TMS320F28069M: lab 02c Problem with identification process.
Part Number: TMS320F28069M
Other Parts Discussed in Thread: MOTORWARE
Hello Community,
I have problems with lab02c on my own inverter board.
Therefor I uploaded a short video which represents the issue.
https://youtu.be/fdOnzqp3vX0
I´m using the
C:\ti\motorware\motorware_1_01_00_18\sw\solutions\instaspin_foc\boards\drv8301kit_revD\f28x\f2806xF
examples, because I need 6 independent pwm´s.
I´m using the Aanheim Motor BLY172S.
The bench supply provides 24V and 6A.
I attached the user.h file the hal.c and some schematics of my hardware setup.
I have no idea how to contain the fault.
Is it right that I have to use lab02c for ID because the Motor is an low inductance type?
How can I implement that my motor just gets a specific amount of current during ID? I always have the problem that the voltage of the supply breaks down due to the current consumption.
Hopefully someone can help me.
Thank you in advance.
Martin.
81304.user.h
/* --COPYRIGHT--,BSD
 * Copyright (c) 2012, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 * *  Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 * --/COPYRIGHT--*/
//! \file   solutions/instaspin_foc/boards/drv8301kit_revD/f28x/f2806xF/src/hal.c
//! \brief Contains the various functions related to the HAL object (everything outside the CTRL system)
//! (C) Copyright 2011, Texas Instruments, Inc.
// the includes
// drivers
// modules
// platforms
#include "hal.h"
#include "user.h"
#include "hal_obj.h"
#ifdef FLASH
#pragma CODE_SECTION(HAL_setupFlash,"ramfuncs");
#endif
// the defines
#define US_TO_CNT(A) ((((long double) A * (long double)USER_SYSTEM_FREQ_MHz) - 9.0L) / 5.0L)
// the globals
HAL_Obj hal;
// the functions
void HAL_cal(HAL_Handle handle)
  HAL_Obj *obj = (HAL_Obj *)handle;
  // enable the ADC clock
  CLK_enableAdcClock(obj->clkHandle);
  // Run the Device_cal() function
  // This function copies the ADC and oscillator calibration values from TI reserved
  // OTP into the appropriate trim registers
  // This boot ROM automatically calls this function to calibrate the interal
  // oscillators and ADC with device specific calibration data.
  // If the boot ROM is bypassed by Code Composer Studio during the development process,
  // then the calibration must be initialized by the application
  ENABLE_PROTECTED_REGISTER_WRITE_MODE;
  (*Device_cal)();
  DISABLE_PROTECTED_REGISTER_WRITE_MODE;
  // run offsets calibration in user's memory
  HAL_AdcOffsetSelfCal(handle);
  // run oscillator compensation
  HAL_OscTempComp(handle);
  // disable the ADC clock
  CLK_disableAdcClock(obj->clkHandle);
  return;
} // end of HAL_cal() function
void HAL_OscTempComp(HAL_Handle handle)
  uint16_t Temperature;
  // disable the ADCs
  ADC_disable(obj->adcHandle);
  // power up the bandgap circuit
  ADC_enableBandGap(obj->adcHandle);
  // set the ADC voltage reference source to internal
  ADC_setVoltRefSrc(obj->adcHandle,ADC_VoltageRefSrc_Int);
  // enable the ADC reference buffers
  ADC_enableRefBuffers(obj->adcHandle);
  // Set main clock scaling factor (max45MHz clock for the ADC module)
  ADC_setDivideSelect(obj->adcHandle,ADC_DivideSelect_ClkIn_by_2);
  // power up the ADCs
  ADC_powerUp(obj->adcHandle);
  // enable the ADCs
  ADC_enable(obj->adcHandle);
  // enable non-overlap mode
  ADC_enableNoOverlapMode(obj->adcHandle);
  // connect channel A5 internally to the temperature sensor
  ADC_setTempSensorSrc(obj->adcHandle, ADC_TempSensorSrc_Int);
  // set SOC0 channel select to ADCINA5
  ADC_setSocChanNumber(obj->adcHandle, ADC_SocNumber_0, ADC_SocChanNumber_A5);
  // set SOC0 acquisition period to 26 ADCCLK
  ADC_setSocSampleDelay(obj->adcHandle, ADC_SocNumber_0, ADC_SocSampleDelay_64_cycles);
  // connect ADCINT1 to EOC0
  ADC_setIntSrc(obj->adcHandle, ADC_IntNumber_1, ADC_IntSrc_EOC0);
  // clear ADCINT1 flag
  ADC_clearIntFlag(obj->adcHandle, ADC_IntNumber_1);
  // enable ADCINT1
  ADC_enableInt(obj->adcHandle, ADC_IntNumber_1);
  // force start of conversion on SOC0
  ADC_setSocFrc(obj->adcHandle, ADC_SocFrc_0);
  // wait for end of conversion
  while (ADC_getIntFlag(obj->adcHandle, ADC_IntNumber_1) == 0){}
  Temperature = ADC_readResult(obj->adcHandle, ADC_ResultNumber_0);
  HAL_osc1Comp(handle, Temperature);
  HAL_osc2Comp(handle, Temperature);
  return;
} // end of HAL_OscTempComp() function
void HAL_osc1Comp(HAL_Handle handle, const int16_t sensorSample)
	int16_t compOscFineTrim;
    compOscFineTrim = ((sensorSample - getRefTempOffset())*(int32_t)getOsc1FineTrimSlope()
                      + OSC_POSTRIM_OFF + FP_ROUND )/FP_SCALE + getOsc1FineTrimOffset() - OSC_POSTRIM;
    if(compOscFineTrim > 31)
        compOscFineTrim = 31;
	else if(compOscFineTrim < -31)
        compOscFineTrim = -31;
    OSC_setTrim(obj->oscHandle, OSC_Number_1, HAL_getOscTrimValue(getOsc1CoarseTrim(), compOscFineTrim));
    return;
} // end of HAL_osc1Comp() function
void HAL_osc2Comp(HAL_Handle handle, const int16_t sensorSample)
    compOscFineTrim = ((sensorSample - getRefTempOffset())*(int32_t)getOsc2FineTrimSlope()
                      + OSC_POSTRIM_OFF + FP_ROUND )/FP_SCALE + getOsc2FineTrimOffset() - OSC_POSTRIM;
    OSC_setTrim(obj->oscHandle, OSC_Number_2, HAL_getOscTrimValue(getOsc2CoarseTrim(), compOscFineTrim));
    return;
} // end of HAL_osc2Comp() function
uint16_t HAL_getOscTrimValue(int16_t coarse, int16_t fine)
  uint16_t regValue = 0;
  if(fine < 0)
      regValue = ((-fine) | 0x20) << 9;
  else
      regValue = fine << 9;
  if(coarse < 0)
      regValue |= ((-coarse) | 0x80);
  else
      regValue |= coarse;
  return regValue;
} // end of HAL_getOscTrimValue() function
void HAL_AdcOffsetSelfCal(HAL_Handle handle)
  uint16_t AdcConvMean;
  // disable the ADCs
  // enable the ADCs
  //Select VREFLO internal connection on B5
  ADC_enableVoltRefLoConv(obj->adcHandle);
  //Select channel B5 for all SOC
  HAL_AdcCalChanSelect(handle, ADC_SocChanNumber_B5);
  //Apply artificial offset (+80) to account for a negative offset that may reside in the ADC core
  ADC_setOffTrim(obj->adcHandle, 80);
  //Capture ADC conversion on VREFLO
  AdcConvMean = HAL_AdcCalConversion(handle);
  //Set offtrim register with new value (i.e remove artical offset (+80) and create a two's compliment of the offset error)
  ADC_setOffTrim(obj->adcHandle, 80 - AdcConvMean);
  //Select external ADCIN5 input pin on B5
  ADC_disableVoltRefLoConv(obj->adcHandle);
  return;
} // end of HAL_AdcOffsetSelfCal() function
void HAL_AdcCalChanSelect(HAL_Handle handle, const ADC_SocChanNumber_e chanNumber)
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_0,chanNumber);
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_1,chanNumber);
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_2,chanNumber);
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_3,chanNumber);
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_4,chanNumber);
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_5,chanNumber);
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_6,chanNumber);
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_7,chanNumber);
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_8,chanNumber);
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_9,chanNumber);
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_10,chanNumber);
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_11,chanNumber);
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_12,chanNumber);
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_13,chanNumber);
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_14,chanNumber);
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_15,chanNumber);
  return;
} // end of HAL_AdcCalChanSelect() function
uint16_t HAL_AdcCalConversion(HAL_Handle handle)
  uint16_t index, SampleSize, Mean;
  uint32_t Sum;
  ADC_SocSampleDelay_e ACQPS_Value;
  index       = 0;     //initialize index to 0
  SampleSize  = 256;   //set sample size to 256 (**NOTE: Sample size must be multiples of 2^x where is an integer >= 4)
  Sum         = 0;     //set sum to 0
  Mean        = 999;   //initialize mean to known value
  //Set the ADC sample window to the desired value (Sample window = ACQPS + 1)
