Other Parts Discussed in Thread: CONTROLSUITE
Tool/software: TI-RTOS
I was trying to send a pulse to ultrasonic sensor using ePWM and listen for echo signal. I also use eCAP to measure the time it takes to echo back.
However, I don't see any values stored in eCAP.. I'm using 3-pin ultrasonic sensor (28015). how can i configure the input and output?
GpioCtrlRegs.GPAMUX1.bit.GPIO5 = 1; // 0=GPIO, 1=EPWM3B, 2=Resv, 3=ECAP1
GpioCtrlRegs.GPADIR.bit.GPIO5 = 1; // 1=OUTput, 0=INput
GpioCtrlRegs.GPAMUX1.bit.GPIO5 = 3; // 0=GPIO, 1=EPWM3B, 2=Resv, 3=ECAP1
GpioCtrlRegs.GPADIR.bit.GPIO5 = 0; // 1=OUTput, 0=INput
EALLOW;
EPwm3Regs.TBCTL.bit.HSPCLKDIV = 5;
EPwm3Regs.TBCTL.bit.CLKDIV = 3;
EPwm3Regs.TBPRD = 48675; // 100 ms period
//EPwm3Regs.CMPA.half.CMPA = 8; // generate 10 us pulse
EPwm3Regs.CMPB = 8; // generate 10 us pulse
EPwm3Regs.TBPHS.half.TBPHS = 0;
EPwm3Regs.TBCTR = 0;
EPwm3Regs.TBCTL.bit.CTRMODE = 0;
EPwm3Regs.TBCTL.bit.PHSEN = 0;
EPwm3Regs.TBCTL.bit.PRDLD = 0;
EPwm3Regs.TBCTL.bit.SYNCOSEL = 2;
EPwm3Regs.CMPCTL.bit.SHDWBMODE = 1;
EPwm3Regs.CMPCTL.bit.LOADBMODE = 0;
EPwm3Regs.AQCTLB.bit.ZRO = 2;
EPwm3Regs.AQCTLB.bit.CAU = 1;
// Configure peripheral registers
ECap1Regs.ECCTL2.bit.CONT_ONESHT = 0; // continuous mode
ECap1Regs.ECCTL2.bit.STOP_WRAP = 3; // stop at 4 events
ECap1Regs.ECCTL1.bit.CAP1POL = 0; // Rising edge
ECap1Regs.ECCTL1.bit.CAP2POL = 1; // Falling edge
ECap1Regs.ECCTL1.bit.CAP3POL = 0; // Rising edge
ECap1Regs.ECCTL1.bit.CAP4POL = 1; // Falling edge
ECap1Regs.ECCTL1.bit.CTRRST1 = 1; // Difference operation
ECap1Regs.ECCTL1.bit.CTRRST2 = 1; // Difference operation
ECap1Regs.ECCTL1.bit.CTRRST3 = 1; // Difference operation
ECap1Regs.ECCTL1.bit.CTRRST4 = 1; // Difference operation
//ECap1Regs.ECCTL2.bit.CAP_APWM = 0; // Disable sync in
ECap1Regs.ECCTL2.bit.SYNCI_EN = 0; // Disable sync in
ECap1Regs.ECCTL2.bit.SYNCO_SEL = 3; // Disable
ECap1Regs.ECCTL1.bit.PRESCALE = 0; // Prescale = 1 /Disable
ECap1Regs.ECCTL1.bit.CAPLDEN = 1;
ECap1Regs.ECCTL2.bit.TSCTRSTOP = 1; // Start Counter
ECap1Regs.ECEINT.bit.CEVT4 = 1; // 4 events = interrupt
EDIS;
