CCS/TIDM-TMDSPLCKIT-V3: CCS Problem
Part Number: TIDM-TMDSPLCKIT-V3
Hi, I have bought a TMDSPLCKIT-V3.
Inside the kit I have found PRIME_DDK_PackageV7910.
I can't compile the example (TI_PRIME_LCC_EXAMPLE) from CCS v.6.2.
I receive different errors.
Could you help me?
  • Hello
    Please copy the build log from the CCS console window and attach on here so I can help figure out what issues you are seeing.
    Best regards
    Chris
  • **** Clean-only build of configuration Release for project prime_llc_example_f2806x ****
    "C:\\ti\\ccs620\\ccsv6\\utils\\bin\\gmake" -k clean
    DEL /F  "prime_ec_f2806xcfg.h" "prime_ec_f2806xcfg.h??"  "prime_ec_f2806x.cdb"  "C:\Texas Instruments\PRIME_DDK_PackageV7910\SW\TI_PRIME_LLC_EXAMPLE\TI_PRIME_LLC_EXAMPLE\dsp_c28x\prime\test\llc_example_project\release_f2806x\prime_llc_example_f2806x.out"  "prime_ec_f2806xcfg.cmd" "prime_ec_f2806xcfg.s??" "prime_ec_f2806xcfg_c.c"
    DEL /F "F2806x_GlobalVariableDefs.d" "ec_task.d" "eca_appemu_sn.d" "ecf.d" "llc_main.d" "prime_ec_f2806xcfg_c.d"
    DEL /F "prime_ec_f2806xcfg.d"
    DEL /F "c:\temp\f2806x\prime_llc_example_f2806x\Release\F2806x_CodeStartBranch.obj" "c:\temp\f2806x\prime_llc_example_f2806x\Release\F2806x_GlobalVariableDefs.obj" "c:\temp\f2806x\prime_llc_example_f2806x\Release\ec_task.obj" "c:\temp\f2806x\prime_llc_example_f2806x\Release\eca_appemu_sn.obj" "c:\temp\f2806x\prime_llc_example_f2806x\Release\ecf.obj" "c:\temp\f2806x\prime_llc_example_f2806x\Release\llc_main.obj" "c:\temp\f2806x\prime_llc_example_f2806x\Release\prime_ec_f2806xcfg.obj" "c:\temp\f2806x\prime_llc_example_f2806x\Release\prime_ec_f2806xcfg_c.obj"
    DEL /F "F2806x_CodeStartBranch.d"
    Impossibile trovare C:\Texas Instruments\PRIME_DDK_PackageV7910\SW\TI_PRIME_LLC_EXAMPLE\TI_PRIME_LLC_EXAMPLE\dsp_c28x\prime\test\llc_example_project\proj\Release\prime_ec_f2806xcfg.h
    Impossibile trovare C:\Texas Instruments\PRIME_DDK_PackageV7910\SW\TI_PRIME_LLC_EXAMPLE\TI_PRIME_LLC_EXAMPLE\dsp_c28x\prime\test\llc_example_project\release_f2806x\prime_llc_example_f2806x.out
    Impossibile trovare C:\Texas Instruments\PRIME_DDK_PackageV7910\SW\TI_PRIME_LLC_EXAMPLE\TI_PRIME_LLC_EXAMPLE\dsp_c28x\prime\test\llc_example_project\proj\Release\prime_ec_f2806xcfg.cmd
    Impossibile trovare C:\Texas Instruments\PRIME_DDK_PackageV7910\SW\TI_PRIME_LLC_EXAMPLE\TI_PRIME_LLC_EXAMPLE\dsp_c28x\prime\test\llc_example_project\proj\Release\F2806x_GlobalVariableDefs.d
    Impossibile trovare C:\Texas Instruments\PRIME_DDK_PackageV7910\SW\TI_PRIME_LLC_EXAMPLE\TI_PRIME_LLC_EXAMPLE\dsp_c28x\prime\test\llc_example_project\proj\Release\prime_ec_f2806xcfg.d
    Impossibile trovare c:\temp\f2806x\prime_llc_example_f2806x\Release\F2806x_CodeStartBranch.obj
    Impossibile trovare C:\Texas Instruments\PRIME_DDK_PackageV7910\SW\TI_PRIME_LLC_EXAMPLE\TI_PRIME_LLC_EXAMPLE\dsp_c28x\prime\test\llc_example_project\proj\Release\F2806x_CodeStartBranch.d
    'Finished clean'
    **** Build Finished ****
    Buildfile generation error occurred..
    Referenced project 'bfm' does not exist in the workspace. Project 'prime_llc_example_f2806x' may not build as expected.
    Build stopped..
  • It looks to not be able to find some files. Can check out the below links as well as training to help fix the reference problems you are seeing.
    e2e.ti.com/.../179750
    processors.wiki.ti.com/.../Include_paths_and_options
    processors.wiki.ti.com/.../Category:CCSv6_Training
    Best regards
    Chris