  ACQPS_Value = ADC_SocSampleDelay_7_cycles;
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_0,ACQPS_Value);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_1,ACQPS_Value);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_2,ACQPS_Value);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_3,ACQPS_Value);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_4,ACQPS_Value);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_5,ACQPS_Value);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_6,ACQPS_Value);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_7,ACQPS_Value);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_8,ACQPS_Value);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_9,ACQPS_Value);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_10,ACQPS_Value);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_11,ACQPS_Value);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_12,ACQPS_Value);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_13,ACQPS_Value);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_14,ACQPS_Value);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_15,ACQPS_Value);
  // Enabled ADCINT1 and ADCINT2
  ADC_enableInt(obj->adcHandle, ADC_IntNumber_2);
  // Disable continuous sampling for ADCINT1 and ADCINT2
  ADC_setIntMode(obj->adcHandle, ADC_IntNumber_1, ADC_IntMode_EOC);
  ADC_setIntMode(obj->adcHandle, ADC_IntNumber_2, ADC_IntMode_EOC);
  //ADCINTs trigger at end of conversion
  ADC_setIntPulseGenMode(obj->adcHandle, ADC_IntPulseGenMode_Prior);
  // Setup ADCINT1 and ADCINT2 trigger source
  ADC_setIntSrc(obj->adcHandle, ADC_IntNumber_1, ADC_IntSrc_EOC6);
  ADC_setIntSrc(obj->adcHandle, ADC_IntNumber_2, ADC_IntSrc_EOC14);
  // Setup each SOC's ADCINT trigger source
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_0, ADC_Int2TriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_1, ADC_Int2TriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_2, ADC_Int2TriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_3, ADC_Int2TriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_4, ADC_Int2TriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_5, ADC_Int2TriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_6, ADC_Int2TriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_7, ADC_Int2TriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_8, ADC_Int1TriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_9, ADC_Int1TriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_10, ADC_Int1TriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_11, ADC_Int1TriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_12, ADC_Int1TriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_13, ADC_Int1TriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_14, ADC_Int1TriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_15, ADC_Int1TriggersSOC);
  // Delay before converting ADC channels
  usDelay(US_TO_CNT(ADC_DELAY_usec));
  ADC_setSocFrcWord(obj->adcHandle, 0x00FF);
  while( index < SampleSize )
      //Wait for ADCINT1 to trigger, then add ADCRESULT0-7 registers to sum
      //Must clear ADCINT1 flag since INT1CONT = 0
      Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_0);
      Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_1);
      Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_2);
      Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_3);
      Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_4);
      Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_5);
      Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_6);
      Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_7);
      //Wait for ADCINT2 to trigger, then add ADCRESULT8-15 registers to sum
      while (ADC_getIntFlag(obj->adcHandle, ADC_IntNumber_2) == 0){}
      //Must clear ADCINT2 flag since INT2CONT = 0
      ADC_clearIntFlag(obj->adcHandle, ADC_IntNumber_2);
      Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_8);
      Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_9);
      Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_10);
      Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_11);
      Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_12);
      Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_13);
      Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_14);
      Sum += ADC_readResult(obj->adcHandle, ADC_ResultNumber_15);
      index+=16;
  } // end data collection
  //Disable ADCINT1 and ADCINT2 to STOP the ping-pong sampling
  ADC_disableInt(obj->adcHandle, ADC_IntNumber_1);
  ADC_disableInt(obj->adcHandle, ADC_IntNumber_2);
  //Calculate average ADC sample value
  Mean = Sum / SampleSize;
  // Clear start of conversion trigger
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_0, ADC_NoIntTriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_1, ADC_NoIntTriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_2, ADC_NoIntTriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_3, ADC_NoIntTriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_4, ADC_NoIntTriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_5, ADC_NoIntTriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_6, ADC_NoIntTriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_7, ADC_NoIntTriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_8, ADC_NoIntTriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_9, ADC_NoIntTriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_10, ADC_NoIntTriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_11, ADC_NoIntTriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_12, ADC_NoIntTriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_13, ADC_NoIntTriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_14, ADC_NoIntTriggersSOC);
  ADC_setupSocTrigSrc(obj->adcHandle, ADC_SocNumber_15, ADC_NoIntTriggersSOC);
  //return the average
  return(Mean);
} // end of HAL_AdcCalConversion() function
void HAL_disableWdog(HAL_Handle halHandle)
  HAL_Obj *hal = (HAL_Obj *)halHandle;
  WDOG_disable(hal->wdogHandle);
  return;
} // end of HAL_disableWdog() function
void HAL_disableGlobalInts(HAL_Handle handle)
  CPU_disableGlobalInts(obj->cpuHandle);
  return;
} // end of HAL_disableGlobalInts() function
void HAL_enableAdcInts(HAL_Handle handle)
  // enable the PIE interrupts associated with the ADC interrupts
  PIE_enableAdcInt(obj->pieHandle,ADC_IntNumber_1);
  // enable the ADC interrupts
  ADC_enableInt(obj->adcHandle,ADC_IntNumber_1);
  // enable the cpu interrupt for ADC interrupts
  CPU_enableInt(obj->cpuHandle,CPU_IntNumber_10);
  return;
} // end of HAL_enableAdcInts() function
void HAL_enableDebugInt(HAL_Handle handle)
  CPU_enableDebugInt(obj->cpuHandle);
  return;
} // end of HAL_enableDebugInt() function
void HAL_enableDrv(HAL_Handle handle)
  DRV8301_enable(obj->drv8301Handle);
  return;
}  // end of HAL_enableDrv() function
void HAL_enableGlobalInts(HAL_Handle handle)
  CPU_enableGlobalInts(obj->cpuHandle);
  return;
} // end of HAL_enableGlobalInts() function
void HAL_enablePwmInt(HAL_Handle handle)
  PIE_enablePwmInt(obj->pieHandle,PWM_Number_1);
  // enable the interrupt
  PWM_enableInt(obj->pwmHandle[PWM_Number_1]);
  // enable the cpu interrupt for EPWM1_INT
  CPU_enableInt(obj->cpuHandle,CPU_IntNumber_3);
  return;
} // end of HAL_enablePwmInt() function
void HAL_enableTimer0Int(HAL_Handle handle)
  PIE_enableTimer0Int(obj->pieHandle);
  TIMER_enableInt(obj->timerHandle[0]);
  // enable the cpu interrupt for TINT0
  CPU_enableInt(obj->cpuHandle,CPU_IntNumber_1);
  return;
void HAL_setupFaults(HAL_Handle handle)
  uint_least8_t cnt;
  // Configure Trip Mechanism for the Motor control software
  // -Cycle by cycle trip on CPU halt
  // -One shot fault trip zone
  // These trips need to be repeated for EPWM1 ,2 & 3
  for(cnt=0;cnt<3;cnt++)
      PWM_enableTripZoneSrc(obj->pwmHandle[cnt],PWM_TripZoneSrc_CycleByCycle_TZ6_NOT);
      PWM_enableTripZoneSrc(obj->pwmHandle[cnt],PWM_TripZoneSrc_CycleByCycle_TZ3_NOT);
      PWM_enableTripZoneSrc(obj->pwmHandle[cnt],PWM_TripZoneSrc_CycleByCycle_TZ2_NOT);
      // What do we want the OST/CBC events to do?
