Other Parts Discussed in Thread: CONTROLSUITE
Dear All
I did not tested the code below yet.
Can anyone say if it will work? Notice two cases
Can you detect any error, please?
Active High, Complementary Outputs, Upcount, PWM4,5,6, to generate 3 phase sines
EALLOW;
SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 0;
EDIS;
EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_CTR_ZERO;
EPwm2Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
EPwm3Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
EPwm4Regs.TBPRD = 4500; // Set timer period
EPwm4Regs.TBPHS.half.TBPHS = 0x0000; // Phase is 0
EPwm4Regs.TBCTR = 0x0000; // Clear counter
// Setup TBCLK
EPwm4Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; // Count up
EPwm4Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Disable phase loading
EPwm4Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm4Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;;
EPwm4Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm4Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm4Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Load registers every ZERO
EPwm4Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm4Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
EPwm4Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
// Setup compare
EPwm4Regs.CMPA.half.CMPA = 0;
// Set actions
EPwm4Regs.AQCTLA.bit.ZRO = AQ_SET;
EPwm4Regs.AQCTLA.bit.CAU = AQ_CLEAR;
EPwm4Regs.AQCTLB.bit.ZRO = AQ_CLEAR;
EPwm4Regs.AQCTLB.bit.CAU = AQ_SET;
// Active Complementary HIGH PWMs - Setup Deadband
EPwm4Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE;
EPwm4Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC;
EPwm4Regs.DBCTL.bit.IN_MODE = DBA_ALL;
EPwm4Regs.DBRED = 90;
EPwm4Regs.DBFED = 90;
EPwm5Regs.TBPRD = 4500; // Set timer period
EPwm5Regs.TBPHS.half.TBPHS = 0x0000; // Phase is 0
EPwm5Regs.TBCTR = 0x0000; // Clear counter
// Setup TBCLK
EPwm5Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; // Count up
EPwm5Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Disable phase loading
EPwm5Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm5Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
EPwm5Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm5Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm5Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Load registers every ZERO
EPwm5Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm5Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
EPwm5Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
// Setup compare
EPwm5Regs.CMPA.half.CMPA = 0;
// Set actions
EPwm5Regs.AQCTLA.bit.ZRO = AQ_SET;
EPwm5Regs.AQCTLA.bit.CAU = AQ_CLEAR;
EPwm5Regs.AQCTLB.bit.ZRO = AQ_CLEAR;
EPwm5Regs.AQCTLB.bit.CAU = AQ_SET;
// Active HIGH PWMs - Setup Deadband
EPwm5Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE;
EPwm5Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC;
EPwm5Regs.DBCTL.bit.IN_MODE = DBA_ALL;
EPwm5Regs.DBRED = 90;
EPwm5Regs.DBFED = 90;
EPwm6Regs.TBPRD = 4500; // Set timer period
EPwm6Regs.TBPHS.half.TBPHS = 0x0000; // Phase is 0
EPwm6Regs.TBCTR = 0x0000; // Clear counter
// Setup TBCLK
EPwm6Regs.TBCTL.bit.CTRMODE = TB_COUNT_UP; // Count up
EPwm6Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Disable phase loading
EPwm6Regs.TBCTL.bit.PRDLD = TB_SHADOW;
EPwm6Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN;
EPwm6Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // Clock ratio to SYSCLKOUT
EPwm6Regs.TBCTL.bit.CLKDIV = TB_DIV1;
EPwm6Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Load registers every ZERO
EPwm6Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW;
EPwm6Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO;
EPwm6Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO;
// Setup compare
EPwm6Regs.CMPA.half.CMPA = 0;
// Set actions
EPwm6Regs.AQCTLA.bit.ZRO = AQ_SET;
EPwm6Regs.AQCTLA.bit.CAU = AQ_CLEAR;
EPwm6Regs.AQCTLA.bit.ZRO = AQ_CLEAR;
EPwm6Regs.AQCTLA.bit.CAU = AQ_SET;
EPwm6Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE;
EPwm6Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC;
EPwm6Regs.DBCTL.bit.IN_MODE = DBA_ALL;
EPwm6Regs.DBRED = 90;
EPwm6Regs.DBFED = 90;
EALLOW;
SysCtrlRegs.PCLKCR0.bit.TBCLKSYNC = 1;
EDIS;
Active High, Independent Outputs, Upcount, PWM4,5,6, to generate a ramp between two phases
EALLOW;
EDIS;
EPwm4Regs.TBPRD = 4500; // Period = 4500 TBCLK counts
EPwm4Regs.CMPA.half.CMPA = 0; // Compare A = 0 TBCLK counts
EPwm4Regs.CMPB = 0; // Compare B = 0 TBCLK counts
EPwm4Regs.TBCTR = 0; // clear TB counter
EPwm4Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Phase loading disabled
EPwm4Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // TBCLK = SYSCLK
EPwm4Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // load on CTR = Zero
EPwm4Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; // load on CTR = Zero
EPwm4Regs.AQCTLB.bit.ZRO = AQ_SET;
EPwm4Regs.AQCTLB.bit.CBU = AQ_CLEAR;
EPwm4Regs.DBCTL.bit.OUT_MODE = DB_DISABLE;
EPwm5Regs.TBPRD = 4500; // Period = 4500 TBCLK counts
EPwm5Regs.CMPA.half.CMPA = 0; // Compare A = 0 TBCLK counts
EPwm5Regs.CMPB = 0; // Compare B = 0 TBCLK counts
EPwm5Regs.TBCTR = 0; // clear TB counter
EPwm5Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Phase loading disabled
EPwm5Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // TBCLK = SYSCLK
EPwm5Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // load on CTR = Zero
EPwm5Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; // load on CTR = Zero
EPwm5Regs.AQCTLB.bit.ZRO = AQ_SET;
EPwm5Regs.AQCTLB.bit.CBU = AQ_CLEAR;
EPwm5Regs.DBCTL.bit.OUT_MODE = DB_DISABLE;
EPwm6Regs.TBPRD = 4500; // Period = 4500 TBCLK counts
EPwm6Regs.CMPA.half.CMPA = 0; // Compare A = 0 TBCLK counts
EPwm6Regs.CMPB = 0; // Compare B = 0 TBCLK counts
EPwm6Regs.TBCTR = 0; // clear TB counter
EPwm6Regs.TBCTL.bit.PHSEN = TB_DISABLE; // Phase loading disabled
EPwm6Regs.TBCTL.bit.HSPCLKDIV = TB_DIV1; // TBCLK = SYSCLK
EPwm6Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // load on CTR = Zero
EPwm6Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; // load on CTR = Zero
EPwm6Regs.AQCTLB.bit.ZRO = AQ_SET;
EPwm6Regs.AQCTLB.bit.CBU = AQ_CLEAR;
EPwm6Regs.DBCTL.bit.OUT_MODE = DB_DISABLE;
EALLOW;
EDIS;
Luis Gonçalves
