filterHandle[mtrNum][cnt+3]);
// clear filters
FILTER_FO_setInitialConditions(filterHandle[mtrNum][cnt+3],_IQ(0.0),_IQ(0.0));
return;
} // end of runOffsetsCalculation() function
//! \brief Call this function to fix 1p6. This is only used for F2806xF/M
//! \brief implementation of InstaSPIN (version 1.6 of ROM) since the
//! \brief inductance calculation is not done correctly in ROM, so this
//! \brief function fixes that ROM bug.
void softwareUpdate1p6(EST_Handle handle,USER_Params *pUserParams)
float_t iqFullScaleVoltage_V = pUserParams->iqFullScaleVoltage_V;
float_t iqFullScaleCurrent_A = pUserParams->iqFullScaleCurrent_A;
float_t voltageFilterPole_rps = pUserParams->voltageFilterPole_rps;
float_t motorLs_d = pUserParams->motor_Ls_d;
float_t motorLs_q = pUserParams->motor_Ls_q;
float_t fullScaleInductance = iqFullScaleVoltage_V
/ (iqFullScaleCurrent_A
* voltageFilterPole_rps);
float_t Ls_coarse_max = _IQ30toF(EST_getLs_coarse_max_pu(handle));
int_least8_t lShift = ceil(log(motorLs_d / (Ls_coarse_max
* fullScaleInductance)) / log(2.0));
uint_least8_t Ls_qFmt = 30 - lShift;
float_t L_max = fullScaleInductance * pow(2.0,lShift);
_iq Ls_d_pu = _IQ30(motorLs_d / L_max);
_iq Ls_q_pu = _IQ30(motorLs_q / L_max);
// store the results
EST_setLs_d_pu(handle,Ls_d_pu);
EST_setLs_q_pu(handle,Ls_q_pu);
EST_setLs_qFmt(handle,Ls_qFmt);
return;
} // end of softwareUpdate1p6() function
//! \brief Setup the Clarke transform for either 2 or 3 sensors.
//! \param[in] handle The clarke (CLARKE) handle
//! \param[in] numCurrentSensors The number of current sensors
void setupClarke_I(CLARKE_Handle handle,const uint_least8_t numCurrentSensors)
_iq alpha_sf,beta_sf;
// initialize the Clarke transform module for current
if(numCurrentSensors == 3)
alpha_sf = _IQ(MATH_ONE_OVER_THREE);
beta_sf = _IQ(MATH_ONE_OVER_SQRT_THREE);
else if(numCurrentSensors == 2)
alpha_sf = _IQ(1.0);
else
alpha_sf = _IQ(0.0);
beta_sf = _IQ(0.0);
// set the parameters
CLARKE_setScaleFactors(handle,alpha_sf,beta_sf);
CLARKE_setNumSensors(handle,numCurrentSensors);
return;
} // end of setupClarke_I() function
//! \param[in] numVoltageSensors The number of voltage sensors
void setupClarke_V(CLARKE_Handle handle,const uint_least8_t numVoltageSensors)
// initialize the Clarke transform module for voltage
if(numVoltageSensors == 3)
else
beta_sf = _IQ(0.0);
// In other words, the only acceptable number of voltage sensors is three.
CLARKE_setNumSensors(handle,numVoltageSensors);
return;
} // end of setupClarke_V() function
//! \brief Update the global variables (gMotorVars).
//! \param[in] handle The estimator (EST) handle
void updateGlobalVariables(EST_Handle handle, const uint_least8_t mtrNum)
uint32_t profile_mticks, profile_ticks;
// get the speed estimate
gMotorVars[mtrNum].Speed_krpm = _IQmpy(STPOSCONV_getVelocityFiltered(st_obj[mtrNum].posConvHandle), gSpeed_pu_to_krpm_sf[mtrNum]);
// Get the DC buss voltage
gMotorVars[mtrNum].VdcBus_kV = _IQmpy(gAdcData[mtrNum].dcBus,
_IQ(gUserParams[mtrNum].iqFullScaleVoltage_V / 1000.0));
// read Vd and Vq vectors per units
gMotorVars[mtrNum].Vd = gVdq_out_pu[mtrNum].value[0];
gMotorVars[mtrNum].Vq = gVdq_out_pu[mtrNum].value[1];
// calculate vector Vs in per units: (Vs = sqrt(Vd^2 + Vq^2))
gMotorVars[mtrNum].Vs = _IQsqrt(_IQmpy(gMotorVars[mtrNum].Vd,gMotorVars[mtrNum].Vd)
+ _IQmpy(gMotorVars[mtrNum].Vq,gMotorVars[mtrNum].Vq));
// read Id and Iq vectors in amps
gMotorVars[mtrNum].Id_A = _IQmpy(gIdq_pu[mtrNum].value[0],
_IQ(gUserParams[mtrNum].iqFullScaleCurrent_A));
gMotorVars[mtrNum].Iq_A = _IQmpy(gIdq_pu[mtrNum].value[1],
// calculate vector Is in amps: (Is_A = sqrt(Id_A^2 + Iq_A^2))
gMotorVars[mtrNum].Is_A = _IQsqrt(_IQmpy(gMotorVars[mtrNum].Id_A,gMotorVars[mtrNum].Id_A)
+ _IQmpy(gMotorVars[mtrNum].Iq_A,gMotorVars[mtrNum].Iq_A));
// gets the Position Controller status