      // TZA events can force EPWMxA
      // TZB events can force EPWMxB
      PWM_setTripZoneState_TZA(obj->pwmHandle[cnt],PWM_TripZoneState_EPWM_Low);
      PWM_setTripZoneState_TZB(obj->pwmHandle[cnt],PWM_TripZoneState_EPWM_Low);
  return;
} // end of HAL_setupFaults() function
HAL_Handle HAL_init(void *pMemory,const size_t numBytes)
  uint_least8_t cnt;
  HAL_Handle handle;
  HAL_Obj *obj;
  if(numBytes < sizeof(HAL_Obj))
    return((HAL_Handle)NULL);
  // assign the handle
  handle = (HAL_Handle)pMemory;
  // assign the object
  // initialize the watchdog driver
  obj->wdogHandle = WDOG_init((void *)WDOG_BASE_ADDR,sizeof(WDOG_Obj));
  // disable watchdog
  HAL_disableWdog(handle);
  // initialize the ADC
  obj->adcHandle = ADC_init((void *)ADC_BASE_ADDR,sizeof(ADC_Obj));
  // initialize the clock handle
  obj->clkHandle = CLK_init((void *)CLK_BASE_ADDR,sizeof(CLK_Obj));
  // initialize the CPU handle
  obj->cpuHandle = CPU_init(&cpu,sizeof(cpu));
  // initialize the FLASH handle
  obj->flashHandle = FLASH_init((void *)FLASH_BASE_ADDR,sizeof(FLASH_Obj));
  // initialize the GPIO handle
  obj->gpioHandle = GPIO_init((void *)GPIO_BASE_ADDR,sizeof(GPIO_Obj));
  // initialize the current offset estimator handles
  for(cnt=0;cnt<USER_NUM_CURRENT_SENSORS;cnt++)
      obj->offsetHandle_I[cnt] = OFFSET_init(&obj->offset_I[cnt],sizeof(obj->offset_I[cnt]));
  // initialize the voltage offset estimator handles
  for(cnt=0;cnt<USER_NUM_VOLTAGE_SENSORS;cnt++)
      obj->offsetHandle_V[cnt] = OFFSET_init(&obj->offset_V[cnt],sizeof(obj->offset_V[cnt]));
  // initialize the oscillator handle
  obj->oscHandle = OSC_init((void *)OSC_BASE_ADDR,sizeof(OSC_Obj));
  // initialize the PIE handle
  obj->pieHandle = PIE_init((void *)PIE_BASE_ADDR,sizeof(PIE_Obj));
  // initialize the PLL handle
  obj->pllHandle = PLL_init((void *)PLL_BASE_ADDR,sizeof(PLL_Obj));
  // initialize the SPI handles
  obj->spiAHandle = SPI_init((void *)SPIA_BASE_ADDR,sizeof(SPI_Obj));
  obj->spiBHandle = SPI_init((void *)SPIB_BASE_ADDR,sizeof(SPI_Obj));
  // initialize PWM handles
  obj->pwmHandle[0] = PWM_init((void *)PWM_ePWM1_BASE_ADDR,sizeof(PWM_Obj)); //Phase A
  obj->pwmHandle[1] = PWM_init((void *)PWM_ePWM2_BASE_ADDR,sizeof(PWM_Obj)); //Phase B
  obj->pwmHandle[2] = PWM_init((void *)PWM_ePWM3_BASE_ADDR,sizeof(PWM_Obj)); //Phase C
  // initialize PWM DAC handles
  obj->pwmDacHandle[0] = PWMDAC_init((void *)PWM_ePWM6_BASE_ADDR,sizeof(PWM_Obj));
  obj->pwmDacHandle[1] = PWMDAC_init((void *)PWM_ePWM5_BASE_ADDR,sizeof(PWM_Obj));
  obj->pwmDacHandle[2] = PWMDAC_init((void *)PWM_ePWM4_BASE_ADDR,sizeof(PWM_Obj));
  // initialize power handle
  obj->pwrHandle = PWR_init((void *)PWR_BASE_ADDR,sizeof(PWR_Obj));
  // initialize timer handles
  obj->timerHandle[0] = TIMER_init((void *)TIMER0_BASE_ADDR,sizeof(TIMER_Obj));
  obj->timerHandle[1] = TIMER_init((void *)TIMER1_BASE_ADDR,sizeof(TIMER_Obj));
  obj->timerHandle[2] = TIMER_init((void *)TIMER2_BASE_ADDR,sizeof(TIMER_Obj));
  // initialize drv8301 interface
  obj->drv8301Handle = DRV8301_init(&obj->drv8301,sizeof(obj->drv8301));
#ifdef QEP
  // initialize QEP driver
  obj->qepHandle[0] = QEP_init((void*)QEP1_BASE_ADDR,sizeof(QEP_Obj));
#endif
  return(handle);
} // end of HAL_init() function
void HAL_setParams(HAL_Handle handle,const USER_Params *pUserParams)
  uint_least8_t cnt;
  _iq beta_lp_pu = _IQ(pUserParams->offsetPole_rps/(float_t)pUserParams->ctrlFreq_Hz);
  HAL_setNumCurrentSensors(handle,pUserParams->numCurrentSensors);
  HAL_setNumVoltageSensors(handle,pUserParams->numVoltageSensors);
  for(cnt=0;cnt<HAL_getNumCurrentSensors(handle);cnt++)
      HAL_setOffsetBeta_lp_pu(handle,HAL_SensorType_Current,cnt,beta_lp_pu);
      HAL_setOffsetInitCond(handle,HAL_SensorType_Current,cnt,_IQ(0.0));
      HAL_setOffsetValue(handle,HAL_SensorType_Current,cnt,_IQ(0.0));
  for(cnt=0;cnt<HAL_getNumVoltageSensors(handle);cnt++)
      HAL_setOffsetBeta_lp_pu(handle,HAL_SensorType_Voltage,cnt,beta_lp_pu);
      HAL_setOffsetInitCond(handle,HAL_SensorType_Voltage,cnt,_IQ(0.0));
      HAL_setOffsetValue(handle,HAL_SensorType_Voltage,cnt,_IQ(0.0));
  // disable global interrupts
  // disable cpu interrupts
  CPU_disableInts(obj->cpuHandle);
  // clear cpu interrupt flags
  CPU_clearIntFlags(obj->cpuHandle);
  // setup the clocks
  HAL_setupClks(handle);
  // Setup the PLL
  HAL_setupPll(handle,PLL_ClkFreq_90_MHz);
  // setup the PIE
  HAL_setupPie(handle);
  // run the device calibration
  HAL_cal(handle);
  // setup the peripheral clocks
  HAL_setupPeripheralClks(handle);
  // setup the GPIOs
  HAL_setupGpios(handle);
  // setup the flash
  HAL_setupFlash(handle);
  // setup the ADCs
  HAL_setupAdcs(handle);
  // setup the PWMs
  HAL_setupPwms(handle,
                (float_t)pUserParams->systemFreq_MHz,
                pUserParams->pwmPeriod_usec,
                USER_NUM_PWM_TICKS_PER_ISR_TICK);
#ifdef QEP
  // setup the QEP
  HAL_setupQEP(handle,HAL_Qep_QEP1);
#endif
  // setup the spiA
  HAL_setupSpiA(handle);
  // setup the spiB
  HAL_setupSpiB(handle);
  // setup the PWM DACs
  HAL_setupPwmDacs(handle);
  // setup the timers
  HAL_setupTimers(handle,
                  (float_t)pUserParams->systemFreq_MHz);
  // setup the drv8301 interface
  HAL_setupGate(handle);
  // set the default current bias
   uint_least8_t cnt;
   _iq bias = _IQ12mpy(ADC_dataBias,_IQ(pUserParams->current_sf));
       HAL_setBias(handle,HAL_SensorType_Current,cnt,bias);
  //  set the current scale factor
   _iq current_sf = _IQ(pUserParams->current_sf);
  HAL_setCurrentScaleFactor(handle,current_sf);
  // set the default voltage bias
   uint_least8_t cnt;
   _iq bias = _IQ(0.0);
       HAL_setBias(handle,HAL_SensorType_Voltage,cnt,bias);
  //  set the voltage scale factor
   _iq voltage_sf = _IQ(pUserParams->voltage_sf);
  HAL_setVoltageScaleFactor(handle,voltage_sf);
 return;
} // end of HAL_setParams() function
void HAL_setupAdcs(HAL_Handle handle)
  // disable the ADCs
  // enable the ADCs
  // set the ADC interrupt pulse generation to prior
  ADC_setIntPulseGenMode(obj->adcHandle,ADC_IntPulseGenMode_Prior);
  // set the temperature sensor source to external
  ADC_setTempSensorSrc(obj->adcHandle,ADC_TempSensorSrc_Ext);
  // configure the interrupt sources
  ADC_disableInt(obj->adcHandle,ADC_IntNumber_1);
  ADC_setIntMode(obj->adcHandle,ADC_IntNumber_1,ADC_IntMode_ClearFlag);
  ADC_setIntSrc(obj->adcHandle,ADC_IntNumber_1,ADC_IntSrc_EOC7);
  // default cycles = 9!
