CCS/TMS320F28027: Unable to flash program TMS 320F28027 using Blackhawk USB2000 controller
Part Number: TMS320F28027
I am trying to flash program TMS320F28027 using Blackhawk USB 2000 controller. I am using code example flash 28027 available in control suite.  The  microcontroller is soldered on a breakout board. The signals (TMS,TDI,TCLK,TDO) are pull up signals using 4.7 K resistors while TRST signal is pull down signal through 2.3k resistor. Vreg is grounded. However, when the flash programm is built and debugged, the following error shows up.
C28xx: Failed CPU Reset: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.83.0)
C28xx: Trouble Reading Register PC: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.83.0)
C28xx: Trouble Reading Register ST1: (Error -1137 @ 0x6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.83.0)
C28xx: GEL: Error while executing OnReset(1): Target failed to read register ST1
    at (ST1&~(0x0100)) [f28027.gel:283]
    at C28x_Mode() [f28027.gel:33]
    at OnReset(1)
C28xx: Flash Programmer: Warning: The configured device (TMS320F28027), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
C28xx: Failed CPU Reset: (Error -1137 @ 0x0) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.83.0)
    at OnReset(1)
C28xx: Trouble Writing Memory Block at 0xae0 on Page 1 of Length 0x1: (Error -1137 @ 0xAE1) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.83.0)
C28xx: Error occurred during flash operation: Target failed to write 0x00000AE0@Data
C28xx: Trouble Writing Memory Block at 0xae1 on Page 1 of Length 0x1: (Error -1137 @ 0xAE2) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.83.0)
C28xx: Error occurred during flash operation: Target failed to write 0x00000AE1@Data
C28xx: Trouble Writing Memory Block at 0xae2 on Page 1 of Length 0x1: (Error -1137 @ 0xAE3) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.83.0)
C28xx: Error occurred during flash operation: Target failed to write 0x00000AE2@Data
C28xx: Trouble Writing Memory Block at 0xae3 on Page 1 of Length 0x1: (Error -1137 @ 0xAE4) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.83.0)
C28xx: Error occurred during flash operation: Target failed to write 0x00000AE3@Data
C28xx: Trouble Writing Memory Block at 0xae4 on Page 1 of Length 0x1: (Error -1137 @ 0xAE5) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.83.0)
C28xx: Error occurred during flash operation: Target failed to write 0x00000AE4@Data
C28xx: Trouble Writing Memory Block at 0xae5 on Page 1 of Length 0x1: (Error -1137 @ 0xAE6) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.83.0)
C28xx: Error occurred during flash operation: Target failed to write 0x00000AE5@Data
C28xx: Trouble Writing Memory Block at 0xae6 on Page 1 of Length 0x1: (Error -1137 @ 0xAE7) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.83.0)
C28xx: Error occurred during flash operation: Target failed to write 0x00000AE6@Data
C28xx: Trouble Writing Memory Block at 0xae7 on Page 1 of Length 0x1: (Error -1137 @ 0xAE8) Device is held in reset. Take the device out of reset, and retry the operation. (Emulation package 6.0.83.0)
C28xx: Error occurred during flash operation: Target failed to write 0x00000AE7@Data
C28xx: Flash Programmer: Device is locked or not connected. Operation cancelled.
C28xx: File Loader: Memory write failed: Unknown error
What could be the problem and how to solve this.
