Part Number: TMS320F28379S
Other Parts Discussed in Thread: SFRA, POWERSUITE
Dear experts,
currently my customer is working with the example Buck_VCM_F2837xS to analyze the plant with the aid of SFRA. He understands the measurement of the plant frequency response. He determines the Closed Loop System in respect to the measured values.
How to calculate for the open loop system?
In his opinion an open loop system (controller, plant and measuring block) can only be calculated by knowing the transfer function of the measuring device.
What is the transfer function of the measuring device (e.g. concerning transfer delays)?
Or do we apply some approximation of the measuring device (ADC) and only use gain for the calculation (Volt to discrete)?
Some more questions.
How to increase the number of the analyzing frequencies? Background: It seems that there is limit at 300 measurement points, which is caused by memory size. Can you recommend some workaround here? Would it possible to reduce precision (32 floating point vs. 16 bit or similar)?