  //configure the SOCs for drv8301kit_revD
  // EXT IA-FB
  //ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_0,ADC_SocChanNumber_A6);      //default f�r drv8301kit_revD
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_0,ADC_SocChanNumber_A1);        // custom Board config.
  ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_0,ADC_SocTrigSrc_EPWM1_ADCSOCA);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_0,ADC_SocSampleDelay_9_cycles);
  // EXT IA-FB
  // Duplicate conversion due to ADC Initial Conversion bug (SPRZ342)
  //ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_1,ADC_SocChanNumber_A6);      //default f�r drv8301kit_revD
  ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_1,ADC_SocTrigSrc_EPWM1_ADCSOCA);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_1,ADC_SocSampleDelay_9_cycles);
  // EXT IB-FB
  //ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_2,ADC_SocChanNumber_B6);      //default f�r drv8301kit_revD
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_2,ADC_SocChanNumber_A5);        //custom Board config.
  ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_2,ADC_SocTrigSrc_EPWM1_ADCSOCA);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_2,ADC_SocSampleDelay_9_cycles);
  // EXT IC-FB
  //ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_3,ADC_SocChanNumber_A0);        // default f�r drv8301kit_revD
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_3,ADC_SocChanNumber_B5);          //custom Board config.
  ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_3,ADC_SocTrigSrc_EPWM1_ADCSOCA);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_3,ADC_SocSampleDelay_9_cycles);
  // ADC-Vhb1 phase A (U)
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_4,ADC_SocChanNumber_B7);
  ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_4,ADC_SocTrigSrc_EPWM1_ADCSOCA);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_4,ADC_SocSampleDelay_9_cycles);
  // ADC-Vhb2 phase B (V)
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_5,ADC_SocChanNumber_A7);
  ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_5,ADC_SocTrigSrc_EPWM1_ADCSOCA);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_5,ADC_SocSampleDelay_9_cycles);
  // ADC-Vhb3 phase C (W)
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_6,ADC_SocChanNumber_B4);
  ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_6,ADC_SocTrigSrc_EPWM1_ADCSOCA);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_6,ADC_SocSampleDelay_9_cycles);
  // VDCBUS
  ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_7,ADC_SocChanNumber_B2);
  ADC_setSocTrigSrc(obj->adcHandle,ADC_SocNumber_7,ADC_SocTrigSrc_EPWM1_ADCSOCA);
  ADC_setSocSampleDelay(obj->adcHandle,ADC_SocNumber_7,ADC_SocSampleDelay_9_cycles);
  return;
} // end of HAL_setupAdcs() function
void HAL_setupClks(HAL_Handle handle)
  // enable internal oscillator 1
  CLK_enableOsc1(obj->clkHandle);
  // set the oscillator source
  CLK_setOscSrc(obj->clkHandle,CLK_OscSrc_Internal);
  // disable the external clock in
  CLK_disableClkIn(obj->clkHandle);
  // disable the crystal oscillator
  CLK_disableCrystalOsc(obj->clkHandle);
  // disable oscillator 2
  CLK_disableOsc2(obj->clkHandle);
  // set the low speed clock prescaler
  CLK_setLowSpdPreScaler(obj->clkHandle,CLK_LowSpdPreScaler_SysClkOut_by_1);
  // set the clock out prescaler
  CLK_setClkOutPreScaler(obj->clkHandle,CLK_ClkOutPreScaler_SysClkOut_by_1);
  return;
} // end of HAL_setupClks() function
void HAL_setupFlash(HAL_Handle handle)
  FLASH_enablePipelineMode(obj->flashHandle);
  FLASH_setNumPagedReadWaitStates(obj->flashHandle,FLASH_NumPagedWaitStates_3);
  FLASH_setNumRandomReadWaitStates(obj->flashHandle,FLASH_NumRandomWaitStates_3);
  FLASH_setOtpWaitStates(obj->flashHandle,FLASH_NumOtpWaitStates_5);
  FLASH_setStandbyWaitCount(obj->flashHandle,FLASH_STANDBY_WAIT_COUNT_DEFAULT);
  FLASH_setActiveWaitCount(obj->flashHandle,FLASH_ACTIVE_WAIT_COUNT_DEFAULT);
  return;
} // HAL_setupFlash() function
void HAL_setupGate(HAL_Handle handle)
  DRV8301_setSpiHandle(obj->drv8301Handle,obj->spiBHandle);
  DRV8301_setGpioHandle(obj->drv8301Handle,obj->gpioHandle);
  DRV8301_setGpioNumber(obj->drv8301Handle,GPIO_Number_51);
  return;
} // HAL_setupGate() function
void HAL_setupGpios(HAL_Handle handle)
  // Hier k�nnen die PIN-Configurationen der PWMs ge�ndert werden!!!
