Hello Champs,
In F280049 controlCARD, GPIO24 and GPIO32 has been both pulled up with 56K resistor.
Would you please kindly suggest whether this pull-up is enough or not? Thanks!
Linda
Hello Champs,
Linda
Hello Kris,
GPIO24 and GPIO32 will be used as boot mode pin at power-up for internal flash boot and will be switched to GPIO when user codes run.
Would you please kindly recommend the pull-up and pull-down resistors value for this kind of application? Thanks!
Linda