gMotorVars[mtrNum].SpinTAC.PosCtlStatus = STPOSCTL_getStatus(st_obj[mtrNum].posCtlHandle);
// get the inertia setting
gMotorVars[mtrNum].SpinTAC.InertiaEstimate_Aperkrpm = _IQmpy(STPOSCTL_getInertia(st_obj[mtrNum].posCtlHandle), _IQ(((float_t)gUserParams[mtrNum].motor_numPolePairs / (0.001 * 60.0 * gUserParams[mtrNum].iqFullScaleFreq_Hz)) * gUserParams[mtrNum].iqFullScaleCurrent_A));
// get the friction setting
gMotorVars[mtrNum].SpinTAC.FrictionEstimate_Aperkrpm = _IQmpy(STPOSCTL_getFriction(st_obj[mtrNum].posCtlHandle), _IQ(((float_t)gUserParams[mtrNum].motor_numPolePairs / (0.001 * 60.0 * gUserParams[mtrNum].iqFullScaleFreq_Hz)) * gUserParams[mtrNum].iqFullScaleCurrent_A));
// get the Position Controller error
gMotorVars[mtrNum].SpinTAC.PosCtlErrorID = STPOSCTL_getErrorID(st_obj[mtrNum].posCtlHandle);
// get the Position Move status
gMotorVars[mtrNum].SpinTAC.PosMoveStatus = STPOSMOVE_getStatus(st_obj[mtrNum].posMoveHandle);
// get the Position Move profile time
STPOSMOVE_getProfileTime_tick(st_obj[mtrNum].posMoveHandle, &profile_mticks, &profile_ticks);
gMotorVars[mtrNum].SpinTAC.PosMoveTime_mticks = profile_mticks;
gMotorVars[mtrNum].SpinTAC.PosMoveTime_ticks = profile_ticks;
// get the Position Move error
gMotorVars[mtrNum].SpinTAC.PosMoveErrorID = STPOSMOVE_getErrorID(st_obj[mtrNum].posMoveHandle);
// get the Position Converter error
gMotorVars[mtrNum].SpinTAC.PosConvErrorID = STPOSCONV_getErrorID(st_obj[mtrNum].posConvHandle);
return;
} // end of updateGlobalVariables() function
void ST_runPosConv(ST_Handle handle, ENC_Handle encHandle, SLIP_Handle slipHandle, MATH_vec2 *Idq_pu, MOTOR_Type_e motorType)
ST_Obj *stObj = (ST_Obj *)handle;
// get the electrical angle from the ENC module
STPOSCONV_setElecAngle_erev(stObj->posConvHandle, ENC_getElecAngle(encHandle));
if(motorType == MOTOR_Type_Induction) {
// The CurrentVector feedback is only needed for ACIM
// get the vector of the direct/quadrature current input vector values from CTRL
STPOSCONV_setCurrentVector(stObj->posConvHandle, Idq_pu);
// run the SpinTAC Position Converter
STPOSCONV_run(stObj->posConvHandle);
// The Slip Velocity is only needed for ACIM
// update the slip velocity in electrical angle per second, Q24
SLIP_setSlipVelocity(slipHandle, STPOSCONV_getSlipVelocity(stObj->posConvHandle));
_iq ST_runPosCtl(ST_Handle handle)
_iq iqReference;
// provide the updated references to the SpinTAC Position Control
STPOSCTL_setPositionReference_mrev(stObj->posCtlHandle, STPOSMOVE_getPositionReference_mrev(stObj->posMoveHandle));
STPOSCTL_setVelocityReference(stObj->posCtlHandle, STPOSMOVE_getVelocityReference(stObj->posMoveHandle));
STPOSCTL_setAccelerationReference(stObj->posCtlHandle, STPOSMOVE_getAccelerationReference(stObj->posMoveHandle));
// provide the feedback to the SpinTAC Position Control
STPOSCTL_setPositionFeedback_mrev(stObj->posCtlHandle, STPOSCONV_getPosition_mrev(stObj->posConvHandle));
// Run SpinTAC Position Control
STPOSCTL_run(stObj->posCtlHandle);
// Provide SpinTAC Position Control Torque Output to the FOC
iqReference = STPOSCTL_getTorqueReference(stObj->posCtlHandle);
return iqReference;
interrupt void QEP_Index_ISR(void) // Funci�n que se encarga de llevar a cero grados los rotores
// Limpiar el "interrupt flag"
QEP_clear_interrupt_flag(obj_mtr->qepHandle, QEINT_Iel);
// Acknowledge interrupt from PIE group 5
PIE_clearInt(obj->pieHandle,PIE_GroupNumber_5);
gIndexOcurre++;
return;
short gIndexOcurre = 0; //counter of interruptions
void main(void)
QEP_clear_all_interrupt_flags(obj_mtr->qepHandle); // Limpiar todas las banderas de interrupción
QEP_enable_interrupt(obj_mtr->qepHandle, QEINT_Iel); //Habilitar el bit de interrupción correspondiente al pulso de Index
// disable the PWM
interrupt void QEP_Index_ISR(void) //Interruption function at the end of the file
gIndexOcurre++;
return;