  // PWM1H phase A
  GPIO_setMode(obj->gpioHandle,GPIO_Number_0,GPIO_0_Mode_EPWM1A);
  // PWM21L phase A
  GPIO_setMode(obj->gpioHandle,GPIO_Number_1,GPIO_1_Mode_EPWM1B);
  // PWM2H phase B
  GPIO_setMode(obj->gpioHandle,GPIO_Number_2,GPIO_2_Mode_EPWM2A);
  // PWM2L phase B
  GPIO_setMode(obj->gpioHandle,GPIO_Number_3,GPIO_3_Mode_EPWM2B);
  // PWM3H phase C
  GPIO_setMode(obj->gpioHandle,GPIO_Number_4,GPIO_4_Mode_EPWM3A);
  // PWM3L phase C
  GPIO_setMode(obj->gpioHandle,GPIO_Number_5,GPIO_5_Mode_EPWM3B);
  // PWM-DAC4
  GPIO_setMode(obj->gpioHandle,GPIO_Number_6,GPIO_6_Mode_EPWM4A);
  // Push Button SW2
  GPIO_setMode(obj->gpioHandle,GPIO_Number_7,GPIO_7_Mode_GeneralPurpose);
  GPIO_setDirection(obj->gpioHandle,GPIO_Number_7,GPIO_Direction_Input);
  // ADCSOCAO_NOT or PWM-DAC3
  GPIO_setMode(obj->gpioHandle,GPIO_Number_8,GPIO_8_Mode_EPWM5A);
  // Push Button SW1
  GPIO_setMode(obj->gpioHandle,GPIO_Number_9,GPIO_9_Mode_GeneralPurpose);
  // PWM-DAC1
  GPIO_setMode(obj->gpioHandle,GPIO_Number_10,GPIO_10_Mode_EPWM6A);
  // PWM-DAC2
  GPIO_setMode(obj->gpioHandle,GPIO_Number_11,GPIO_11_Mode_EPWM6B);
  // DRV8301-LED1
  GPIO_setMode(obj->gpioHandle,GPIO_Number_12,GPIO_12_Mode_GeneralPurpose);
  GPIO_setLow(obj->gpioHandle,GPIO_Number_12);
  GPIO_setDirection(obj->gpioHandle,GPIO_Number_12,GPIO_Direction_Output);
  // OCTWn
  GPIO_setMode(obj->gpioHandle,GPIO_Number_13,GPIO_13_Mode_TZ2_NOT);
  // FAULTn
  GPIO_setMode(obj->gpioHandle,GPIO_Number_14,GPIO_14_Mode_TZ3_NOT);
  // LED2
  GPIO_setMode(obj->gpioHandle,GPIO_Number_15,GPIO_15_Mode_GeneralPurpose);
  // Set Qualification Period for GPIO16-23, 5*2*(1/90MHz) = 0.11us
  GPIO_setQualificationPeriod(obj->gpioHandle,GPIO_Number_16,5);
  // SPI-SIMO
  GPIO_setMode(obj->gpioHandle,GPIO_Number_16,GPIO_16_Mode_SPISIMOA);
//  GPIO_setPullup(obj->gpioHandle,GPIO_Number_16, GPIO_Pullup_Enable);
  // SPI-SOMI
  GPIO_setMode(obj->gpioHandle,GPIO_Number_17,GPIO_17_Mode_SPISOMIA);
//  GPIO_setPullup(obj->gpioHandle,GPIO_Number_17, GPIO_Pullup_Enable);
  // SPI-CLK
  GPIO_setMode(obj->gpioHandle,GPIO_Number_18,GPIO_18_Mode_SPICLKA);
//  GPIO_setPullup(obj->gpioHandle,GPIO_Number_18, GPIO_Pullup_Enable);
  // SPI-STE
  GPIO_setMode(obj->gpioHandle,GPIO_Number_19,GPIO_19_Mode_SPISTEA_NOT);
//  GPIO_setPullup(obj->gpioHandle,GPIO_Number_19, GPIO_Pullup_Enable);
#ifdef QEP
  // EQEPA
  GPIO_setMode(obj->gpioHandle,GPIO_Number_20,GPIO_20_Mode_EQEP1A);
  GPIO_setQualification(obj->gpioHandle,GPIO_Number_20,GPIO_Qual_Sample_3);
  // EQEPB
  GPIO_setMode(obj->gpioHandle,GPIO_Number_21,GPIO_21_Mode_EQEP1B);
  GPIO_setQualification(obj->gpioHandle,GPIO_Number_21,GPIO_Qual_Sample_3);
  // STATUS
  GPIO_setMode(obj->gpioHandle,GPIO_Number_22,GPIO_22_Mode_GeneralPurpose);
  // EQEP1I
  GPIO_setMode(obj->gpioHandle,GPIO_Number_23,GPIO_23_Mode_EQEP1I);
  GPIO_setQualification(obj->gpioHandle,GPIO_Number_23,GPIO_Qual_Sample_3);
#else
  // EQEPA
  GPIO_setMode(obj->gpioHandle,GPIO_Number_20,GPIO_20_Mode_GeneralPurpose);
  // EQEPB
  GPIO_setMode(obj->gpioHandle,GPIO_Number_21,GPIO_21_Mode_GeneralPurpose);
  // STATUS
  // EQEP1I
  GPIO_setMode(obj->gpioHandle,GPIO_Number_23,GPIO_23_Mode_GeneralPurpose);
#endif
  // SPI SIMO B
  GPIO_setMode(obj->gpioHandle,GPIO_Number_24,GPIO_24_Mode_SPISIMOB);
  // SPI SOMI B
  GPIO_setMode(obj->gpioHandle,GPIO_Number_25,GPIO_25_Mode_SPISOMIB);
  // SPI CLK B
  GPIO_setMode(obj->gpioHandle,GPIO_Number_26,GPIO_26_Mode_SPICLKB);
  // SPI CSn B
  GPIO_setMode(obj->gpioHandle,GPIO_Number_27,GPIO_27_Mode_SPISTEB_NOT);
  // No Connection
  GPIO_setMode(obj->gpioHandle,GPIO_Number_28,GPIO_28_Mode_GeneralPurpose);
  // No Connection
  GPIO_setMode(obj->gpioHandle,GPIO_Number_29,GPIO_29_Mode_GeneralPurpose);
  // No Connection
  GPIO_setMode(obj->gpioHandle,GPIO_Number_30,GPIO_30_Mode_GeneralPurpose);
  // ControlCARD LED2
  GPIO_setMode(obj->gpioHandle,GPIO_Number_31,GPIO_31_Mode_GeneralPurpose);
  GPIO_setLow(obj->gpioHandle,GPIO_Number_31);
  GPIO_setDirection(obj->gpioHandle,GPIO_Number_31,GPIO_Direction_Output);
  // No Connection
  GPIO_setMode(obj->gpioHandle,GPIO_Number_32,GPIO_32_Mode_GeneralPurpose);
  // No Connection
  GPIO_setMode(obj->gpioHandle,GPIO_Number_33,GPIO_33_Mode_GeneralPurpose);
  // ControlCARD LED3
  GPIO_setMode(obj->gpioHandle,GPIO_Number_34,GPIO_34_Mode_GeneralPurpose);
  GPIO_setLow(obj->gpioHandle,GPIO_Number_34);
  GPIO_setDirection(obj->gpioHandle,GPIO_Number_34,GPIO_Direction_Output);
  // JTAG
  GPIO_setMode(obj->gpioHandle,GPIO_Number_35,GPIO_35_Mode_JTAG_TDI);
  GPIO_setMode(obj->gpioHandle,GPIO_Number_36,GPIO_36_Mode_JTAG_TMS);
  GPIO_setMode(obj->gpioHandle,GPIO_Number_37,GPIO_37_Mode_JTAG_TDO);
  GPIO_setMode(obj->gpioHandle,GPIO_Number_38,GPIO_38_Mode_JTAG_TCK);
  // DRV8301 Enable
  GPIO_setMode(obj->gpioHandle,GPIO_Number_39,GPIO_39_Mode_GeneralPurpose);
  // CAP1
  GPIO_setMode(obj->gpioHandle,GPIO_Number_40,GPIO_40_Mode_GeneralPurpose);
  GPIO_setDirection(obj->gpioHandle,GPIO_Number_40,GPIO_Direction_Input);
  // CAP2
  GPIO_setMode(obj->gpioHandle,GPIO_Number_41,GPIO_41_Mode_GeneralPurpose);
  GPIO_setDirection(obj->gpioHandle,GPIO_Number_41,GPIO_Direction_Input);
  // CAP3
  GPIO_setMode(obj->gpioHandle,GPIO_Number_42,GPIO_42_Mode_GeneralPurpose);
  GPIO_setDirection(obj->gpioHandle,GPIO_Number_42,GPIO_Direction_Input);
  // DC_CAL
  GPIO_setMode(obj->gpioHandle,GPIO_Number_43,GPIO_43_Mode_GeneralPurpose);
  // No Connection
  GPIO_setMode(obj->gpioHandle,GPIO_Number_44,GPIO_44_Mode_GeneralPurpose);
  // No Connection
