TMS320F28379D: ADC PPB limit detection vs. comparator subsystems
Part Number: TMS320F28379D
Hi, I suppose that for over current detection, comparator subsystems should be used to Hi-Z all the pwms because it's faster than PPB limit detection (which needs conversion and cost time).
But I also find the sentence in reference manual "This functionality also enables safety conscious applications to trip the ePWM based on an out-of-range ADC conversion without any CPU intervention." What's safety conscious applications? It's different from what I mentioned above for over current detection?
  • Hi Howard,
    You can use the Comparators and/or the PPBs to achieve similar results.
    The comparators will definitely be faster, but the ADC PPB levels will be much more accurate. The PPBs are also sampled at a specific time in the ePWM control cycle, whereas the comparators are active all the time (although I think you can add a blanking window in the ePMW if desired).
    You can use both to achieve redundant tripps of the ePWM.