  GPIO_setMode(obj->gpioHandle,GPIO_Number_50,GPIO_50_Mode_GeneralPurpose);
  // DRV8301 Enable
  GPIO_setMode(obj->gpioHandle,GPIO_Number_51,GPIO_51_Mode_GeneralPurpose);
  GPIO_setLow(obj->gpioHandle,GPIO_Number_51);
  GPIO_setDirection(obj->gpioHandle,GPIO_Number_51,GPIO_Direction_Output);
  // No Connection
  GPIO_setMode(obj->gpioHandle,GPIO_Number_52,GPIO_52_Mode_GeneralPurpose);
  // No Connection
  GPIO_setMode(obj->gpioHandle,GPIO_Number_53,GPIO_53_Mode_GeneralPurpose);
  // No Connection
  GPIO_setMode(obj->gpioHandle,GPIO_Number_54,GPIO_54_Mode_GeneralPurpose);
  // No Connection
  GPIO_setMode(obj->gpioHandle,GPIO_Number_55,GPIO_55_Mode_GeneralPurpose);
  // No Connection
  GPIO_setMode(obj->gpioHandle,GPIO_Number_56,GPIO_56_Mode_GeneralPurpose);
  // No Connection
  GPIO_setMode(obj->gpioHandle,GPIO_Number_57,GPIO_57_Mode_GeneralPurpose);
  // No Connection
  GPIO_setMode(obj->gpioHandle,GPIO_Number_58,GPIO_58_Mode_GeneralPurpose);
  return;
}  // end of HAL_setupGpios() function
void HAL_setupPie(HAL_Handle handle)
  PIE_disable(obj->pieHandle);
  PIE_disableAllInts(obj->pieHandle);
  PIE_clearAllInts(obj->pieHandle);
  PIE_clearAllFlags(obj->pieHandle);
  PIE_setDefaultIntVectorTable(obj->pieHandle);
  PIE_enable(obj->pieHandle);
  return;
} // end of HAL_setupPie() function
void HAL_setupPeripheralClks(HAL_Handle handle)
  CLK_enableCompClock(obj->clkHandle,CLK_CompNumber_1);
  CLK_enableCompClock(obj->clkHandle,CLK_CompNumber_2);
  CLK_enableCompClock(obj->clkHandle,CLK_CompNumber_3);
  CLK_enableEcap1Clock(obj->clkHandle);
  CLK_disableEcanaClock(obj->clkHandle);
#ifdef QEP
  CLK_enableEqep1Clock(obj->clkHandle);
  CLK_enableEqep2Clock(obj->clkHandle);
#endif
  CLK_enablePwmClock(obj->clkHandle,PWM_Number_1);
  CLK_enablePwmClock(obj->clkHandle,PWM_Number_2);
  CLK_enablePwmClock(obj->clkHandle,PWM_Number_3);
  CLK_enablePwmClock(obj->clkHandle,PWM_Number_4);
  CLK_enablePwmClock(obj->clkHandle,PWM_Number_5);
  CLK_enablePwmClock(obj->clkHandle,PWM_Number_6);
  CLK_enablePwmClock(obj->clkHandle,PWM_Number_7);
  CLK_disableHrPwmClock(obj->clkHandle);
  CLK_disableI2cClock(obj->clkHandle);
  CLK_disableLinAClock(obj->clkHandle);
  CLK_disableClaClock(obj->clkHandle);
  CLK_enableSciaClock(obj->clkHandle);
  CLK_enableSpiaClock(obj->clkHandle);
  CLK_enableSpibClock(obj->clkHandle);
  CLK_enableTbClockSync(obj->clkHandle);
  return;
} // end of HAL_setupPeripheralClks() function
void HAL_setupPll(HAL_Handle handle,const PLL_ClkFreq_e clkFreq)
  // make sure PLL is not running in limp mode
  if(PLL_getClkStatus(obj->pllHandle) != PLL_ClkStatus_Normal)
      // reset the clock detect
      PLL_resetClkDetect(obj->pllHandle);
      asm("        ESTOP0");
  // Divide Select must be ClkIn/4 before the clock rate can be changed
  if(PLL_getDivideSelect(obj->pllHandle) != PLL_DivideSelect_ClkIn_by_4)
      PLL_setDivideSelect(obj->pllHandle,PLL_DivideSelect_ClkIn_by_4);
  if(PLL_getClkFreq(obj->pllHandle) != clkFreq)
      // disable the clock detect
      PLL_disableClkDetect(obj->pllHandle);
      // set the clock rate
      PLL_setClkFreq(obj->pllHandle,clkFreq);
  // wait until locked
  while(PLL_getLockStatus(obj->pllHandle) != PLL_LockStatus_Done) {}
  // enable the clock detect
  PLL_enableClkDetect(obj->pllHandle);
  // set divide select to ClkIn/2 to get desired clock rate
  // NOTE: clock must be locked before setting this register
  PLL_setDivideSelect(obj->pllHandle,PLL_DivideSelect_ClkIn_by_2);
  return;
} // end of HAL_setupPll() function
void HAL_setupPwms(HAL_Handle handle,
                   const float_t systemFreq_MHz,
                   const float_t pwmPeriod_usec,
                   const uint_least16_t numPwmTicksPerIsrTick)
  uint16_t   halfPeriod_cycles = (uint16_t)(systemFreq_MHz*pwmPeriod_usec) >> 1;
  uint_least8_t    cnt;
  // turns off the outputs of the EPWM peripherals which will put the power switches
  // into a high impedance state.
  PWM_setOneShotTrip(obj->pwmHandle[PWM_Number_1]);
  PWM_setOneShotTrip(obj->pwmHandle[PWM_Number_2]);
  PWM_setOneShotTrip(obj->pwmHandle[PWM_Number_3]);
  // first step to synchronize the pwms
  CLK_disableTbClockSync(obj->clkHandle);
      // setup the Time-Base Control Register (TBCTL)
      PWM_setCounterMode(obj->pwmHandle[cnt],PWM_CounterMode_UpDown);
      PWM_disableCounterLoad(obj->pwmHandle[cnt]);
      PWM_setPeriodLoad(obj->pwmHandle[cnt],PWM_PeriodLoad_Immediate);
      PWM_setSyncMode(obj->pwmHandle[cnt],PWM_SyncMode_EPWMxSYNC);
      PWM_setHighSpeedClkDiv(obj->pwmHandle[cnt],PWM_HspClkDiv_by_1);
      PWM_setClkDiv(obj->pwmHandle[cnt],PWM_ClkDiv_by_1);
      PWM_setPhaseDir(obj->pwmHandle[cnt],PWM_PhaseDir_CountUp);
      PWM_setRunMode(obj->pwmHandle[cnt],PWM_RunMode_FreeRun);
      // setup the Timer-Based Phase Register (TBPHS)
      PWM_setPhase(obj->pwmHandle[cnt],0);
      // setup the Time-Base Counter Register (TBCTR)
      PWM_setCount(obj->pwmHandle[cnt],0);
      // setup the Time-Base Period Register (TBPRD)
      // set to zero initially
      PWM_setPeriod(obj->pwmHandle[cnt],0);
      // setup the Counter-Compare Control Register (CMPCTL)
      PWM_setLoadMode_CmpA(obj->pwmHandle[cnt],PWM_LoadMode_Zero);
      PWM_setLoadMode_CmpB(obj->pwmHandle[cnt],PWM_LoadMode_Zero);
      PWM_setShadowMode_CmpA(obj->pwmHandle[cnt],PWM_ShadowMode_Shadow);
      PWM_setShadowMode_CmpB(obj->pwmHandle[cnt],PWM_ShadowMode_Immediate);
      // setup the Action-Qualifier Output A Register (AQCTLA)
      PWM_setActionQual_CntUp_CmpA_PwmA(obj->pwmHandle[cnt],PWM_ActionQual_Set);
      PWM_setActionQual_CntDown_CmpA_PwmA(obj->pwmHandle[cnt],PWM_ActionQual_Clear);
      // setup the Dead-Band Generator Control Register (DBCTL)
      PWM_setDeadBandOutputMode(obj->pwmHandle[cnt],PWM_DeadBandOutputMode_EPWMxA_Rising_EPWMxB_Falling);
      PWM_setDeadBandPolarity(obj->pwmHandle[cnt],PWM_DeadBandPolarity_EPWMxB_Inverted);
      // setup the Dead-Band Rising Edge Delay Register (DBRED)
      PWM_setDeadBandRisingEdgeDelay(obj->pwmHandle[cnt],HAL_PWM_DBRED_CNT);
      // setup the Dead-Band Falling Edge Delay Register (DBFED)
      PWM_setDeadBandFallingEdgeDelay(obj->pwmHandle[cnt],HAL_PWM_DBFED_CNT);
      // setup the PWM-Chopper Control Register (PCCTL)
      PWM_disableChopping(obj->pwmHandle[cnt]);
      // setup the Trip Zone Select Register (TZSEL)
      PWM_disableTripZones(obj->pwmHandle[cnt]);
  // setup the Event Trigger Selection Register (ETSEL)
  PWM_disableInt(obj->pwmHandle[PWM_Number_1]);
  PWM_setSocAPulseSrc(obj->pwmHandle[PWM_Number_1],PWM_SocPulseSrc_CounterEqualZero);
  PWM_enableSocAPulse(obj->pwmHandle[PWM_Number_1]);
  // setup the Event Trigger Prescale Register (ETPS)
  if(numPwmTicksPerIsrTick == 3)
      PWM_setIntPeriod(obj->pwmHandle[PWM_Number_1],PWM_IntPeriod_ThirdEvent);
      PWM_setSocAPeriod(obj->pwmHandle[PWM_Number_1],PWM_SocPeriod_ThirdEvent);
  else if(numPwmTicksPerIsrTick == 2)
      PWM_setIntPeriod(obj->pwmHandle[PWM_Number_1],PWM_IntPeriod_SecondEvent);
      PWM_setSocAPeriod(obj->pwmHandle[PWM_Number_1],PWM_SocPeriod_SecondEvent);
  else
      PWM_setIntPeriod(obj->pwmHandle[PWM_Number_1],PWM_IntPeriod_FirstEvent);
      PWM_setSocAPeriod(obj->pwmHandle[PWM_Number_1],PWM_SocPeriod_FirstEvent);
  // setup the Event Trigger Clear Register (ETCLR)
  PWM_clearIntFlag(obj->pwmHandle[PWM_Number_1]);
  PWM_clearSocAFlag(obj->pwmHandle[PWM_Number_1]);
  // since the PWM is configured as an up/down counter, the period register is set to one-half
  // of the desired PWM period
  PWM_setPeriod(obj->pwmHandle[PWM_Number_1],halfPeriod_cycles);
  PWM_setPeriod(obj->pwmHandle[PWM_Number_2],halfPeriod_cycles);
  PWM_setPeriod(obj->pwmHandle[PWM_Number_3],halfPeriod_cycles);
  // last step to synchronize the pwms
  return;
}  // end of HAL_setupPwms() function
#ifdef QEP
void HAL_setupQEP(HAL_Handle handle,HAL_QepSelect_e qep)
  // hold the counter in reset
  QEP_reset_counter(obj->qepHandle[qep]);
  // set the QPOSINIT register
  QEP_set_posn_init_count(obj->qepHandle[qep], 0);
  // disable all interrupts
  QEP_disable_all_interrupts(obj->qepHandle[qep]);
  // clear the interrupt flags
  QEP_clear_all_interrupt_flags(obj->qepHandle[qep]);
  // clear the position counter
  QEP_clear_posn_counter(obj->qepHandle[qep]);
  // setup the max position
  QEP_set_max_posn_count(obj->qepHandle[qep], (4*USER_MOTOR_ENCODER_LINES)-1);
  // setup the QDECCTL register
  QEP_set_QEP_source(obj->qepHandle[qep], QEP_Qsrc_Quad_Count_Mode);
  QEP_disable_sync_out(obj->qepHandle[qep]);
  QEP_set_swap_quad_inputs(obj->qepHandle[qep], QEP_Swap_Not_Swapped);
  QEP_disable_gate_index(obj->qepHandle[qep]);
  QEP_set_ext_clock_rate(obj->qepHandle[qep], QEP_Xcr_2x_Res);
  QEP_set_A_polarity(obj->qepHandle[qep], QEP_Qap_No_Effect);
  QEP_set_B_polarity(obj->qepHandle[qep], QEP_Qbp_No_Effect);
  QEP_set_index_polarity(obj->qepHandle[qep], QEP_Qip_No_Effect);
  // setup the QEPCTL register
  QEP_set_emu_control(obj->qepHandle[qep], QEPCTL_Freesoft_Unaffected_Halt);
  QEP_set_posn_count_reset_mode(obj->qepHandle[qep], QEPCTL_Pcrm_Max_Reset);
  QEP_set_strobe_event_init(obj->qepHandle[qep], QEPCTL_Sei_Nothing);
  QEP_set_index_event_init(obj->qepHandle[qep], QEPCTL_Iei_Nothing);
  QEP_set_index_event_latch(obj->qepHandle[qep], QEPCTL_Iel_Rising_Edge);
  QEP_set_soft_init(obj->qepHandle[qep], QEPCTL_Swi_Nothing);
  QEP_disable_unit_timer(obj->qepHandle[qep]);
  QEP_disable_watchdog(obj->qepHandle[qep]);
  // setup the QPOSCTL register
  QEP_disable_posn_compare(obj->qepHandle[qep]);
  // setup the QCAPCTL register
  QEP_disable_capture(obj->qepHandle[qep]);
  // renable the position counter
  QEP_enable_counter(obj->qepHandle[qep]);
  return;
#endif
void HAL_setupSpiA(HAL_Handle handle)
  SPI_reset(obj->spiAHandle);
  SPI_setClkPolarity(obj->spiAHandle,SPI_ClkPolarity_OutputRisingEdge_InputFallingEdge);
  SPI_disableLoopBack(obj->spiAHandle);
  SPI_setCharLength(obj->spiAHandle,SPI_CharLength_16_Bits);
  SPI_setMode(obj->spiAHandle,SPI_Mode_Slave);
  SPI_setClkPhase(obj->spiAHandle,SPI_ClkPhase_Delayed);
  SPI_enableTx(obj->spiAHandle);
  SPI_enableChannels(obj->spiAHandle);
  SPI_enableTxFifoEnh(obj->spiAHandle);
  SPI_enableTxFifo(obj->spiAHandle);
  SPI_setTxDelay(obj->spiAHandle,0);
  SPI_clearTxFifoInt(obj->spiAHandle);
  SPI_enableRxFifo(obj->spiAHandle);
//not needed for slave mode  SPI_setBaudRate(obj->spiAHandle,(SPI_BaudRate_e)(0x000d));
  SPI_setSuspend(obj->spiAHandle,SPI_TxSuspend_free);
  SPI_enable(obj->spiAHandle);
  return;
}  // end of HAL_setupSpiA() function
void HAL_setupSpiB(HAL_Handle handle)
  SPI_reset(obj->spiBHandle);
  SPI_setMode(obj->spiBHandle,SPI_Mode_Master);
  SPI_setClkPolarity(obj->spiBHandle,SPI_ClkPolarity_OutputRisingEdge_InputFallingEdge);
  SPI_enableTx(obj->spiBHandle);
  SPI_enableTxFifoEnh(obj->spiBHandle);
  SPI_enableTxFifo(obj->spiBHandle);
  SPI_setTxDelay(obj->spiBHandle,0x0018);
  SPI_setBaudRate(obj->spiBHandle,(SPI_BaudRate_e)(0x000d));
  SPI_setCharLength(obj->spiBHandle,SPI_CharLength_16_Bits);
  SPI_setSuspend(obj->spiBHandle,SPI_TxSuspend_free);
  SPI_enable(obj->spiBHandle);
  return;
}  // end of HAL_setupSpiB() function
void HAL_setupPwmDacs(HAL_Handle handle)
  uint16_t halfPeriod_cycles = 512;       // 3000->10kHz, 1500->20kHz, 1000-> 30kHz, 500->60kHz
  uint_least8_t    cnt;
    // initialize the Time-Base Control Register (TBCTL)
    PWMDAC_setCounterMode(obj->pwmDacHandle[cnt],PWM_CounterMode_UpDown);
    PWMDAC_disableCounterLoad(obj->pwmDacHandle[cnt]);
    PWMDAC_setPeriodLoad(obj->pwmDacHandle[cnt],PWM_PeriodLoad_Immediate);
    PWMDAC_setSyncMode(obj->pwmDacHandle[cnt],PWM_SyncMode_EPWMxSYNC);
    PWMDAC_setHighSpeedClkDiv(obj->pwmDacHandle[cnt],PWM_HspClkDiv_by_1);
    PWMDAC_setClkDiv(obj->pwmDacHandle[cnt],PWM_ClkDiv_by_1);
    PWMDAC_setPhaseDir(obj->pwmDacHandle[cnt],PWM_PhaseDir_CountUp);
    PWMDAC_setRunMode(obj->pwmDacHandle[cnt],PWM_RunMode_FreeRun);
    // initialize the Timer-Based Phase Register (TBPHS)
    PWMDAC_setPhase(obj->pwmDacHandle[cnt],0);
    PWMDAC_setCount(obj->pwmDacHandle[cnt],0);
    // Initialize the Time-Base Period Register (TBPRD)
    PWMDAC_setPeriod(obj->pwmDacHandle[cnt],0);
    // initialize the Counter-Compare Control Register (CMPCTL)
    PWMDAC_setLoadMode_CmpA(obj->pwmDacHandle[cnt],PWM_LoadMode_Zero);
    PWMDAC_setLoadMode_CmpB(obj->pwmDacHandle[cnt],PWM_LoadMode_Zero);
    PWMDAC_setShadowMode_CmpA(obj->pwmDacHandle[cnt],PWM_ShadowMode_Shadow);
    PWMDAC_setShadowMode_CmpB(obj->pwmDacHandle[cnt],PWM_ShadowMode_Shadow);
    // Initialize the Action-Qualifier Output A Register (AQCTLA)
    PWMDAC_setActionQual_CntUp_CmpA_PwmA(obj->pwmDacHandle[cnt],PWM_ActionQual_Clear);
    PWMDAC_setActionQual_CntDown_CmpA_PwmA(obj->pwmDacHandle[cnt],PWM_ActionQual_Set);
    // account for EPWM6B
    if(cnt == 0)
      PWMDAC_setActionQual_CntUp_CmpB_PwmB(obj->pwmDacHandle[cnt],PWM_ActionQual_Clear);
      PWMDAC_setActionQual_CntDown_CmpB_PwmB(obj->pwmDacHandle[cnt],PWM_ActionQual_Set);
    // Initialize the Dead-Band Control Register (DBCTL)
    PWMDAC_disableDeadBand(obj->pwmDacHandle[cnt]);
    // Initialize the PWM-Chopper Control Register (PCCTL)
    PWMDAC_disableChopping(obj->pwmDacHandle[cnt]);
    // Initialize the Trip-Zone Control Register (TZSEL)
    PWMDAC_disableTripZones(obj->pwmDacHandle[cnt]);
    // Initialize the Trip-Zone Control Register (TZCTL)
    PWMDAC_setTripZoneState_TZA(obj->pwmDacHandle[cnt],PWM_TripZoneState_HighImp);
    PWMDAC_setTripZoneState_TZB(obj->pwmDacHandle[cnt],PWM_TripZoneState_HighImp);
    PWMDAC_setTripZoneState_DCAEVT1(obj->pwmDacHandle[cnt],PWM_TripZoneState_HighImp);
    PWMDAC_setTripZoneState_DCAEVT2(obj->pwmDacHandle[cnt],PWM_TripZoneState_HighImp);
    PWMDAC_setTripZoneState_DCBEVT1(obj->pwmDacHandle[cnt],PWM_TripZoneState_HighImp);
  PWMDAC_setPeriod(obj->pwmDacHandle[PWMDAC_Number_1],halfPeriod_cycles);   // Set period for both DAC1 and DAC2
  PWMDAC_setPeriod(obj->pwmDacHandle[PWMDAC_Number_2],halfPeriod_cycles);
  PWMDAC_setPeriod(obj->pwmDacHandle[PWMDAC_Number_3],halfPeriod_cycles);
  return;
}  // end of HAL_setupPwmDacs() function
void HAL_setupTimers(HAL_Handle handle,const float_t systemFreq_MHz)
  uint32_t  timerPeriod_0p5ms = (uint32_t)(systemFreq_MHz * (float_t)500.0) - 1;
  uint32_t  timerPeriod_10ms = (uint32_t)(systemFreq_MHz * (float_t)10000.0) - 1;
  // use timer 0 for frequency diagnostics
  TIMER_setDecimationFactor(obj->timerHandle[0],0);
  TIMER_setEmulationMode(obj->timerHandle[0],TIMER_EmulationMode_RunFree);
  TIMER_setPeriod(obj->timerHandle[0],timerPeriod_0p5ms);
  TIMER_setPreScaler(obj->timerHandle[0],0);
  // use timer 1 for CPU usage diagnostics
  TIMER_setDecimationFactor(obj->timerHandle[1],0);
  TIMER_setEmulationMode(obj->timerHandle[1],TIMER_EmulationMode_RunFree);
  TIMER_setPeriod(obj->timerHandle[1],timerPeriod_10ms);
  TIMER_setPreScaler(obj->timerHandle[1],0);
  // use timer 2 for CPU time diagnostics
  TIMER_setDecimationFactor(obj->timerHandle[2],0);
  TIMER_setEmulationMode(obj->timerHandle[2],TIMER_EmulationMode_RunFree);
  TIMER_setPeriod(obj->timerHandle[2],0xFFFFFFFF);
  TIMER_setPreScaler(obj->timerHandle[2],0);
  return;
}  // end of HAL_setupTimers() function
void HAL_writeDrvData(HAL_Handle handle, DRV_SPI_8301_Vars_t *Spi_8301_Vars)
  DRV8301_writeData(obj->drv8301Handle,Spi_8301_Vars);
  return;
}  // end of HAL_writeDrvData() function
void HAL_readDrvData(HAL_Handle handle, DRV_SPI_8301_Vars_t *Spi_8301_Vars)
  DRV8301_readData(obj->drv8301Handle,Spi_8301_Vars);
  return;
}  // end of HAL_readDrvData() function
void HAL_setupDrvSpi(HAL_Handle handle, DRV_SPI_8301_Vars_t *Spi_8301_Vars)
  DRV8301_setupSpi(obj->drv8301Handle,Spi_8301_Vars);
  return;
}  // end of HAL_setupDrvSpi() function
void HAL_setDacParameters(HAL_Handle handle, HAL_DacData_t *pDacData)
	pDacData->PeriodMax = PWMDAC_getPeriod(obj->pwmDacHandle[PWMDAC_Number_1]);
	pDacData->offset[0] = _IQ(0.5);
	pDacData->offset[1] = _IQ(0.5);
	pDacData->offset[2] = _IQ(0.0);
	pDacData->offset[3] = _IQ(0.0);
	pDacData->gain[0] = _IQ(1.0);
	pDacData->gain[1] = _IQ(1.0);
	pDacData->gain[2] = _IQ(1.0);
	pDacData->gain[3] = _IQ(1.0);
	return;
}	//end of HAL_setDacParameters() function
// end of file
2045.hal.h
  • Ok, the issue is over.
    // EXT IA-FB
    //ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_1,ADC_SocChanNumber_A6); //default für drv8301kit_revD
    ADC_setSocChanNumber(obj->adcHandle,ADC_SocNumber_0,ADC_SocChanNumber_A1); <----------Here was the fault !!!!!!!!!!!
    I accidently changed “ADC_SocNumber_0” it has to be “ADC_SocNumber_1”
    Martin
  • Thank you for posting the resolution to your issue Martin
    Sean
